SDR# RTL433 Plugin For SDR# Now Available
Marco402
New version 1.5.6.0 January 15, 2023 Tested with SDRSharp 1906
-Update RTL_433 (25 more devices)
-Memorize the frequency by exiting SDRSharp lost by adding the enabled plugin button.
-Change framework 4.6 to 4.8.
For this year, still some installation problems:
Warning: Do not try to download the dlls by right-clicking on them which opens the browser menu and save the link as,
this action creates a text file of the dll name.
You have to click on the name of the dll with the left button and download (start again for the other 2 dlls) or download ZIP file.
Marc
hamradionl
Hi,
thanks for update.
Older releases after press START in console i see some verbose filter settings lines popup
SDR#1902
this new version not have/shown?
Older release 868 i the past some things popup,
in new release nomore
But............ not sure if the units are gone in 868
Marco402
Hi,
This is RTL_433 that sends messages to the console based on -v
Indeed the line at the start is not there.
I don't understand if you have a units problem?
why release 868 ?
Marc
sunwave
Oklahoma
Marc
I downloaded it and installed it. It seems to be working but I have no idea what the signals should look like on the waterfall. I am in the Oklahoma City, Oklahoma USA and not sure if ISM devices are a used much here. They seem to be low power. I am really new to it.
Marco402
It must be possible to systematically save all devices in a txt file with a checkBox at the plugin level.
Name file =date+time+device name .
Marco402
Hi
I have update version 1.5.6.1 to github with messages records. I kept .txt with the tab separator. Read details in README.
Marc
ve2mel
Saint-Pascal, Québec, Canada
Hello Marco402,
I tried rtl-433 with a hackrf one , and it still crashes. I changed to a small usb key rtl.sdr V.3 and it works very well. I am up to date with airspy and the plugin too, 1.5.6.1. do you have any idea why i'm not able with my hackrf-one? because I have a better reception with, compared with my USB key.
Marco402
Hi ve2mel
I don't have a HackRf to try, did you set the sampleRate to 1.024 to begin with?
If not ok, can you give me the details of the error?
Marc
ve2mel
Ok, for now, I can't go below 8. I put it at 8 and for now it runs for 1 hour without planting. before by default it was at 10 meg sampling rate. I'll let you know of the results. Thank you for your return.
sunwave
Oklahoma
I got something to show up. Set the bandwith to 1.8Mhz. should be detecting more than this. Many ISM signals in th 915MHz area from 906MHz to 928MHz full of ISM signals1674958522239.png
edit: Well now it is starting to show more activity1674958886148.png
edit....a few minutes later....That Regency remote device must be a nice one. More actions in one window 1674959364822.png
edit.....minutes later...8 events
nj3h
Redmond, OR
Hello Marco,
Thank you for you RTL_433 plugin for the SDR# program.
Yesterday, I was having no issues. I was able to get the popup windows to open up with the data from each decode. However today, I see the data on the waterfall, but the data windows are not opening up. Please see the attached picture. do you have any ideas as what might be causing this to happen?
Thanks for any help,
George
Marco402
Hi nj3h
I don't see, have you tried to restart airspy or computer or wait longer, the displayed signal may not be recognized?
Marc
