Some Minitor VI pagers won't accept custom audio
jpelura3
salem, nj
I can program frequencies and tones with no issue. However, when trying to upload custom audio, the upload only takes on some pagers. In the programming software, after I upload and click on the play button which plays the audio through the pager, custom audio plays. But when I change the ABC.... button, it's the standard "Selective call frequency one tone" speech. Audio files are in .WAV format, 8 kHz, mono, and 16 bit PCM. I used Audacity to create the files. They're named. F1, F2, F3, AV, AT, MON, SCAN and EMS.
I thought it was a firmware issue but some of the pagers are FW 1.05 and others 1.09 or whatever the latest is, I'm not in front of that computer.
Any thoughts or suggestions? It seems older pagers generally don't have the issue. Just newer ones. I can provide more information if needed.
Thanks for any insight.
edit: I should add, I did re-install the programming software and tried on another computer. Same issue.
n7maq-1
Oregon
Try one of these sites to make your voice files.
RadioGuy7268
PA
Is it possible that some of the non-playing files are larger sized voice files? I've seen that be an issue before. It appears that your coding is correct - especially if the same file is already playing properly on other pagers. Try to see if a shorter version of the file will play on those units you are having an issue with.
ElainneeWC
Interesting issue! So the software plays the custom audio fine, but the newer pagers just revert have you noticed if it’s all files or only some? I wonder if it could be a file size or memory thing with the newer units.
jpelura3
salem, nj
the new pager does not play any of the custom audio. My file sizes are only a few K. But as I said, plays "over" the pager from the software fine. I'm going to try some of the links above for encoding.
jpelura3
salem, nj
My file sizes range from 10k-20k. None of them work.
