[SDS100 Antennas] Remtronix 843S vs 920S vs Stock: RSSI champ vs audio champ—why?
Trilliumaire
Evergreen, CO
On my SDS100, the Remtronix 843S consistently shows higher RSSI on steady carriers/tones, but the Remtronix 920S consistently produces clearer voice on ~800 MHz P25. Looking for explanations and best practices to measure this properly.
Currently in an "RF Disadvantaged" area in the mountains but near-ish to Denver, but no line of sight. HD TV antennas don't even work here. :ROFLMAO:
I used the SDS100 in "Search with Scan" set. Once I found a lock, I swapped between the 3 antennas: Stock, 920S, and Remtronix 843S.
The 843S is expected to be the best all-around, an the 920S is expected to better at ~800 MHz.
What I found is that the 843S had better RSSI on what appeared to be unmodulated CW tones as I scanned, across everything. But when scanning on modulated signals, say around 800 MHz, the 920S did better at pulling in more conversations clearly.
So what are your thoughts on CW tone / carrier RSSI measurements vs. real-world modulated signal experiences with different antennas?
My theory is that the 843S is letting in more junk, so the RSSI is higher, but the 920S acts as a filter, increases SNR, but reduces RSSI.
trentbob
W3BUX- Bucks County, PA
Well the 920s is the old original Radio Shack RS 800 that was made by GRE and now REM. That has very high gain on 7-800 MHz, you're going to have less errors on simulcast systems and it's going to sound better. Better audio and modulation.
REM has made three versions BNC, SMA and SMA 100 and they are all going to perform the same. The sma100 has the O-ring to maintain the Integrity of the water resistance in the radio but doesn't affect reception. It's tuned for 7-800 MHz. It does okay on UHF but not so much on VHF High, very compromised reception, it'll pick stuff up but it's not optimal in VHF High.
The other antenna coverage is VHF High, UHF and 7- 800 MHz. There might be some fluctuation in your reception but it's wide coverage.
If you are in an RF challenged area, you very well might be letting in more junk.
Not sure what you listen to on a regular basis but there are more ways to judge reception than RSSI. Sometimes a better RSSI can simply be because of a noisier environment.
If you're listening to simulcast systems, a good indicator for reception on simulcast systems like a phase 2 tdma simulcast system your best indicators are error rate and noise.
I'm being basic here but really good reception is going to give you better audio and modulation, scratchy noisy analog frequencies that are not coming in well are going to provide terrible audio.
The audio itself on the SDS-100 has always been a bone of contention, some people like it and some people don't. Personally I think it sounds good but some say the speaker is too small and it sounds tintty.
AB4BF
EM93cs
Several years ago, I ordered a Comet antenna for my Wouxun HT and received a scanner antenna by mistake. It is a Comet SMA-W100RX, SMA-P, 25-1300MHz Scanner Antenna. Would something like this work on your SDS-100? It is an SMA male, 986 mm long double jointed, black, extendable, 200 mm when closed.
Trilliumaire
Evergreen, CO
Since I need a measurement close to Eb/No or SNR, I found that on the SDS100 you can go into the "Customize" menu in the display and add "D-ERROR", which is a bit error rate for digital comms, presumably from the FEC applied to the transmission. If we get in the lower SNR/(Eb/No) regime, I would be able to see this measurement directly (since the FEC would kick in), and get a more rigorous measurement of the performance of these different antennas, without relying on some vague RSSI value.
I also enabled the "NOISE" measurement on the SDS100.
Between these two, I should get a serious delta comparison of these various antennas, at least in the parts of the spectrum these digital signals live.
trentbob
I've noticed that normal SMA antennas not made for Chinese radios sometimes do work on the proprietary recessed antenna connection and sometimes they don't.. they don't go deep enough to make a connection. Chinese radios use the reverse SMA don't they?
For example, my go to antenna for my SDS 100 is the Watson w 801 which is impossible to find now and if you do it's out of stock but it's an excellent all around antenna with very good 7-800 reception and very good VHF High and UHF but the SMA model does not fit and does not make contact so I use the BNC with the adapter. It's a normal SMA connection not the reverse SMA that you would use on a Chinese radio, it just doesn't go deep enough to make contact.
If you're lucky enough to get a knowledgeable vendor they may be able to tell you or maybe somebody here will know but there's really no way to know which normal SMA is going to work or not.. any REM SMA connection will work even if it doesn't have the O-ring to maintain the radios water resistance.
It's almost as if you have to try it to know.. Maybe a more knowledgeable member will have that answer
Trilliumaire
Evergreen, CO
It might, but I really want to compare the deltas in performance, across whatever antenna I plug in.
So without getting other equipment, like a spectrum analyzer, and digging in hard into the guts of the SDS100, I just wanted a simple way to measure the performance across antennas directly on the device, without too much hassle.
I may have found a way, maybe. Not sure what the scanner community does for this as a general rule.
I am new to scanners, but not new to RF/Antennas or DSP/Comms.
trentbob
So the first picture is the SMA connection that will fit a SDS 100 providing the water resistance. Notice the extension that allows it to go deeper into the mounting portal.
This is the SMA connection for an antenna used on a Chinese radio and as you can see it would not work on an SDS 100.
Trilliumaire
Evergreen, CO
Yes, that definitely won't work with Uniden (Yuniden Hôrudingusu) ...
A Japanese company making SDS100's out of [mostly] Vietnam. :ROFLMAO:
Ubbe
Stockholm, Sweden
D-error for digital and Noise for analog transmissions but it treats any modulation as noise so must be quiet when reading the value, like when a repeater have a few seconds of hang time after a transmission ends. FEC are disabled during transmissions using Motorola RAS, as the scanner cannot handle the RAS key, but D-error measurements still works properly. But it is said that RAS only needs to disable FEC on voice frames in the scanner and other data frames can still be using FEC, so your assumption might still be correct.
/Ubbe
Trilliumaire
Evergreen, CO
I hear ya ...
I bought the waterfall unlock (only $20), I think this might be the best way to get an SNR estimate, vs. D-ERROR or any other metric,
Basically eyeball the peak level to the noise floor for the SNR estimate across antennas and try to notice a difference.
Trilliumaire
Evergreen, CO
I had some time today to do the SDS100 SNR measurements comparing these three antennas: Remtronix 843S, Remtronix 920S, and Stock Antenna.
Setup: Using the Waterfall unlock on the SDS100 ($20 from Uniden), FFT taking the full screen (no waterfall), and found what appears to be a steady narrowband signal. Same Span and front end filters throughout. Waited 30 seconds for things to settle after swapping antennas. Set Max Hold for 3 seconds (rolling), to reduce noise in the FFT bins.
At 800 MHz (for P25, my main focus):
Remtronix 843S:
Remtronix 920S
Stock:
Honestly, I can't really see a huge difference in the 920S or the 843S.
¯\_(ツ)_/¯
But both appear to be better than Stock.
So since the 920S is waterproof, I will use this when outside, and since the 843S has the elbow (0, 45, 90 degrees), good for getting a good V polarization when on a mount driving around, BUT NOT WATERPROOF, I will use this for indoors only or driving around.
The stock antenna serves as a weatherproof backup/spare.
Bottom line, I think this is the best way to measure the SNR variation in the SDS100 across different antennas. I tried doing a similar measurement around 150 MHz, and I believe the 843S did slightly better there, but it was a NOAA weather signal and kept bouncing around, so hard to tell. But both the Remtronix antennas were better than stock at 150 MHz too.
trentbob
Remtronix 843S:
Remtronix 920S
Stock:
¯\_(ツ)_/¯
Yes the stock is not a great performer, but provides the water resistance, it's not worth the trade LOL
I guess if I had to pick the prime range I would guess it's probably best on VHF high but it is an underperformer. Water resistance doesn't matter to me. I'm not going out in the rain with it, forget the radio, I don't want to get wet.
By the way the water resistance part came from Uniden deciding rather build a new chassis, they used one of their existing chassis from a marine radio. Hence, water resistant antenna. Also created the "nip it in the bud" campaign which resulted in the big butt battery but that's a different story for a different thread.
Trilliumaire
Evergreen, CO
I probably won't intentionally go out in the rain with it. But when out hiking, overlanding, setting up camp or whatnot, it's easy to get caught in storms, so I need a basic IPX rating, including the antenna (unpredictable mountain weather).
The next layer of optimization is seeing if I can reduce EMI as much as possible by attaching ferrite beads to the cables. The SDS100 has the 3.5mm headphone jack, and I have Bluetooth headphones. I had a 3.5mm to BT dongle sitting next to the SDS100 antenna, an inch away, and felt bad because I am probably freaking out the front-end somewhat.
So I Frankensteined a setup to have a longer 3.5mm cable go from the headphone jack, and AWAY from the antenna (at least 1-2 ft, so the BT dongle isn't screaming into the SDS100 front-end). Then I added a little coin sized mixer to send Scanner Radio feeds from my iPhone on Port A, and the SDS100 to Port B, all mixed into my wireless headphones (from the same dongle!). And with reduced EMI (hopefully). But this is another thread. :ROFLMAO:
trentbob
What do you think of the volume output from the earphone jack? Very low, supposedly to protect the customers ears. In the car, in the cup holder, paired with my Larson triband, I found that the speaker on the radio was actually louder than an amplified speaker connected to the earphone jack.
Trilliumaire
Evergreen, CO
I mostly wear these open ear headphones (Shockz OpenRun Pro 2).
They are bone conducting, but I turn that off and just use the little speakers. They don't actually go into the ear canal. Having said that, the SDS100 is plenty loud from the jack! I can hear what is around me, and what comes from the scanner and the iPhone at the same time.
For listening without a lot going on around me, I set the SDS100 to a volume of 7 with these. If it's noisy, I might go up to 12. But never really go to 15 with these. The only time I go with 15 is when using the SDS100 speaker when outside ... but the speaker on the SDS100 is pretty weak anyway. But no probs with the headphone jack. If you do covered headphones, and with noise cancelling, the headphone jack is even better than the open air Shokz.
For a "big blast" I hook the SDS100 to my Makita speaker. It will go as loud as you want! Just get a beefy external speaker with a 3.5mm line in jack. It will blow away the car stereo, no problem, and piss off your wife too! :ROFLMAO:
