Sds100 belt clip
RandyKuff
Lorain, Ohio
And how is that clip going to replace the SDS100's... That looks like a one piece design that uses the two screws to mount it...
firebell9137
RandyKuff
Lorain, Ohio
That belt clip only mounts with those 2 screws... No place on the scanner to do that...
If your talking about using just the top hole to do that... I would not trust that... For one you will loose any swival capability...
I can also see that snapping with pressure on it...
firebell9137
I dont want swivel in the first place.
I was gonna use middle top hole in the belt clip.
I guess not. Any more suggestions?
RandyKuff
Lorain, Ohio
When it falls and hit the concrete from 3’ in the air, you will wish you had bought a case with a clip instead of some duct tape solution.
Plus the SDS's belt clip has a loop on the bottom so as not to slip off of your belt...
firebell9137
I only saw cases without belt clips on the scanner websites. The one i have will let me use the belt clip on the scanner because it's open in the back hooks on to the antenna.
emscapt9816
Retired, but somehow working harder now...
Coconut Creek, FL
firebell9137
