Squelch Setting ?
Does it matter where the squelch is set at on a BCD325p2 for a Motorola Trunked system as far as how fast or slow it will scan and if it makes a Difference whats a good place to set it at. TIA Folks
marksmith
Anne Arundel County, MD
If you set it too low, like 0 or 1, it can slow the scanning speed. Anything 2 or higher should not 3ffect scanning.
WS1095/536/436/996P2/HP1e/HP2e/996XT/325P2/396XT/PRO668/PSR800/PRO652
radiochuck
Traffic Reporter
Phoenix, AZ
I leave mine set at 2. I think that's the default. But yeah, as marksmith said, if it's too low, it'll slow you down.
UnidenSupport
Uniden Representative
Wisconsin
For normal scanning, your squelch should be at either a 2 or 3 unless you are trying to find and register close call hits, then you may want to go to a 4 or 5. lower than 2 and you will get nothing but static, higher than 3 and you will most likely be skipping over some frequencies.
racing1
What if I'm scanning 2-3 sites at a time due to the fact certain talkgroups are on specific towers,what should my squelch be set at so I have a happy medium between quicker scanning between sites and being able to hear 90% of my talkgroups without squelch affecting the scanners ability to hold on to the talkgroup and not drop it so I don't just hear part of a conversation?
UnidenSupport
Wisconsin
The scanner will hang on each site for a few seconds regardless of your squelch setting. By all means, experiment, but from experience and the people we've helped here, going above 3 will make you miss good transmissions. Squelch is just the threshold of the quality of frequencies you receive, it can only make scan speed quicker by skipping transmissions.
