Those are correct...due to dispatcher staffing deficiencies. N/E, S/E, and NCW talkgroups are most commonly used for special incidents such as protests or backup when the main is active for a SWAT or such.
Paul
Thanks, Paul!
Paul
SD Bud, about a year and a half ago, you shared the info below in regard to SDPD dispatch areas. Just curious if this is still accurate?
>> NE on Eastern, SE on Southern, NCW on Northern
Thanks!
The plan was, a few years back, to have those broken out as separate areas soon, but Covid probably helped slow that down some.
Who KNOWS now what they'll do.
Have you experimented with the filters? I get somewhat crappy reception on that system unless I use the W-INV filter.Do other listeners experience audio dropout when listening to the new 700Mhz system on an SDS unit? An example would be missing a street name or unit ID. Probably a second at the most. I have it on both my SDS100 and 200. However, I don't notice this issue when listing to the Next Gen RCS. I am wondering if a setting change might correct this on the SD system? I generally have a solid 3+ bars on my signal display. My 100 has a Remtronix 700/800 antenna and my 200 has hardwired Motorola NMO 700/800 antenna on my SUV. Any advice is appreciated!
How did you program the system into your uniden? I used p25 and entered all CC’s yet I hear nothibgI have it programmed on my BCD396XT and it is very choppy as well but it depends what antenna I have equipped on it but I do not listen much to it because it is mostly garbage trucks on it.
Hearing Mid-City currently patched on the 700 system.
Paul
i have a uniden 996P2. And I’m using Free Scananthony,
Have you checked the appropriate box[es] in "EDIT PROFILE"? Monitor/Download? Service Type?
