RD982 digital programming issue
CR9
I purchased a RD982 UHF from the estate of a local ham. It was programmed and the duplexer tuned but still remained in the original box and not yet put on the air. They could not find any paperwork, software or cables. I purchased a programming cable and got CPS version 8.05.06.008NA2. When I read the programming I only see a single analog channel. There is no digital channel programmed and I cannot find how to add a digital channel in the CPS. I can add analog channels and change the one that is already there. I can read and write to the repeater fine. What do i need to do or what am I doing wrong? I need a digital channel.
MSS-Dave
Generally Central Florida
Hook up the repeater via your programming cable. Go to the Common tab then Feature Control. Click on the Feature Check button. Look at top of box in the Repeater Mode Control Conventional box. If it says Analog Only, repeater does not have Digital Option. That can be added by a license purchased from a Hytera dealer.
Dealer price is $468.00. List would be at least 30% higher.
If the Digital option was installed, you would see Analog, Digital and Mixed Channel under the Conventional > Channels tab.
