SDS100/SDS200: SDS100 Noob help
Jenni5637
DUKE CENTER, PA
I am new to scanners and got an SDS100 for xmas. Way more than I probably need but not sure. I am not sure if I need Pro voice/DMR/NDX to get it working properly. I am located in Duke Center PA. I have loaded McKean 42 into the scanner with sentinel and there are times it stops on a channel and I see Data/Link on the screen but no sound. This is a very rural area and I am not sure if I possibly need a better antenna or something else. Any help or guidance is appreciated. I have looked for tutorial on the SDS100 but have not found anything too helpful except using sentinel. Are there any good tutorial out there?
Thank you in advance.
dave3825
Suffolk County NY
Your counties main page does not show any DMR, NXDN or Provoice, the 3 digital upgrades.
In trunked systems, this is what's listed with only one being NXDN. If nothing on that system is of any interest to you, then you do not need any of those 3 upgrades.
FCI Mckean P25Project 25 Phase IIBradford
Federal Correctional Institution McKeanMotorola Type II SmartnetBradford
Industrial Electronics (448)NXDN NEXEDGE 9600Regional
PA-STARNet: Pennsylvania Statewide Radio NetworkProject 25 Phase IIStatewide
There could be DMR and NXDN in use in your county that nobody has submitted to the database. There could be NXDN, DMR Provoice in use in your surrounding counties.
You should take a look at your county and the surrounding counties to see if anything of interest stands out.
You should also connect your scanner to Sentinel and read it, then update master database and write back to the scanner so if your using the zip code feature, the scanner has the most current data.
Jenni5637
DUKE CENTER, PA
Thanks Dave. I'm thinking I may need a better antenna then. I have wrote back the full database to the scanner also. I have tried the zip code feature but all I have heard is catt county NY because I am close to that area.
Whiskey3JMC
Chimer Inner
Out of Area 🇺🇸
I take it you mean these?
You'll need to turn on the Fire-Tac & Fire-Talk service types to bring in your county's fire talkgroups (see "Tag" column in the RRDB) These two service types are not enabled by default. Also keep in mind your law enforcement is fully encrypted as are PSP (mode "TE") so you won't be able to track them. This is probably what you're coming across when you describe it stopping on a channel but hearing no sound so it'd be best to permanent avoid law enforcement talkgroups. Welcome to the forums!
ce2576
Cleburne, TX
Looks like ALL law enforcement in your county (including state police) are encrypted. Note that the TG's for law enforcement are listed as TE. The 'E' meaning encrypted
That's likely why you are not hearing anything. Fire/EMS in your area is in the clear, presuming nothing has changed in that regard since the database was last updated for your area
There is one NXDN system in your area: Industrial Electronics (448)
On the DMR side, this system is being used in parts of PA: Mid-Atlantic Digital Radio Network.
Don't waste your money on ProVoice. Quote from another thread regarding ProVoice: "It's an outdated radio system type. I think there are less than 2 dozen systems nationwide."
tvengr
Well Known Member
Baltimore County, MD
Please attach your favorites list file so we can take a look at it to check for errors. In Sentinel, click on the File tab and Export to hpe file (Favorites List). You will need to zip the exported file to be able to attach it. Click on Attach files and open the zipped file.
dmfalk
First, then antenna. The one that comes with the SDS100 is crap, so I'd definitely suggest getting a new antenna. There are quite a few that can be had for around $30 that'll perform much better. (I personally use a Comet W100RX, SMA mount, but that's just my choice.)
Second, the DMR, NXDN and ProVoice upgrades: I'd definitely get DMR and NXDN, and only get the ProVoice if you just want to have it "just in case" (such as when travelling). There's also a Waterfall upgrade, which allows you to explore a frequency range visually, and see if there's something there you're not aware of. Handy, but not required.
Thirdly, there are plenty of videos on YouTube about how to use the SDS100. (Enough to give one a headache, though they're helpful...)
Fourth, check for a firmware upgrade, if it isn't, already! You do this in Sentinel.
And check these forums for any help- Any advice may already be answered here, but if not, ask! We're here to help!
And lastly, have fun! :) The SDS100 has lots to offer in such a little box, that it can be overwhelming, but fun to explore.
Also, these links may help:
Easier to Read Sentinel Manual
Easier to Read SDS100 Scanner Manual
Enjoy!
bcgrubin
Millbury,MA
FCI McKean P-25
For the hell of it program your scanner like the Federal Correctional Institution McKean
select the Band Type Custom. Its P25 ending in analog. Lower 406.000 Upper 410.000
FCI McKean P25
For the hell of it Try to Program that as Type 2 Smartnet.
It’s P25 digital channels ending in analog. The majority of these facilities run on this.
dave3825
Suffolk County NY
FCI McKean P-25
FCI McKean P25
Federal Correctional Institution McKean is a Motorola Type II Smartnet and last updated in 2011
FCI Mckean P25 is a P25 Phase 2 system and would need to be programmed manually as that system does not have any identified talkgroups and considered by Uniden as not scannable. Systems deemed not scannable are excluded from Sentinel.
It should not be programmed in as a Smartnet system.
Special_T
China Grove, NC
Resources galore! I keep forgetting about that page... 🙃
Enjoy!
Good afternoon,
Newbie here. Do newer SDS100's come with the DMR update or is that something you would always have to get upgraded if yo wanted it? Thanks!
Whiskey3JMC
Chimer Inner
Out of Area 🇺🇸
Nope, the only Unidens that come with DMR (& NXDN) out of the box are the 160 & 260DN. Only caveats with these scanners are no trunk tracking & no P25
hiegtx
Mentor
Dallas, TX
Good afternoon,
The firmware, enabling DMR reception capability, is in place in the scanner. But it is not activated and available for use unless & until the upgrade is purchased for that specific radio. You don't need to download & install a different firmware package; just purchase & enter the upgrade key.
Special_T
China Grove, NC
Thank you for the information!
