Required file 'lame_enc.dll' not found in current working folder
danbq14
I am using SDR# with DSD+ interface. After the update to DSD+ fastlane. Iam getting the following error:
But "lame_enc.dll" is in the DSD+ folder
I am new in using DSD+ Fastlane
DSD+ interface was working before this update
I updated DSD+ 1.101 to 2.303
danbq14
DSD+ plugin is checking in C:\DSDPlus folder but cant find lame_enc.dll , but this file is in C:\DSDPlus folder.
Shall I copy lame_enc.dll in the C:\SDR# folder instead?
Or shall I copy all DSD+ files in that SDR# folder?
slicerwizard
Toronto, Ontario
No, the plugin is running DSD+ in the SDR# folder. DSD+ is checking for the lame_enc.dll file, but DSD+ is not running in the DSD+ folder.
Probably won't help. I'd expect DSD+ to be looking for other files as well.
You can do that. Then the SDR# folder is your DSD+ folder. Then your original DSD+ folder is... just a backup folder?
Personally, if I was using SDR#, I wouldn't use the plugin.
bravo14
Polk County FL
You can download the Newest Base Files
Go to Msic than go the last list and it will have the files to download.Screen Shot 05-28-21 at 09.15 PM.JPG
danbq14
If I dont use the plugin with SDR#, how can I start DSD+ while using SDR#.
Thanks for your answer.
danbq14
How can I direct the output of DSD+ to SDR#?
Sorry I am new with this software.
slicerwizard
Toronto, Ontario
You start DSD+ by double-clicking on the DSDPlus.exe file in the DSD+ folder.
You direct the output of SDR# to DSD+ by telling SDR# to use a virtual audio cable for its audio output and you tell DSD+ to use the same cable as its input.
danbq14
The only way to start DSDPlus Fastlane seem to be by running 1R.bat and then FMP24-CC.bat
When I start DSDPlus only, in the 1R DSD+ windows I receive :
Initiating FMPx link using link ID 20001...
FMPx link error = -5
[Server is not listening on selected link ID]
and I dont see the audio windows
slicerwizard
Toronto, Ontario
Why can't you start it by double-clicking on the DSDPlus.exe file in Windows Explorer?
Did you read the instructions in Notes.txt?
Using DSD+ with external signal sources
DSD+ can be used with external signal sources such as a properly discriminator-tapped receiver
or SDR software such as SDR#. To use DSD+ with these sources, use the menus in DSD+ to
select Passive Digital Monitor mode and then to select the audio input device that carries
the digital audio signal. When running in this mode, DSD+ can be used to monitor conventional
analog and supported digital signals; DSD+ will not directly support trunk tracking.
danbq14
Thank's very much for your help. I got it working but it does not seem to work on every stations. Also could you tell me how I can listen to analog stations without rerouting my audio to direct sound speaker instead of Direct Sound vb audio Virtual cable?
danbq14
In the 1R event log if I select i/p "Use direct FMPx Linking", I get the following error in the DSD+ windows
I have to select "Cable Output (VB-Audio Virtual) in order to decode. But it does not always decode. If I switch to an analog station after, I have to increase the audio in sdr# and also select "Filter audio"
Is this normal?
Sorry to bother you with all those questions but I am a newbie.
danbq14
I would like to listen to Police conversation (dmx), airport, ambulances and amateur radio. SDR# let me tune to all these frequencies easily.
Do you know any other software more compatibles?
