I want to upgrade soon from my PRO-96 and am looking at the 1088 when it comes out. Is the Intermod problem being discussed apply to GRE/Whistler hand held scanners with stock rubber duck? I'm also in Los Angeles with lots of potential strong interfering signals but so far the PRO-96 has been very good with the stock antenna.
prcguy
It is just my experience .. but if you just use the rubber duck, you should be good. The biggest problem is when people add 'more antenna' hoping to hear more, or hoping to hear anything when their radio is pretty much already struggling with the signals it has.
The outcome is often that they in fact make the problem worse .. and yes, hear less. This is cause .. they do not understand the problem they are having. It is almost never a problem with not enough sensitivity with these scanners .. they are very good in that regard.
I have it on my list to measure the actual sensitivity of the HP1, HP2 and 1095 as I think that would be a good addition to the thread linked above.
I concur with sshermanmd in that the squelch on the 1095 has to be set very high and as a result, you may be missing weaker signals. Although I think the bigger issue is often not the squelch but likely that the radio is still struggling with the strong signals that remain.
Unless you have another scanner with the same programming to compare to (and I do) .. it is pretty hard to tell that it is not picking up all that it maybe should.
Sure the Whistler scanners have a very good interface and great audio, I think the buttons will be a good addition, but unless they fix their front end issues .. they can add all the buttons in the world, it is still a bit of a failure.
That does not mean that you will not enjoy your new Whistler scanner .. but you have to be cautious about what you do with it. Adding that new super antenna .. may be just enough to make things worse and not better.
Overall I am much happier with my 1095 than I was .. but it is still not my go to scanner.
Probably the only real fix .. add some attenuation (or in my case a notch filter, after determining the problem frequencies that are overloading your radio) until the front end becomes linear again.
If attenuation is the only answer .. you are just shooting yourself in the foot. So are you really winning ? Probably not.
For those that are interested .. I had issues with 3 frequencies. 162.1500, 163.2300 and 163.6200. My notch is centered on 162.1500 as it was the strongest. It is down -20 dB ... and -8 db and -3 db for the other 2. It was just enough to get rid of the intermod on my HomePatrol and make my WS-1095 perform better.
