I just noticed this post about Snohomish County and I live in Snohomish County, what does this mean as far as purchasing a scanner? What would be ab example of the cheapest older model that will work on this new system and what is an ideal beginners model that I should start with. What technology is a minimum I need to make sure the scanner has on it. Thanks guys
SERS is still primarily an analog system, running Motorola SmartZone and is rebanded 800 MHz. It is digital capable, but typically only for encrypted use. Other folks will have to speak to the scanner make/models that are compatible.
