Scramble Channels
KHPFAN
This may be a long shot, but i was wondering if there is a way that you can get past, listening from a scanner, those scramble channels that some SO's or PD's have to distort their traffic.
gewecke
Illinois
If they transmit in the clear with a pl or dpl,then simply program their tone in your radio. encryption many times is not transmitted with a tone,so you wouldn't hear the noise when they go to encryption.
N9ZAS.
KHPFAN
Main freq is 155.7450 and it's tone is 152dpl. What frequency is that, that i need to program
firefive76
Kansas
Lot of places are using rolling or hopping code scrambling. Have yet to hear of anybody that can "decode" them.
n0lqt
Howe, TX
Sure there is! "N"o "S"uch "A"gency..... .... and probably DHS. Amazing what you can do with a few IBM Roadrunners or Blue Gene supercomputers in the sub-basement of you office...... but then again, they probably have all the keys anyway (anybody remember "Key Escrow"????
N
N_Jay
Guest
I think the last few posters are misunderstanding the OP's question.
gewecke
Illinois
To KHP...If the agency your refering to is using "securenet" for encryption,then entering the 152dpl should mute the noise. I'm suggesting this because of a local pd that uses the same encryption standard,and it's tone of 146.2pl is not transmitted when code is on.
Now if it's single inversion scrambling as mentioned,then maybe a DNE (don noble electronics) decoder would work nicely if installed in to a external speaker.
I've had a DNE for years,I use it to decode some of the bubble pak radios that have the scramble feature.
N9ZAS.
KHPFAN
it's a local pd that is using it, i didn't know if there was just a different frequency to use that would decode it or not...there not a large department and not all the units have the ability to use it so i didn't know how hard or easy it would be.
gewecke
Illinois
IF it sounds sort of like donald duck when they transmit,then you can decode it...but NOT legally.
IF it sounds like you have your squelch open without a signal,when they transmit(white noise) then good luck with that! Be happy with what you are able to hear in the clear! No pun intended.
N9ZAS.
KHPFAN
Their pretty much donald ducks in uniform...haha. But thank you
gewecke
Illinois
That's a good duck...er,um I mean thing! This means they can be decoded by installing a device which re-inverts the speech back to it's original form and removes the null tone.
