gmclam was going in the right direction above (radio locks onto control channel/"park there")
Ubbe could tell you the exact time it "parks", but basically, your radio only has one tuner.
It "parks" on a control channel and listens for X milliseconds.
If it 'hears' a channel grant, it tunes to that freq. and you hear the traffic.
The radio is tuned to that freq until the transmission is ended, or you have set it to a neg delay.
If, after X milliseconds it hears no channel grants, it moves on.
Whatever the freq of the next control channel is, it just tunes and listens.
So..... it shouldn't matter if you are scanning 800 then 170.
If everything is set up properly, (antenna that is capable of both, all programming, etc correct), it shouldn't make any difference.
It is important to note here that being aware of how many SITES you have programmed, (and how they are programmed) is also real important.
The radio will go to each SITE you have programmed and "park" on it, for X milliseconds, listening.
Looking for a control channel, then "parking". Or, scanning all programmed freq for a control channel, for X milliseconds.
Also, location control can and does effect all of this. Set incorrectly or used improperly, it can certainly throw a wrench into the works.
