SDRTrunk SDR TRUNK question
bobruzzo
W1AV
Cranston, Rhode Island
I am using the SDR TRUNK version 0.5.0 BETA 2.....running fine on my local statewide P25 system.....but when I turn on a 900 Mhz business band DMR system, it sort of works, I see activity but no audio and I get THIS on the other screen (see photo). I have no idea what this means....this was working OK on previous release. Computer is HP EliteDesk i7 6700 16GB RAM. Sample rate in SDR TRUNK set at 2.048
dave3825
Suffolk County NY
050 beta 2 came out Mar 21, 2022. There have been some newer versions since then. You can look for that error in github or just try out one of the newer versions. I am running 060 Alpha 6. 053 final and 060 alpha 5 came out in April.
bobruzzo
W1AV
OK I will try another version, thanks
bobruzzo
W1AV
I also notice this ERROR, something about SDR Play api library. I am listening to the state P25 trunking system, working fine, still cant get audio from the 900 Mhz business repeater, even tho I see talk groups scrolling through. But what is THIS error mean?
dave3825
Suffolk County NY
SdrPlay support was added so it scans your pc to see if the SdrPlay api software is present. If you do not have any SdrPlay dongles, you would not have any SdrPlay api software on your pc and the message can be ignored.
