SF Rebanding?
ridgescan
San Francisco, Ca.
Did they switch something again or did my 785d finally krap its trunker? I am getting nothing all of a sudden as of today.
EDIT it all came back now cancel-the whole system was deaf here this AM for a good 20 minutes-wonder why.
Ameriscan
Phoenix, Az
Ive posted a few times about the same thing, yesterday, some time early afternoon, i heard SFFD say, " ok, we can go back to our normal radios again, the system is now up and running" my question is.. if they are not on the normal system.. then what one are they on?
ridgescan
San Francisco, Ca.
that's what I thought too lol-they must be switching to the 700mHz band? I searched the old haunts like 460megs and even 45megs but they were not there. I also did the 800 band in regular search mode and they still weren't there. Strange!
rooivalk
Probably the "fail safe" testing that they were doing. A message was broadcast about it over the last few days. And I think the system stops trunking and users use one frequency per channel?
officer_415
SF Bay Area
Sounds like you mean failsoft. And yes, each frequency operates in a conventional repeater mode and each subscriber radio will switch to one of those channels (pre-programmed based on the agency).
ridgescan
San Francisco, Ca.
any idea what band this happens in? Because it sure didn't occur in the 800 band they usually operate in.
officer_415
SF Bay Area
Failsoft uses the same trunking frequencies, but in a conventional repeater mode. In the event of a system failure, dispatches will be on CAFIRE1 (853.9875) and responses will be on CAFIRE2 (851.9125). I don't think there's any situation where SFFD would leave 800 MHz, except for a failure of those channels.
ridgescan
San Francisco, Ca.
hmm.. well thanks for the reply and info:)
akarydas
BCD 396T SFPD rebanding
Can anyone help me to reprogram SFPD rebanded system? Do I just need to add the new control channels?
It was so long ago that i programmed the system into my 396T and it no longer picks up SFPD.
akarydas
added cc and don't hear anything. do i need to do anything else?
officer_415
SF Bay Area
This question has already been answered several times earlier in the thread:
you need to enter the custom band plan available here: EditBandPlan < UnidenMan4 < TWiki
For the BCD396T: Menu > Program System > (select SF) > Edit Sys Option > Edit Band Plan
Note that the BCD396T will only have the Edit Band Plan option if you have firmware 3.00.00 or later.
rooivalk
So...On my 396T, I re-entered the NEW CC's. It won't pick up anything in ID SCAN, but will pick-up talk groups scanning as ID SEARCH...Interesting...I'll try the custom bandplan, but my 396T doesn't have the Edit band Plan option, and I have firmware 3.02.02...
kma371
Do you have and talk groups stored in the memory?
ridgescan
San Francisco, Ca.
I still have the old frequencies in there LOL when this happened I just piled in all the new ones behind the old ones and it still works fine.
mrob907
Columbus, OHio
Fail soft
Once in a while you'll hear that. A test is done every so often of the "Fail soft" mode of operation on the smartzone. When this happens it simulates the absence of the control channel, or controller. The system goes into conventional mode. They test it once in a while but I can't remember how often. usually lasts anywhere from 20 minutes to 2 hours.
