Am I the only one who wishes the SET SCAN SELECTION menu item would go 1 step deeper? Currently, you can select FAVORITES on and off, and the next level select SYSTEMS within the FAVORITES to on and off. There should be another level to turn ON and OFF Departments within the SYSTEMS.
Favorite (Evansville AREA) which holds several systems say Vanderburgh P25, Detention Center, Evansville Water, etc etc
Currently the SET SCAN Selection will let you choose Favorites under the Manage Quick Key Status and also Systems under the same, there is no 3rd choice to set Departments quick key status. Seems like a no brainier to add the Department quick key to that menu.
So it would be SET SCAN SELECTION......MANAGE QUICK KEY STATUS....DEPARTMENT QUICK KEY. currently for the SYSTEM Selection you have to say which FAVORITE first. So I would guess to set up the Department quick Key status would require input of FAV/SYS first.
Or am I the only one???? Doesn't seem like a difficult firmware change.
Before anyone asks this refers to the SDS series scanner specifically the SDS 200
