I'm having a heck of a time locating 'thru the wall bushing' for RG 8 coax. I can order from China, but can't seem to find any in U.S. Searched Amazon, Ebay, etc. ..an hour later, still no luck. Any suggestions ?
Well, after searching for over an hour again today, I give up. I'll just have to get creative and poke around Home depot to get some ideas.
Thanks for the responses.
Go to your local hardware store and get some of the grey PVC conduit from their electrical department. It's cheap and glues together just like sprinkler pipe. Get something big enough that you can fit a few pieces of coax through, as well as a ground wire. On the outside of your home, use one of the PVC boxes they sell. Run the conduit in to the back of the box. Route the coax out the bottom of the box. Stuff some fiberglass insulation into the end of the conduit once the cables are in to keep the cold air from coming in.
That traps you with UHF connectors, which may not be ideal if you are doing high frequency stuff. But if you were, you probably wouldn't be using RG-8.
