Scanner receiving
Bonkk083
Union, SC
Will a scanner receive a better signal without a splitter, multicoupler or amp?
dave3825
Suffolk County NY
Spliter does what it says, it splits. So on weak distant signals, you will have issues.
Multicoupler, if it has zero loss between ports then it’s not degrading your signal so there should not be any difference.
Amp. How is it being used? If you’re using the amp to basically receive the signal because it’s weak then you might not hear it at all without the amp. If the amp is overloading the scanner then it would be better to attenuate the signal before it hits the scanner
Bonkk083
Union, SC
How can I find out loss between ports, maybe this is i
Frequency Range: 25 MHz to 1 GHz 4-Ports
Nominal Impedance: 50 ohm
Port-To-Port isolation (min): 22 dB
Return Loss (all ports): > 20 dB
P1dB = 17 dBm (output) 3OIP = 32 dBm (output
Coupler Gain/Loss: +2 dB to -1 dB (max) over frequency range
RF Connectors: BNC (standard)
Mechanical: 4.375 X 2.375 X 1.250 inches (L.W.H)
Case: Die cast Aluminum, Black powder coating (standard)
DC Power Connector: 2.1/5.5mm coaxial (standard)
DC ower Requirements: +12VDC (nominal) @ 85 mA
