Now the other big question is, should you wire tie your coax to the mast? If not, what is the best way to run your coax for less line interference?
Yes, but make sure you use Ty-Wraps that are specifically marked as UV stable. The non-UV stable versions will get brittle and break.
Other option is to get the stainless steel ty-wraps.
