SDRTrunk - p25 decoder test release
thewraith2008
Have a look in "sdrtrunk_app.log" in "SDRTrunk\logs" to see if JMBE has loaded.
When you have P25 channel started there should be an entry in the log:
Code:
20180612 115134.917 [AWT-EventQueue-0] INFO  i.g.d.m.d.p.a.P25AudioModule - JMBE audio conversion library [JMBE Audio Conversion Library v0.3.3] successfully loaded - P25 audio will be available  [20MB/29MB 68%]
If not loaded, then file is not where it should be or is bad.
If is loaded, then issue is else where.
I don't use P25 so I can't help beyond that.
AB9NN
Beulah, MI
THANKS for the informative response. I found the log - or at least the one from last night. I have concerns. Here are the log contents pertinent to our discussion:
20180611 220822.780 [sdrtrunk pool-1-thread-4] INFO i.g.d.m.d.p.a.P25AudioModule - JMBE audio conversion library [JMBE Audio Conversion Library v0.3.3] successfully loaded - P25 audio will be available [147MB/256MB 57%]
20180611 220822.792 [sdrtrunk pool-1-thread-4] INFO i.g.d.source.tuner.TunerModel - Unable to source channel [853875000] from preferred tuner [RTL2832 SDR/R820T 00000001] - searching for another tuner [148MB/256MB 57%]
20180611 222336.433 [AWT-EventQueue-0] ERROR i.g.d.s.t.r.r.R820TTunerEditor - R820T Tuner Controller - couldn't apply sample rate setting [2.400 MHz] [469MB/1GB 31%]
org.usb4java.LibUsbException: USB error 9: error writing byte buffer: Pipe error
In particular:
I think that the radio is not being fully accessed since the lower right panel on the Tuner tab is grayed out even though a radio shows in the rest of the panel.
Another concern. What relative size is the JMBE Library file? Mine is around 69 KB. Seems small. Makes me wonder if it's really all there... smile.
thewraith2008
How many dongles you using?
Outside of SDRTrunk do the dongles work? (like in SDR#).
You may need to re-run Zadig.
Is your PC CPU OK. When pooling dongles like SDRTrunk does it can be taxing on the system.
Poor CPU performance can affect USB throughput.
A tool called RTLTool can test this and check available sample rates.
RTLTool
69Kb sounds right - It's only the decoder part.
AB9NN
Beulah, MI
I ran the test - and it produced nothing... I tried both versions of the test software. It found the dongles and allowed me to select one. I tested both. I selected no bits, then 1 - 7 sequentially, then all except zero. Clicking the test button produced no change in the tool. I think it reads the name but can't fully connect to it just like SDRTunk. The dongles work with other softwares like SDR# but have issues when changing frequencies.
I am using two dongles. They had worked surprisingly well for a good amount of time both with SDRTrunk and with other softwares. Both dongles being used by SDRTrunk and in a configuration where one dongle used SDRTrunk (or was used by it) and the other running other software (supplying signal to that other software). That was on an old but 3 year old then new Windows 10 PC with memory maxed out. Since that time I acquired a new PC. I believe it to be a good VR machine. I will test however. I would be surprised if that were the issue. Especially since they worked well until a Windows 10 update.
I will continue to work with Zadig but have done that. I will continue to work with it... PC CPU should be fine as it is new. Also, they worked on old PC until the driver install issues.
thewraith2008
The 'RTLTool' "Dongle Test" when run, you should see data transferred with no BYTEs lost.
If BYTEs are lost then stop and continue OK then usually dongle is no good at that sample rate.
If BYTEs are continually lost with the selected sample rate (ie. 2.4) then a problem exists. Usually CPU and or USB throughput.
If no data is transferred then there maybe be an issue with hardware or drivers.
Not sure what "Set GPIO bits" is for. (for what dongle that is)
Other than re-installing drivers and a power cycling PC, you could try connecting dongles via powered USB hub. A recent Win10 update caused people issues. Zadig was the answer in there case.
This issue seems less like SDRTrunk problem now. Hope you can get it backup and running.
AB9NN
Beulah, MI
I ran RTLTOOL and it did absolutely nothing. Played with it for some time, chose the dongle, selected pins, pressed test, etc.. Bits were 0 0 0 in the top right panel. So...
When the dongle is running with SDRTrunk on my old PC it tuns fine. The Tuners tab, after the tuner is selected, is populated with data and controls. On the new machine - that doesn't really happen. Therefore I suspect it is not hardware related since it does two different things on two different machines.
I have power cycled the new PC many times and changed ports with same results every time. I do have a powered USB hum and also tried directly plugged into the PC.
The ports on the new PC are USB 3 but they worked until the Windows 10 update and a Zadig re-install. Then things got funky.
Thanks for the smart, logical steps to try!
AB9NN
Beulah, MI
JMBE Build Fails - 3 incompatible and 1 stopped Daemons could not be reused,
Denny - I am following these steps: https://github.com/DSheirer/jmbe and my Java passes the tests.
When I CD to the correct folder and run the bat file it produces a jar file but it will not run.
The build process throws the following erroors:
C:\Users\jkres\Downloads\jmbe-0.3.3b\jmbe-0.3.3b>gradlew.bat build
Starting a Gradle Daemon, 3 incompatible and 1 stopped Daemons could not be reused, use --status for details
> Configure project :
Your finished JMBE library is here: C:\Users\jkres\Downloads\jmbe-0.3.3b\jmbe-0.3.3b\build/libs
BUILD SUCCESSFUL in 8s
7 actionable tasks: 2 executed, 5 up-to-date
C:\Users\jkres\Downloads\jmbe-0.3.3b\jmbe-0.3.3b>gradlew.bat --status
PID STATUS INFO
15764 IDLE 4.4
17580 STOPPED (by user or operating system)
15424 STOPPED (by user or operating system)
8052 STOPPED (by user or operating system)
Only Daemons for the current Gradle version are displayed. See https://docs.gradle.org/4.4/userguide/gradle_daemon.html#sec:status
Not sure how to proceed. Thanks.
DSheirer
Fulton, NY
You've built the JMBE library, so all you have to do now is copy that library file to the same folder as the sdrtrunk application and then launch the application.
Download the sdrtrunk release from the releases page, if you haven't already:
https://github.com/DSheirer/sdrtrunk/releases
Copy the JMBE library file that you just created to the same folder where you've downloaded the sdrtrunk application. The JMBE library file should be named: jmbe-0.3.3b.jar
Double-click the sdrtrunk application file, or in a console/terminal window change to the download folder and type:
java -jar (applicationfilename)
Denny
AB9NN
Beulah, MI
R820T Tuner Controller - couldn't apply the sample rate setting (2,400 MHz) USB error
Denny - thanks. The application throws the error:
R820T Tuner Controller - couldn't apply the sample rate setting (2,400 MHz) USB error 9: error writting byte buffer:pipe error
The application (SDRTrunk) starts and loads channels. The bottom right box of the Tuners tab, after I have clicked on a tuner, is grayed out except for "Please select a tuner". It will play no audio but I can see the signals on the waterfall and all other tabs seem normal.
The application files are direct copies from my old PC. The same RTLSDR dongle works fine with the same application (version, etc) on the old PC. I have examined all the tabs and don't see an adjustment I need to make are change. Here is the output of the command you gave me: I do see in the output dump the following: ".usb4java.LibUsbException". Some Java issue? I am running Java 10 and have it configured in Windows 10 the same, including folder locations, names, contents and Path and other Environment Variables as on the old PC.
C:\_Files\SDR - Software Defined Radio\sdrtrunk - 1st working version>java -jar sdr-trunk-all-0.3.4-beta.2.jar
07:26:27.261 INFO i.g.dsheirer.gui.SDRTrunk - ******************************************************************* [16MB/256MB 6%]
07:26:27.265 INFO i.g.dsheirer.gui.SDRTrunk - **** sdrtrunk: a trunked radio and digital decoding application *** [16MB/256MB 6%]
07:26:27.265 INFO i.g.dsheirer.gui.SDRTrunk - **** website: https://github.com/dsheirer/sdrtrunk *** [16MB/256MB 6%]
07:26:27.265 INFO i.g.dsheirer.gui.SDRTrunk - ******************************************************************* [16MB/256MB 6%]
07:26:27.265 INFO i.g.dsheirer.gui.SDRTrunk - Memory Logging Format: [Used/Allocated PercentUsed%] [16MB/256MB 6%]
07:26:27.265 INFO i.g.dsheirer.gui.SDRTrunk - Host CPU Cores: 16 [16MB/256MB 6%]
07:26:27.266 INFO i.g.dsheirer.gui.SDRTrunk - Host OS Name: Windows 10 [16MB/256MB 6%]
07:26:27.266 INFO i.g.dsheirer.gui.SDRTrunk - Host OS Arch: amd64 [16MB/256MB 6%]
07:26:27.266 INFO i.g.dsheirer.gui.SDRTrunk - Host OS Version: 10.0 [16MB/256MB 6%]
07:26:27.266 INFO i.g.dsheirer.gui.SDRTrunk - Host Max Java Memory: 3 GB [16MB/256MB 6%]
07:26:27.269 INFO i.g.d.util.ThreadPool - Application thread pool created with [16] threads [16MB/256MB 6%]
07:26:27.269 INFO i.g.dsheirer.gui.SDRTrunk - Home path: C:\Users\jkres\SDRTrunk [16MB/256MB 6%]
07:26:27.273 INFO i.g.d.p.SystemProperties - SystemProperties - loaded [C:\Users\jkres\SDRTrunk\SDRTrunk.properties] [16MB/256MB 6%]
07:26:27.273 INFO i.g.d.p.SystemProperties - SystemProperties - application properties loaded [C:\Users\jkres\SDRTrunk\SDRTrunk.properties] [16MB/256MB 6%]
07:26:27.281 INFO i.g.d.s.SettingsManager - SettingsManager - loading settings file [C:\Users\jkres\SDRTrunk\settings\settings.xml] [17MB/256MB 6%]
07:26:27.706 INFO i.g.d.s.m.MixerManager - loading system mixer devices
[LOADED] Output: Primary Sound Driver CHANNELS: [MONO, STEREO]
[LOADED] Output: Headphones (4- C-Media USB Audio Device ) CHANNELS: [MONO, STEREO]
[LOADED] Output: Desk Speakers (Realtek Audio) CHANNELS: [MONO, STEREO]
[LOADED] Output: CABLE Input (VB-Audio Virtual Cable) CHANNELS: [MONO, STEREO]
[LOADED] Input: Primary Sound Capture Driver CHANNELS: [LEFT, RIGHT, MONO]
[LOADED] Input: CABLE Output (VB-Audio Virtual CHANNELS: [LEFT, RIGHT, MONO]
[LOADED] Input: Microphone (4- C-Media USB Audi CHANNELS: [LEFT, RIGHT, MONO]
[10MB/256MB 3%]
07:26:27.708 INFO i.g.d.s.r.RecordingSourceManager - RecordingSourceManager - discovered [0] recording configurations [10MB/256MB 3%]
07:26:27.896 INFO i.g.d.s.t.TunerManager - LibUSB API Version: 16777474 [11MB/256MB 4%]
07:26:27.897 INFO i.g.d.s.t.TunerManager - LibUSB Version: 1.0.18.10866 [11MB/256MB 4%]
07:26:27.904 INFO i.g.d.s.t.TunerManager - discovered [14] attached USB devices [11MB/256MB 4%]
07:26:27.910 INFO i.g.d.s.t.TunerManager - usb device [413C:301A] NOT LOADED: Unknown Device [12MB/256MB 4%]
07:26:27.910 INFO i.g.d.s.t.TunerManager - usb device [0CF3:E007] NOT LOADED: Unknown Device [12MB/256MB 4%]
07:26:27.911 INFO i.g.d.s.t.TunerManager - usb device [413C:2113] NOT LOADED: Unknown Device [12MB/256MB 4%]
07:26:30.621 INFO i.g.d.s.t.TunerManager - usb device [0BDA:2838] LOADED: RTL2832 SDR/R820T 00000001 [12MB/256MB 4%]
07:26:30.622 INFO i.g.d.s.t.TunerManager - usb device [05E3:0610] NOT LOADED: Unknown Device [12MB/256MB 4%]
07:26:33.318 INFO i.g.d.s.t.TunerManager - usb device [0BDA:2838] LOADED: RTL2832 SDR/R820T VHF-001 [13MB/256MB 5%]
07:26:33.319 INFO i.g.d.s.t.TunerManager - usb device [0D8C:0008] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.320 INFO i.g.d.s.t.TunerManager - usb device [1022:145C] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.321 INFO i.g.d.s.t.TunerManager - usb device [413C:2113] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.321 INFO i.g.d.s.t.TunerManager - usb device [05E3:0610] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.322 INFO i.g.d.s.t.TunerManager - usb device [0764:0501] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.322 INFO i.g.d.s.t.TunerManager - usb device [1022:43B9] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.323 INFO i.g.d.s.t.TunerManager - usb device [05E3:0610] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.324 INFO i.g.d.s.t.TunerManager - usb device [0D8C:0008] NOT LOADED: Unknown Device [13MB/256MB 5%]
07:26:33.909 INFO i.g.d.icon.IconManager - loading icons file [C:\Users\jkres\SDRTrunk\settings\icons.xml] [30MB/256MB 11%]
07:26:34.106 INFO i.g.d.p.PlaylistManager - Attempting to load version 2 playlist file [C:\Users\jkres\SDRTrunk\playlist\playlist_v2.xml] [18MB/256MB 7%]
07:26:34.208 INFO i.g.dsheirer.gui.SDRTrunk - starting main application gui [46MB/256MB 17%]
07:26:45.802 INFO i.g.d.c.c.ChannelAutoStartFrame - Starting [3] now - timer invoked [125MB/256MB 48%]
07:26:45.812 ERROR i.g.d.s.t.r.RTL2832Tuner - couldn't provide source channel [126MB/256MB 49%]
at io.github.dsheirer.source.tuner.rtl.RTL2832TunerController.write(RTL2832TunerController.java:815)
at io.github.dsheirer.source.tuner.rtl.RTL2832TunerController.writeDemodRegister(RTL2832TunerController.java:711)
at io.github.dsheirer.source.tuner.rtl.RTL2832TunerController.enableI2CRepeater(RTL2832TunerController.java:615)
at io.github.dsheirer.source.tuner.rtl.r820t.R820TTunerController.setTunedFrequency(R820TTunerController.java:159)
at io.github.dsheirer.source.tuner.frequency.FrequencyController.setFrequency(FrequencyController.java:115)
at io.github.dsheirer.source.tuner.frequency.FrequencyController.setFrequency(FrequencyController.java:87)
at io.github.dsheirer.source.tuner.TunerController.updateLOFrequency(TunerController.java:337)
at io.github.dsheirer.source.tuner.TunerController.getChannel(TunerController.java:210)
at io.github.dsheirer.source.tuner.rtl.RTL2832Tuner.getChannel(RTL2832Tuner.java:116)
at io.github.dsheirer.source.tuner.TunerModel.getSource(TunerModel.java:304)
at io.github.dsheirer.source.SourceManager.getSource(SourceManager.java:78)
at io.github.dsheirer.controller.channel.ChannelProcessingManager.startProcessing(ChannelProcessingManager.java:213)
at io.github.dsheirer.controller.channel.ChannelProcessingManager.channelChanged(ChannelProcessingManager.java:158)
at io.github.dsheirer.controller.channel.ChannelAutoStartFrame.startChannels(ChannelAutoStartFrame.java:185)
at io.github.dsheirer.controller.channel.ChannelAutoStartFrame.access$400(ChannelAutoStartFrame.java:40)
at io.github.dsheirer.controller.channel.ChannelAutoStartFrame$CountdownTimer.run(ChannelAutoStartFrame.java:241)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:514)
at java.base/java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1135)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
at java.base/java.lang.Thread.run(Thread.java:844)
07:26:45.814 INFO i.g.d.s.tuner.TunerModel - Unable to source channel [853962500] from preferred tuner [RTL2832 SDR/R820T VHF-001] - searching for another tuner [126MB/256MB 49%]
07:26:45.817 ERROR i.g.d.s.t.r.RTL2832Tuner - couldn't provide source channel [126MB/256MB 49%]
at io.github.dsheirer.source.tuner.TunerModel.getSource(TunerModel.java:327)
07:26:45.821 ERROR i.g.d.s.t.r.RTL2832Tuner - couldn't provide source channel [127MB/256MB 49%]
07:26:45.881 INFO i.g.d.m.d.p.a.P25AudioModule - JMBE audio conversion library [JMBE Audio Conversion Library v0.3.3] successfully loaded - P25 audio will be available [136MB/256MB 53%]
DSheirer
Fulton, NY
It looks like your JMBE library loaded successfully, so that issue is resolved.
The second issue is your tuner. Does this tuner work ok with other SDR applications like SDR#?
The error indicates that sdrtrunk is trying to set the center frequency and the USB software (libusb) is throwing an error that it can't communicate with the tuner.
If the driver is installed correctly, you may want to try unplugging the tuner and replugging to reset the device.
Denny
AB9NN
Beulah, MI
It does start and play audio with work ok with other SDR applications like SDR#. It is a little funky and used to work nearly perfectly (heat issues, etc excepted). When I re-tune I have to stop and re-start the software, and then it is good.
I suspect driver but did unplug and re-plug. When I re-install driver with Zadig.exe it doesn't find the same driver that it used to find. Is there a way to manually install it or otherwise place it where it can be found?
DSheirer
Fulton, NY
I only have a limited working knowledge of Zadig driver installs ... maybe someone else here can provide help?
thewraith2008
What dongles do you use? Image if possible.
Are you using a precompiled version of SDRTrunk (I don't mean the JMBE) or did you compile it yourself?
Do these dongles work without issue in old PC with SDR# and SDRTrunk. (ie. If you tested them right now, not in the past). Do you still have it to test with?
Do these dongles work without issue in new PC with SDR#. Or does the quote above apply. "issues when changing frequencies".
Not a good sign.
Looking at the log you posted and all the USB devices (just a quick lookup):
Mouse, Bluetooth, WiFi?, USB hub, USB audio dongle, USB controller, Wifi dongle?, USB Hub, UPS, USB Controller, USB controller, USB audio dongle.
Are you running Windows 10 and your SDR stuff (SDRTrunk, SDR#) in a VM?
Are your dongles connected to that host?
If yes then this is going to complicate things. Especially with all those USB devices.
If you are not, try and test by removing some if not all of those attached devices. There is a high probability that there is a conflict going on there.
Anyway, just something else to think about.
AB9NN
Beulah, MI
Substantial Progress!
The VHF RTLSDR seems to be working nicely with the software - albeit no audio yet... The HF RTLSDR with SpyVerter is still in the old error state.
No audio heard yet, but for the VHF radio the error that was being thrown is gone and the bottom right section of the Tuners tab is now populated and functional! It "looks like it is working fine", although I have heard no audio out from it yet. Maybe a slow day or may need to select another input or may be additional issues. I will continue to monitor and tweek and get back here if issues remain.
What I did and what helpd:
Yes - this is a Windows 10 PC. Just a straight boot but it is a gaming PC with 16 processors. VM - unsure but I don't think so. Not sure how to check that.
I pulled all USB devices out and found I no longer had a mouse and keyboard functioning. Plugged them back in. Mouse worked. Not keyboard. Decided to reboot. No way to input password. DUH! But - AHA! The machine has USB ports and front and back of machine. All are USB 3 high speed. Pulled keyboard from front port and plugged into backend port. Bingo! Keyboard restored. Logged in.
Decided if that worked for keyboard - maybe the same for RTLSDR? Sure enough! To be fair, I had had several issues that I cleared over the past few days with JAVA - multiple versions, etc..
I will continue to monitor and tweak - than you!!!
AB9NN
Beulah, MI
Denny - I have seen some blue CALL activity being decoded but have heard no audio. I have exhausted all audio connection experimentation.
I did notice - in the Audio Panel - there is no speaker icon. Rather, there is a dot. If I click that an M (muted probably) appears on the right for the two sides of audio - right and left. That makes me wonder if there is some application issue, etc.. What can I try next?
thewraith2008
Do you get system audio in Windows 10.
Can you play a video or music file OK.
If you adjust volume slider do you get a sound?
Are all the mixer level set OK, nothing to low or muted?
If no sound, right click speaker on system tray and select "Playback devices" and see what the default device is.
If you do get sound, do you still get something like this show in your SDRTrunk log?
[10MB/256MB 3%]
I get the same in sdrtrunk_0.3.4b1. It's only a visual thing.
If you setup a analog channel in SDRTunk, say a AM ATIS from your local airport, do you hear anything?
AB9NN
Beulah, MI
Denny - long replies below, but after doing that documentation I read what I thought was your signature on your e-mail. Looked like another question. That provided progress:
I set-up a channel tuned to an NBFM station (118.325) and I do get audio. It is distorted but I can hear the modulated signal barely. On SDR# it is stronger.
The rest of my replies follow. I "presume" that this sheds some light on the issue? Feeling like my hope is slowly climbing a long hill but is getting there! chuckle...
Reminds me a bit of my ski racing training days...
Denny - My replies to your thoughtful diagnosis questioning follows. On the first section I have the answer in front of the question. Summary - audio works great for everything else. Settings seem fine.
In For your last question about log issues, I have copied in the complete run log from CMD. I have left blank lines as start and stop points for sections of interest.
I have also provided a play-by-play review of my audio Windows 10 check-off when issues arrive.
Before all of that however, after reading the CMD output I found the following file:
- sdrtrunk_app.log
and it had the following line of note:
20180626 094518.153 [main] INFO i.g.d.s.mixer.MixerManager - loading system mixer devices
[LOADED] Output: Speakers (5- C-Media USB Audio Device ) CHANNELS: [MONO, STEREO]
[LOADED] Input: Microphone (5- C-Media USB Audi CHANNELS: [LEFT, RIGHT, MONO]
[10MB/256MB 4%]
I am presuming it loaded what it needed but I am not aware of anything missing that maybe should be there that could indicate an error.
Here are the answers to the questions, etc:
Yes - Do you get system audio in Windows 10.
Yes - Can you play a video or music file OK.
Yes - If you adjust volume slider do you get a sound?
Yes - Are all the mixer level set OK, nothing to low or muted?
N/A - If no sound, right click speaker on system tray and select "Playback devices" and see what the default device is.
[10MB/256MB 3%]
When I start SDRTrunk I configure the Audio Panel as follows:
- I select the desk speakers on both the left and Right channels
- I adjust the volume on LEFT and RIGHT on both the left and right channels to 75
- These adjustments used to work well on the old computer
- In the Windows 10 System Tray I set the audio output on t the speaker icon to desk speakers and set the volum midway up
- In Control Palen - SOUND - I set Desk Speakers as DEFAULT and set LEVELS in PROPERTIES at 44 which is LOUD
- Mike is at 0
- Line in is muted (audio works for all other apps)
- Side is at 100
- Center is at 100
- Advanced Tab - Default Format = 24 bit 48000 Hz (Studio Quality)
- Exclusive mode is unchecked all boxes
- Special sound is all OFF and unchecked
My start log follows - could find no other log "file" being produced:
C:\Users\jkres\OneDrive\Desktop\RADIo_Old_PC>cd \_Files\SDR - Software Defined Radio\sdrtrunk - 1st working version
09:45:17.677 INFO i.g.dsheirer.gui.SDRTrunk - ******************************************************************* [16MB/256MB 6%]
09:45:17.686 INFO i.g.dsheirer.gui.SDRTrunk - **** sdrtrunk: a trunked radio and digital decoding application *** [16MB/256MB 6%]
09:45:17.688 INFO i.g.dsheirer.gui.SDRTrunk - **** website: https://github.com/dsheirer/sdrtrunk *** [16MB/256MB 6%]
09:45:17.688 INFO i.g.dsheirer.gui.SDRTrunk - ******************************************************************* [16MB/256MB 6%]
09:45:17.689 INFO i.g.dsheirer.gui.SDRTrunk - Memory Logging Format: [Used/Allocated PercentUsed%] [16MB/256MB 6%]
09:45:17.690 INFO i.g.dsheirer.gui.SDRTrunk - Host CPU Cores: 16 [16MB/256MB 6%]
09:45:17.690 INFO i.g.dsheirer.gui.SDRTrunk - Host OS Name: Windows 10 [16MB/256MB 6%]
09:45:17.690 INFO i.g.dsheirer.gui.SDRTrunk - Host OS Arch: amd64 [16MB/256MB 6%]
09:45:17.690 INFO i.g.dsheirer.gui.SDRTrunk - Host OS Version: 10.0 [16MB/256MB 6%]
09:45:17.690 INFO i.g.dsheirer.gui.SDRTrunk - Host Max Java Memory: 3 GB [16MB/256MB 6%]
09:45:17.692 INFO i.g.d.util.ThreadPool - Application thread pool created with [16] threads [16MB/256MB 6%]
09:45:17.693 INFO i.g.dsheirer.gui.SDRTrunk - Home path: C:\Users\jkres\SDRTrunk [16MB/256MB 6%]
09:45:17.697 INFO i.g.d.p.SystemProperties - SystemProperties - loaded [C:\Users\jkres\SDRTrunk\SDRTrunk.properties] [16MB/256MB 6%]
09:45:17.699 INFO i.g.d.p.SystemProperties - SystemProperties - application properties loaded [C:\Users\jkres\SDRTrunk\SDRTrunk.properties] [16MB/256MB 6%]
09:45:17.711 INFO i.g.d.s.SettingsManager - SettingsManager - loading settings file [C:\Users\jkres\SDRTrunk\settings\settings.xml] [17MB/256MB 7%]
09:45:18.153 INFO i.g.d.s.m.MixerManager - loading system mixer devices
[10MB/256MB 4%]
09:45:18.154 INFO i.g.d.s.r.RecordingSourceManager - RecordingSourceManager - discovered [0] recording configurations [10MB/256MB 4%]
09:45:18.418 INFO i.g.d.s.t.TunerManager - LibUSB API Version: 16777474 [12MB/256MB 4%]
09:45:18.419 INFO i.g.d.s.t.TunerManager - LibUSB Version: 1.0.18.10866 [12MB/256MB 4%]
09:45:18.433 INFO i.g.d.s.t.TunerManager - discovered [15] attached USB devices [12MB/256MB 4%]
09:45:18.438 INFO i.g.d.s.t.TunerManager - usb device [0D8C:0008] NOT LOADED: Unknown Device [12MB/256MB 4%]
09:45:18.439 INFO i.g.d.s.t.TunerManager - usb device [0CF3:E007] NOT LOADED: Unknown Device [12MB/256MB 4%]
09:45:18.440 INFO i.g.d.s.t.TunerManager - usb device [05E3:0617] NOT LOADED: Unknown Device [12MB/256MB 4%]
09:45:18.440 INFO i.g.d.s.t.TunerManager - usb device [05E3:0610] NOT LOADED: Unknown Device [12MB/256MB 4%]
09:45:18.441 INFO i.g.d.s.t.TunerManager - usb device [413C:2113] NOT LOADED: Unknown Device [12MB/256MB 4%]
09:45:21.150 INFO i.g.d.s.t.TunerManager - usb device [0BDA:2838] LOADED: RTL2832 SDR/R820T 00000001 [13MB/256MB 5%]
09:45:21.151 INFO i.g.d.s.t.TunerManager - usb device [0D8C:0008] NOT LOADED: Unknown Device [13MB/256MB 5%]
09:45:22.688 INFO i.g.d.s.t.TunerManager - usb device [0BDA:2838] LOADED: RTL2832 SDR/R820T VHF-001 [13MB/256MB 5%]
09:45:22.689 INFO i.g.d.s.t.TunerManager - usb device [1022:145C] NOT LOADED: Unknown Device [13MB/256MB 5%]
09:45:22.690 INFO i.g.d.s.t.TunerManager - usb device [05E3:0617] NOT LOADED: Unknown Device [13MB/256MB 5%]
09:45:22.691 INFO i.g.d.s.t.TunerManager - usb device [413C:301A] NOT LOADED: Unknown Device [13MB/256MB 5%]
09:45:22.691 INFO i.g.d.s.t.TunerManager - usb device [413C:2113] NOT LOADED: Unknown Device [13MB/256MB 5%]
09:45:22.692 INFO i.g.d.s.t.TunerManager - usb device [05E3:0610] NOT LOADED: Unknown Device [13MB/256MB 5%]
09:45:22.693 INFO i.g.d.s.t.TunerManager - usb device [0764:0501] NOT LOADED: Unknown Device [13MB/256MB 5%]
09:45:22.693 INFO i.g.d.s.t.TunerManager - usb device [1022:43B9] NOT LOADED: Unknown Device [13MB/256MB 5%]
09:45:24.616 INFO i.g.d.icon.IconManager - loading icons file [C:\Users\jkres\SDRTrunk\settings\icons.xml] [30MB/256MB 11%]
09:45:25.110 INFO i.g.d.p.PlaylistManager - Attempting to load version 2 playlist file [C:\Users\jkres\SDRTrunk\playlist\playlist_v2.xml] [19MB/256MB 7%]
09:45:25.321 INFO i.g.dsheirer.gui.SDRTrunk - starting main application gui [47MB/256MB 18%]
09:45:37.212 INFO i.g.d.c.c.ChannelAutoStartFrame - Starting [3] now - timer invoked [144MB/256MB 56%]
09:45:37.320 INFO i.g.d.m.d.p.a.P25AudioModule - JMBE audio conversion library [JMBE Audio Conversion Library v0.3.3] successfully loaded - P25 audio will be available [155MB/256MB 60%]
09:46:04.559 ERROR i.g.d.s.t.r.RTL2832Tuner - couldn't provide source channel [124MB/308MB 40%]
at io.github.dsheirer.controller.channel.ChannelModel.broadcast(ChannelModel.java:152)
at io.github.dsheirer.channel.traffic.TrafficChannelManager.process(TrafficChannelManager.java:208)
at io.github.dsheirer.channel.traffic.TrafficChannelManager.access$000(TrafficChannelManager.java:48)
at io.github.dsheirer.channel.traffic.TrafficChannelManager$DecoderStateEventListener.receive(TrafficChannelManager.java:395)
at io.github.dsheirer.channel.traffic.TrafficChannelManager$DecoderStateEventListener.receive(TrafficChannelManager.java:387)
at io.github.dsheirer.sample.Broadcaster.broadcast(Broadcaster.java:83)
at io.github.dsheirer.sample.Broadcaster.receive(Broadcaster.java:33)
at io.github.dsheirer.channel.state.DecoderState.broadcast(DecoderState.java:148)
at io.github.dsheirer.module.decode.p25.P25DecoderState.processTSBKChannelGrant(P25DecoderState.java:2944)
at io.github.dsheirer.module.decode.p25.P25DecoderState.processTSBK(P25DecoderState.java:1559)
at io.github.dsheirer.module.decode.p25.P25DecoderState.receive(P25DecoderState.java:372)
at io.github.dsheirer.module.decode.p25.P25DecoderState.receive(P25DecoderState.java:147)
at io.github.dsheirer.module.decode.Decoder$MessageDistributor.receive(Decoder.java:87)
at io.github.dsheirer.module.decode.Decoder$MessageDistributor.receive(Decoder.java:80)
at io.github.dsheirer.module.decode.p25.P25MessageProcessor.receive(P25MessageProcessor.java:76)
at io.github.dsheirer.module.decode.p25.P25MessageProcessor.receive(P25MessageProcessor.java:14)
at io.github.dsheirer.module.decode.p25.P25MessageFramer.dispatch(P25MessageFramer.java:168)
at io.github.dsheirer.module.decode.p25.P25MessageFramer.access$300(P25MessageFramer.java:40)
at io.github.dsheirer.module.decode.p25.P25MessageFramer$P25MessageAssembler.checkComplete(P25MessageFramer.java:596)
at io.github.dsheirer.module.decode.p25.P25MessageFramer$P25MessageAssembler.receive(P25MessageFramer.java:244)
at io.github.dsheirer.module.decode.p25.P25MessageFramer.receive(P25MessageFramer.java:179)
at io.github.dsheirer.module.decode.p25.P25MessageFramer.receive(P25MessageFramer.java:40)
at io.github.dsheirer.dsp.psk.DQPSKDemodulator.calculateSymbol(DQPSKDemodulator.java:134)
at io.github.dsheirer.dsp.psk.DQPSKDemodulator.receive(DQPSKDemodulator.java:92)
at io.github.dsheirer.dsp.psk.DQPSKDemodulator.receive(DQPSKDemodulator.java:68)
at io.github.dsheirer.module.decode.p25.P25_C4FMDecoder.receive(P25_C4FMDecoder.java:85)
at io.github.dsheirer.module.decode.p25.P25_C4FMDecoder.receive(P25_C4FMDecoder.java:38)
at io.github.dsheirer.dsp.filter.halfband.complex.HalfBandFilter_CB_CB.receive(HalfBandFilter_CB_CB.java:102)
at io.github.dsheirer.dsp.filter.halfband.complex.HalfBandFilter_CB_CB.receive(HalfBandFilter_CB_CB.java:7)
at io.github.dsheirer.sample.complex.ComplexToComplexBufferAssembler.receive(ComplexToComplexBufferAssembler.java:61)
at io.github.dsheirer.dsp.filter.cic.ComplexPrimeCICDecimate$Output.receive(ComplexPrimeCICDecimate.java:393)
at io.github.dsheirer.sample.decimator.ComplexDecimator.receive(ComplexDecimator.java:45)
at io.github.dsheirer.dsp.filter.cic.ComplexPrimeCICDecimate$Stage.receive(ComplexPrimeCICDecimate.java:309)
at io.github.dsheirer.dsp.filter.cic.ComplexPrimeCICDecimate$DecimatingStage.receive(ComplexPrimeCICDecimate.java:242)
at io.github.dsheirer.dsp.filter.cic.ComplexPrimeCICDecimate$TwoStage.receive(ComplexPrimeCICDecimate.java:342)
at io.github.dsheirer.dsp.filter.cic.ComplexPrimeCICDecimate.receive(ComplexPrimeCICDecimate.java:177)
at io.github.dsheirer.source.tuner.TunerChannelSource$DecimationProcessor.run(TunerChannelSource.java:544)
09:46:04.611 ERROR i.g.d.s.t.r.RTL2832Tuner - couldn't provide source channel [135MB/308MB 44%]
thewraith2008
It's also a possibility that the call is occurring outside of the spectrum pool.
eg. If pool is from 450-452.4 MHz and CC is on 451 MHz, then a call occurs on 453 MHz.
CC is OK because it is within 450-452.4 MHz, but VC is outside that range at 453.
Because you only have one tuner that works, it is unable to tune to VC to decode voice.
What I get from what you are saying is that other USB devices where causing a conflict with the dongles.
You got one working as normal but the other is not tuning.
Audio in OS and SDRTrunk (because of the analog test channel.) are OK
There is the possibility that the one dongle with channel tuning issue is bad.
This is why I asked in follow post to try and rule that out.
The "old PC" could also be, do they work in another PC without issue.
You do seem close to resolving this issue, but I believe all problems here now, revolve around hardware and not software. I could be wrong though :)
To help with your post formatting. BBCode formatting
Just to clarify DSheirer = Denny
AB9NN
Beulah, MI
Thanks! To your points...
- Great thought, but don't think so. Hardware worked fine on old PC but with some re-tuning issues.
Can't rule-out hardware issues, and it's been some time since I've had the speakers plugged-in on
the old PC. Will try that. Might be that now that the basic functionality is restored on new PC both
new and old are at same functionality. I will do additional testing once Michigan storms clear.
- I guess for $30 or so (having spare ports on new PC) I maybe can try a new dongle and see.
Agree - does seem close to resolution. I am re-reading the set-up of the audio / identifiers. A couple of more questions:
- Once started I get static on the waterfalll although the waterfall does work. Once I click on TUNERS and then MAIN the waterfall shows what seems to be a good radio signal populated waterfall. Seems I didn't have to do that click before... may be mistaken.
- If I have the following output from the software, what frequency should I have set-up as a channel?
I have 853.962500 and 853.87500 and 854.98750 and I am in NW Lower MI.
Activity Summary - Decoder:p25 Normal (C4FM)
SITE NAC:796h WACN:92493h SYS:796h [WPIH50] LRA:00h RFSS-SITE:04-1Eh
SERVICES: CONTROL CHAN[ ] SERVICES[ DATA REGISTRATION VOICE ]
PCCH DOWNLINK 853.962500 [0-473] UPLINK 808.962500 [0-473]
SCCH DOWNLINK 853.462500 [0-393] UPLINK 808.462500 [0-393] SCCH 2 DOWNLINK 853.462500 [0-393] UPLINK 808.462500 [0-393]
SNDCP DOWNLINK 0.000000 [15-4095] UPLINK 0.000000 [15-4095]
FREQUENCY BANDS:
ID:0 BASE:851006250 BANDWIDTH:12500 SPACING:6250 OFFSET:-45000000
thewraith2008
Yes, but it doesn't on the new PC. You have 1 tuner functioning. You need to look at call activity to see if this is happening.
Can't rule-out hardware issues, and it's been some time since I've had the speakers plugged-in on the old PC.
What? I was talking about testing your RTL dongles on another PC.
Your choice, but there are things you can test out before doing that
Maybe a screenshot of this may help.
FREQUENCY BANDS:
I don't use P25 so I'll leave that to someone else.
