Got everything connected but now cant get it programmed! Here is the error log:
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
Sketch uses 1644 bytes (5%) of program storage space. Maximum is 30720 bytes.
Global variables use 389 bytes (18%) of dynamic memory, leaving 1659 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM9 -b57600 -D -Uflash:w:C:\Users\mainuser\AppData\Local\Temp\arduino_build_597724/996p2.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean,
BDMICRO Microcontrollers, Relays, Optocouplers, and IoT
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM9
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xb9
avrdude done. Thank you.
Problem uploading to board. See
Arduino - Troubleshooting for suggestions.
I have checked the site for suggestions but everything seems to be checked correctly. I did notice that I have one light on the board solid and the other slow blinking at all times. I have tried this on 2 boards with the same result.
Any suggestions?
