SDS200 and proscan problem
kb3nun
west pittston
Running a sds 200 with a new laptop and getting error code and droping connection
the source is running on port 8500
the web server is running on port 443
and the remote server is running on port 5000
below is a copy of the erros I am getting
Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException (0x80004005): No such host is known
at System.Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
at System.Net.Sockets.TcpClient.EndConnect(IAsyncResult asyncResult)
at SourceClient.ConnectToServer(Object State) in \ProScan\SourceClient.vb:line 132
Error Code 10 - The operation is not allowed on non-connected sockets.
Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it [::ffff:174.127.114.11]:808
at SourceClient.ConnectToServer(Object State) in \ProScan\SourceClient.vb:line 130
I have also had my ISP to my home and monitored for any problems and no drop offs in signal
ProScan
Software Provider
Ontario, Calif.
443 port is a email port but that should work also
But best to use HTTP or https ports
443 is https which doesn't apply. Use port 80.
Are you still seeing "No such host is known"?
Did you power cycle the scanner router? If that doesn't work then try
ipconfig /renew
W1KNE
Rooting out dumbasses since 2011.
Southern New England
Two other things to try.
Flush the DNS cache. ipconfig /flushdns
Also manually change your PC's DNS from 192.168.1.1 to 8.8.8.8. That will eliminate an issue with the DNS table in the router causing an issue, if it is..
kb3nun
west pittston
192.168.1.1 is the router address and 8.8.8.8 is a google DNS server
or do u mean change my router address to like 10.0.0.1 which is another address to login to routers
I am already running a different DNS server not the one the ISP uses, think i am using Quad 9 dns
kb3nun
west pittston
ipconfig /renew
did all that
even done a winsock reset
did the ipconfig release than renew
belvdr
did all that
Did you change the port to 80? Are you still getting unknown host?
The request above is to change the DNS properties of your NIC to use 8.8.8.8. No changes to anything else would be required.
kb3nun
west pittston
Just switched to port 80
And switched dns on NIC to 8.8.8.8 and the alternate to 8.8.4.4
I will reply with the finding on those changes
kb3nun
west pittston
ok well that seemed to work , I changed the dns on the PC, I would have never thought of that, after all the things I changed and put back to original
I would like to thank you for your help, this problem. Has costed me so much money from a new computer for the feed down to the ISP charging me to trouble shoot , plus the countless. Hours I have spent on the issue
Again thank you Eddie (Kb3nun)
kb3nun
west pittston
I would like to thank everyone for there input on the issue I was having, and thanks to you all the problem is now fixed, well i hope its fixed so far no errors
Thanks again Eddie (Kb3nun)
kb3nun
west pittston
Well the problem came up again about midnight last night, so what i did this time was use the ip address to broadcastiy not the audio1.broadcastiy.com
But what I dont know is there another server that i can use ?
kb3nun
west pittston
talked to a IT specialist today and he said it sounds like a host issue, i told him I changed from the host name (audio1.broadcastify.com) to 174.127.114.11 that is the physical. Ip address , he said when u use a URL it has to do more work than if u use just an ip address
now let's see if this work
Does this sound right to anyone
belvdr
Yes he is eliminating DNS. However we did that already by changing your DNS to Google’s.
I’m thinking something on your Internet circuit or your PC (most likely) is wonky.
kb3nun
west pittston
OK is that what i changed on the NIC card, and i also am using a different DNS on my router also
well if this doesn't work what i will try if going back to the radio feed software from proscan and see what happens there
kb3nun
west pittston
Did a complete uninstall of proscan 20.4 and even cleaned the registry of all proscann files
Now i installed the radio feed 6.0 and no problems
so what is the difference with them
