Saratoga County TRS Official Thread
lafd55
Albany, NY
If Ballston Spa follows the pattern then their RIDs would read 714313-714318 but have seen PD and Constable units as 713XXX. Also if anyone has a question on a RID I have been scanning and recording and have a pretty decent list. Still myself have questions on some. Thankfully the only good thing about the Saratoga TRS is the fact that RIDs follow patterns compared to Albany or Colonie...
lafd55
Albany, NY
Also, does anyone know if Waterford PD is coming onto the system and getting off Capital Digitronics?
radicalbill
Malta, NY
New TG 1811
I heard a new TG today. It sounds like it is encrypted
1811
anyone know what this is used for ?
Bill
lafd55
Albany, NY
Ballston Spa PD is now being dispatched by the Sheriff Dispatch on the TRS, they do not have mobiles yet just portables, 5 that I have tracked.
lafd55
Albany, NY
All non-Sheriff dispatching and communication is done on 1711 but they are also on 911 (1111) for emergency calls. Here are their portable RIDs
723101
723102
723103
723104
723105
gmwink
Ballston, NY
BCD396XT Help
Hello all, I am looking for some suggestions before I pack up my new scanner and send it back. I have read all the post, followed many suggestions, but cannot find an answer to my problem. Any help is greatly appreciated. I have a new BCD396XT. I have programed it with the Saratoga P25 info using Scancat and Freescan. The scanner seems to program correctly with each. However I am only receiving minimal transmissions. I am using the Saratoga feed from Broadcastify as my reference. On the scanner I only receive a few Sheriff and EMS transmissions that sound like they are originating from a field radio, and no fire transmissions. I have all the talk groups programed and nothing is locked out. I have set the attenuation both on and off. Also, I am 7 miles from both the towers in Milton and Clifton Park, in Burnt Hills. At home I get 2-3 bars but I don't think the distance is an issue because I drove to within a mile of the Milton tower, the bars improved to 4-5 but there was no increase in the traffic.
Not sure what else to try and need to know if this is a lost cause. Thank you for any suggestions.
radicalbill
Malta, NY
sounds like not getting good signal
check that you are getting 99%
I had the same issues, and I put up an outside Yagi antenna and that made a huge difference
gmwink
Ballston, NY
Thanks for the suggestion. One quick question, during programming I did not input any APCO Band Plan data. I look on my scanner now and see two entries. Is this normal, or should I have more entries?
lafd55
Albany, NY
Saratoga County is very hit and miss with scanners, you either have to make sure you are in a sweet spot or mount an antenna to your house or vehicle.
kc2kvy
Has anyone had any success monitoring this system using RTL SDRs?
lafd55
Albany, NY
Now hearing Stillwater PD on the TRS, similar to Ballston Spa PD they only have portables at this present time.
UID: 723701
gmwink
Ballston, NY
Can anyone recommend a yagi antenna that they have success with for Saratoga county? Not looking to spend a lot of money. Thank you in advance.
radicalbill
Malta, NY
I have a few antennas I am trying to sell
I have some big Yagi antennas that work well on the 800 band.
I bought more than I can use.
I would sell one to you for 25.00
They retail for around 100.00
They are used, but work just fine.
Let me know if you are interested, I am in Malta, NY.
Bill
KC2OVX
radicalbill
Malta, NY
I called but there was no answer
I am usually available till around 1pm each day.
I get up real early.
Not sure what your schedule is like.
Let me know if you can do mornings, maybe before you go to work.
Bill
