SDR# SDR# issue output for Dmr uplink
maxcrt
Using SDRSharp versions greater than 1910, DSDplus installed or DSD interface plugin (1.009)is not able to transfer the Uplink of Dmr repeater or Direct mode communications.
The downlink is correctly decoded, without changing anything.
Using SDRSharp versions before 1913, both Downlink and Uplink are correctly decoded
maxcrt
Has anyone else encountered the problem?
It is seen very clearly that the monitoring of Dmr traffic between mobile devices (direct mode) or uplink of Dmr repeaters is stopped using DSDplus from SDR# as soon as it receives the first frame.
As SDR# closes the connection with the virtual wire if it doesn't receive the signal from the base stations
