Can you make a video showing this setup on a Phase II P-25? Thank You.
All I have is simulcast towers around me, so I won’t be able to receive any of the P2 around me since the 996p2 sucks with LSM. What exactly are you looking to see?
It doesn't matter if the reception sucks due to LSM issues. Want to see if it actual just passes the display info back to RH-96 on a Phase II system while trunking. There are menu commands that the RH-96 would not accept from a 996/325P2 in terms of P-25 phase II.
Can you tell me what cord your using between the RH and the box, did you get an angled connector on one end?OK, I now have the version 2 working with the GPS connected and working. The schematic is correct but the photo on page 9 is wrong. Use pins 2,3, and 5 as the schematic shows.
Gold Plated... Perhaps there is a less expensive one thru Digi-keyI have a 3.5 mm stereo cable with a right angle plug at the remote head. I got it on amazon.
Here is the link:
https://www.amazon.com/gp/product/B0793KY93Z/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&th=1
Also, I am running a separate audio cable for a remote speaker since the remote head does not provide the audio freed.
Soonest I could do this is probably Monday. I live far enough away from a Phase 2 tower that my signal is too weak to pick it up. If it were still in my home I could test with my roof antenna, but it's now in the car and I won't be pulling it out for this. When I get to work on Monday, I'll be much closer to the tower and I'll see what happens. Although it's a Phase 2 tower, that doesn't necessarily mean the transmissions will be p2, at least that's my understanding.It doesn't matter if the reception sucks due to LSM issues. Want to see if it actual just passes the display info back to RH-96 on a Phase II system while trunking. There are menu commands that the RH-96 would not accept from a 996/325P2 in terms of P-25 phase II.
If 8 bucks is too expensive, just get a stereo 3.5 with angled end for the rh96. Remember, you get what you pay for in this hobby.Gold Plated... Perhaps there is a less expensive one thru Digi-key
That depends on how it's wired. Suspect there is a ribbon cable from the front display/keypad board over to the main board. So, that's why the data is sent in serial format from the scanner to the RH-96.Would it be possible to remove the entire front area (display/knobs) as one piece, and somehow lengthen the wires so the original display could be placed in one location, with the rest of the scanner brains under the seat or somewhere?
Don't know if the talkgroups shown are Phase 1 or 2, but the tower is a Phase 2 tower. For what it's worth, here ya go. No audio, just video...It doesn't matter if the reception sucks due to LSM issues. Want to see if it actual just passes the display info back to RH-96 on a Phase II system while trunking. There are menu commands that the RH-96 would not accept from a 996/325P2 in terms of P-25 phase II.
Thanks for taking a moment to post that. Really appreciate it.Don't know if the talkgroups shown are Phase 1 or 2, but the tower is a Phase 2 tower. For what it's worth, here ya go. No audio, just video...
The point would be that I have an RH-96 for my 396T and I was curious if it would work. Thanks for your reply.No, because it runs off a serial connection, and the 352 does not have one. Besides, the radio is smaller than the RH so what would be the point?
The point would be the 325p2 can be mounted in a box and located in the trunk of a vehicle or mounted under the seat - remote control of the radio...No, because it runs off a serial connection, and the 352 does not have one. Besides, the radio is smaller than the RH so what would be the point?
