DSDPlus RFSS_STS_BCST showing different CC
billy2047
📶 🕨 Ø T₁ ÆS Ⱬ ⬜ ᴴ L |→| 𝅘𝅥 💾 🛰️ 🔋
SYS REG RFSD OUT OF RANGE NO COMMS
Hi all, I'm watching 1R DSD+ window and I've noticed my local P25 system is sending out a different control channel indicated by RFSS_STS_BCST status broadcast.
For example, the screenshot shows CC=853.8125. but in reality, the CC for the system is transmitting on 856.7125. When that happens, DSD+FL jumps to 853.8125 and then nothing.
There is nothing transmitting on 853.8125 and the frequency is not even part of the system.
Does anyone know why? Thanks
dave3825
Suffolk County NY
That was reported December 2024 and back then it was not happening to you. Now it is. Something changed somewhere.
I’m in the i4/95 area and was seeing site 71 856.7125 soon as I click that freq it goes to 853.8125. And there’s nothing there on the 853.8125. Has anyone see the 856.7125?
I'm decoding site 71.71 (856.7125) right now and it doesn't jump to 853.8125.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
What version of DSDPlus are you running? (you should always indicate that from the start)
bravo14
Polk County FL
I was running the newest version of DSD. I've tried different versions still happening on them. I don't know if there is a difference from 1r to dsdplus cc. I do use FMP24 CC when using 1r or dsdplus cc.
mtindor
FMP24 PRO USER
You should consider going to CTRL and setting it to CC-only. Then Record some raw audio (I'm guessing 30 seconds is reasonable because I imagine the RFSS_STS_BCST is being repeated so quickly / often that there would be a bunch of those in just a 30 second capture. Then post it here (so some of us curious people could see it for ourselves) and send it to dsdplusfastlane@gmail.com.
Have you ever tried any other trunking software (like SDRTrunk) on the same system? If so, does it exhibit the same behavior? Do you see the same RFSS_STS_BCST info being reported?
