rtl-sdr
rabbit108
S.E. VA
The first time I didn't remove the checkmark, I got the message "USB Open error 12."
The second time I didn't remove the checkmark, I got "Device not Found" when I tried to start the software display, even though I had selected the RTL USB as the source.
Open Device Manager to check for dongle:
More later after Lunch.
kg4ehv
Radio Active
Penrose N.C.
Kudos Rabbit, I've had a sdr for years and never got it to work. I started reading this thread and had some time, I dug it out of the junk box and followed your post and boom it works. Thank you very much.
rabbit108
S.E. VA
Open SDRSharp:
Select RTL-SDR USB as source, click on gear to show RTL-SDR Controller to adjust RF Gain, and click on Start triangle at upper left:
Enjoy!
The setup will be a little different for Windows 7, and a lot different for versions after v1784. V1784 is the last version to include SpectrumSpy.
rabbit108
S.E. VA
This is SDRSharp v1906. Norton didn't want me to download it, but I downloaded it anyway and had Norton check the downloaded file.
Microsoft Defender didn't want me to run it, but I ran it anyway:
I had a lot of trouble getting the RTL-SDR V3 dongle to run the free GitHub DIY Scanner software to simulate a spectrum analyzer, but I finally got it to work. I used V1.3.0, 64bit exe:
Releases · EarToEarOak/RTLSDR-Scanner
lwvmobile
DSD-FME
Just my own two cent, for what its worth, if you are using Windows 7 32-bit, you may need to use an older Zadig driver installer. I had to use the zadig_xp-2.2.exe installer listed under other versions to get it to work correctly in my Windows 7 32-bit VM. And before any questions/criticism over choice of OS rolls in, its just for compiling software (DSD-FME) against the least common denominator of choice, and being able to test it properly.
rabbit108
S.E. VA
That's a good idea; I'll have to try it. I have 2 old Windows 7 laptops. One with W7 32-bit OS, and one with 64-bit OS, but the 32-bit has a failed HD.
N1EXA
FT8 Huntin Mudd Duck on the deep end of the pond !
Acushnet Heights New Bedford MA - GRID FN41 mp
It's not so much me not knowing how to use the software if the software's lack of ability of working I can't get nothing to download and work right as coming up with either a kernal 32 error code or an error code stating that this dll is missing or that dll is missing regardless of what website I download the software from it's almost like the software that's out there is corrupt
Use the Genric DLL File
Pete N1EXA
dave3825
Suffolk County NY
I seem to remember an issue a while back when they started that .net crap.
Even tho my pc is 64 bit that I had to download the .net 32 bit version as that is what sdr# is, 32 bit.
rabbit108
S.E. VA
The following are tests with SDRSharp in a Windows 7 computer, with the focus on Zadig. This is the computer I will be using:
First with SDRSharp v1732:
I will be using the Zadig that comes with the SDRSharp download:
