R30 Software
dmaria
Thanks. Am seeing the RT system software at $98 bucks. Sound about right? With RT, does entries write direct to the radio? Thanks.
The RT software is $25 (or $35 with cable) direct from RT Systems. Where did you see it for $98?
palmerjrusa
Frederick
I use the ARC30 Butel software for my IC-R30 and am very pleased with it:
bearcatrp
Land of 10,000 taxes
Just tried the ARC 30 software. Not impressed. Tried to add another group of frequencies. Did press F2 as stated to do. Wouldn't save. Gave up!
bearcatrp
Here is what I tried. Removed the sd card and plugged it in usb port with proper adapter. Fired up ARC30. It read it fine. Saw all my current information. Went to next empty line to try add a county P25 system. I was doing a copy/paste on the 1st frequency I wanted to input. It took it. Moved to the next field to fill which was name. The frequency I just put in disappears. Being new on this software, am probably missing something. I'll play around with it to see if I can figure it out.
bearcatrp
Figured out some of this software. Same as before putting micro SD card in computer. Since I am not a paid user, would not upload to the current data. Wanted to test it out with one group before committing to do allot of additions. Let me save it though as a dat file. Since I am not a premium member on RR, couldn't import. Will have to test a little more before deciding.
bearcatrp
I know I don't need to remove the card. Just decided thats the way I want to do it. Won't let me upload new data to test it out though. States I need to be a paid subscription. Hard to test it out when its partially crippled. I does let me save what I added but its a .dat file.
bearcatrp
I see if I have a subscription to RR that I can import. Can the import be selective to one county P25 system at a time? Just want to make sure I don't max out my memory. Thanks. Will probably purchase this next month.
