SDS100/SDS200: Scan mode nothing to scan
sds100guy
I have a favorite lists setup I have systems departments and channels set up in that list, and when I go to monitor it it says scan mode nothing to scan. The channels are from the NJICS system. No channels in my county are coming up. I do not have any quick keys, and monitor and download are both set to on.
tvengr
Well Known Member
Baltimore County, MD
Are you using a SDS100? What is your city and county? Do you have the appropriate service types enabled in the profile? If you attach your favorites list file, I will take a look at it and check for problems. Go to the File tab in Sentinel and click on Export to hpe file (Favorites List). You will need to right click on the exported file and Send to Compressed (zipped) folder to be able to attach it. Click on Attach files and open the zipped folder.
jtwalker
not sure how do I set them up, I just pulled them from the database into a favorites list.
You pull the entire system from the database, then delete/avoid talkgroups/departments you aren’t interested in AND delete/avoid sites that aren’t close enough for you to receive … but you have to leave at least one site.
The reason I mentioned sites is because you didn’t.
sds100guy
I have attached the zip folder, and I believe to have all the service types enabled
  • Essex County.zip
tvengr
Well Known Member
Your favorites list does not have any sites for the NJICS trunked system. You need to add this site:
1 (1)001 (1)West Orange SimulcastEssex, NJ769.19375769.45625769.66875769.96875770.44375770.66875770.91875
773.34375773.79375c774.31875c774.54375c774.78125c
You have 2 departments (Essex County and Channels) with both containing the same talkgroups. One can be deleted.
sds100guy
Thank you i will add that to the list right now
Brales60
Punta Gorda, Fl
They can be a *****. Took me quite a while to figure out my SDS200, and I still only know about 25% of it. Keep at it, it'll start to fall in place. I now routinely add and delete things to listen to.
sds100guy
If you let me know your city, I can check if any additional sites will give better coverage for your area.
Thank you, I am in verona but work in cedar grove they are right next to each other tho so either should be great.
