SaiaNet/DMR Questions in WNY
lkas
Cheektowaga NY
Ok I have a hopefully simple question, I live Near UB North Campus (cooke hall tower) and I want to only monitor UBPD, would it be safe to assume I can get away with only programming the cooke hall site into my scanner and get away with hearing 99% of the communication. I currently monitor 3-4 sites and feel like that is not needed?
in a nut shell YES.. they are constantly on that site and Site 1 Seneca tower
ak716
'Merica
I'd say so. It's the most likely tower some units would affiliate with regularly. Like you said 99% of the communications, you realize that you might miss something on some blue moon day, which is key! The only way to almost guarantee hearing everything is to have a radio that belongs to that system.
DaveNF2G
Latham, NY
Site 16 in Rochester has another channel pair that is not in the DB. I wasn't able to track down the frequency while I was there on Friday. The site is using "channel" 19/20 (10 in RRDB form) in addition to the ones already listed.
k2hz
Rochester, NY
I will watch it today. Is this the Con+ or the TIII system?
k2hz
Rochester, NY
I see it is the CON+ it looks like they may have dropped LCN 3 so I need to watch it for a while.
k2hz
Rochester, NY
LCN 3 just came active so the only change is to add LCN 10 if I can find the frequency. They may be working on the site since 2 and 3 were quiet for a long time with traffic rotating on the upper channels. Then 2 and 3 came up and the upper channels were quiet for a while and now back to normal all channel rotation.
k2hz
Rochester, NY
Site 16 LCN 10 LSN19/20 is 463.3875. RRDB will be updated in a few minutes.
k2hz
Rochester, NY
Is there anway to find out what agencies are affiliated with what sites?
How many times do we need to tell you affiliation depends on what site a subscriber unit to an agency TG is in range of at the particular time!
Agencies are not assigned to particular sites. But, if they operate in a particular area, the closest site is a good possibility most of the time.
Question asked and answered many times and the answer is not going to change.
seagravebuff60
Short Bus Reject
Please stop already. Out of your 69 posts, in about 30 or so of them, you have asked this same exact question, which has been answered many times by multiple people over time, and the answer will not change.
