Hello!
First and foremost - thank you in advance for the help!
I provide the DUCOMM Channel 1 East feed in IL on Broadcastify and am looking to improve it by using my RasPi (maybe include more talkgroups, etc.).
I am trying to monitor STARCOM21 (Illinois; specifically the 774.43125 control channel) via OP25 on my RasPi 4.
I've managed to get OP25 to monitor the control channel with this script:
Here's what I get:
I can see a lot of the Talkgroups I am familiar with showing up there - great!
As soon as I started adding additional arguments I get errors.
Logic dictates that I am doing something wrong...but I really don't know what! So any help/assistance is greatly appreciated!
I try this next:
And I get this output:
Any ideas? Is my trunk.tsv malformed? I simply edited the one that came with OP25 and saved it as the same format...
Could it be the file with the talkgroups? Again, I used the file that came with OP25 so it should be the correct format/file type.
Additionally, when I try to start the web service (without using the trunk.tsv) with this script:
I get this output:
I assume I am doing something wrong here, neglecting to include a specific arguement, etc...but I really don't know what and my research leads me in circles.
Any help is greatly appreciated!
Thanks!
D
Code:
./rx.py --args 'rtl' -N 'LNA:49' -S 2500000 -f 774.43125e6 -2
Here's what I get:
I try this next:
Code:
./rx.py --args 'rtl' -N 'LNA:49' -S 2500000 -f 774.43125e6 -2 -T trunk.tsv
Using Python /usr/bin/python2
gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.13.4
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp
Using device #0 Realtek RTL2838UHIDIR SN: 00000001
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
gain: name: LNA range: start 0 stop 0 step 0
setting gain LNA to 49
supported sample rates 250000-2560000 step 24000
Exact sample rate is: 2500000.107620 Hz
Using two-stage decimator for speed=2500000, decim=25/4 if1=100000 if2=25000
p25_frame_assembler_impl: do_imbe[0], do_output[0], do_audio_output[0], do_phase2_tdma[1], do_nocrypt[1]
Traceback (most recent call last):
File "./rx.py", line 1068, in <module>
rx = rx_main()
File "./rx.py", line 975, in __init__
self.tb = p25_rx_block(self.options)
File "./rx.py", line 238, in __init__
self.open_usrp()
File "./rx.py", line 890, in open_usrp
self.__set_rx_from_osmosdr()
File "./rx.py", line 819, in __set_rx_from_osmosdr
self.__build_graph(self.src, capture_rate)
File "./rx.py", line 370, in __build_graph
self.trunk_rx = trunking.rx_ctl(frequency_set = self.change_freq, nac_set = self.set_nac, debug = self.options.verbosity, conf_file = self.options.trunk_conf_file, logfile_workers=logfile_workers, meta_update = self.meta_update, crypt_behavior = self.options.crypt_behavior)
File "/home/pi/op25/op25/gr-op25_repeater/apps/trunking.py", line 842, in __init__
self.build_config_tsv(conf_file)
File "/home/pi/op25/op25/gr-op25_repeater/apps/trunking.py", line 977, in build_config_tsv
self.setup_config(configs)
File "/home/pi/op25/op25/gr-op25_repeater/apps/trunking.py", line 1031, in setup_config
self.configs[nac]['cclist'].append(get_frequency(f))
File "/home/pi/op25/op25/gr-op25_repeater/apps/helper_funcs.py", line 46, in get_frequency
return int(f)
ValueError: invalid literal for int() with base 10: '0x145'
Code:
./rx.py --args 'rtl' -N 'LNA:49' -S 2500000 -f 774.43125e6 -2 -l http://127.0.0.1:8080
I get this output:
Failed to create http terminal server
File "/home/pi/op25/op25/gr-op25_repeater/apps/http_server.py", line 143, in __init__
self.server = create_server(application, host=host, port=my_port)
File "/usr/lib/python2.7/dist-packages/waitress/server.py", line 49, in create_server
adj = Adjustments(**kw)
File "/usr/lib/python2.7/dist-packages/waitress/adjustments.py", line 368, in __init__
raise ValueError('Invalid host/port specified.')
ValueError: Invalid host/port specified.
Thanks!
D
