StarCom21 2025 Official Thread
YoShep69
Central Illinois
Believe it's coming from Macon County as I can BARELY get a lock on it here on the east side of Bloomington
Thanks for the channel info.
I can't get any signal. I'm in the same area as you. I just see it as a new neighbor to 229 (Normal) in Pro96Com.
I just noticed it Monday of this week. Macon County was also my first thought.
kevino
Database Administrator
Chicagoland
Hearing Glenview Dispatch Fire Department tone outs on TG 33456
This appears to have been a patch to either Highland Park FD's 154.160 dispatch channel or Lake Forest FD's 154.8825 dispatch channel (both are multicast). Currently, the last TG 33456 transmission on Broadcastify is from 11:59am on Thursday, so this TG might not be on the air full-time at this point.
K9CRT
Decatur, IL
Can anyone in Decatur, IL area macon co help it seems in this area Starcom 21 has changed frequencies my scanners have went deaf on the old ones and also a friend across town scanner. I have both the Grecom and RS which have been working perfect for several years until the past weeks.
Doug K9CRT
Decatur IL
Bri112233445
Somewhere listening to KenCom
Doug K9CRT
Decatur IL
What site were you using? They may have depreciated North and South to make Argenta/Oreana a simcast site.
There's Also A few people have been saying there's a new site that's coming from Macon that isn't identified yet
Bri112233445
Seeing a new site 2-64 as a neighbor to the Normal site, control channel is 860.2625. Believe it's coming from Macon County as I can BARELY get a lock on it here on the east side of Bloomington and I'm seeing a lot of traffic from Springfield and Decatur talkgroups. Interestingly enough, I'm showing sites 2-1 (Argenta), 2-28 (Decatur North) and 2-36 (Decatur South) as non-active on the neighbor list and the frequencies I'm showing look like they've come from those sites. So far I've noted these frequencies in use:
851.3125 (from site 2-1)
851.8375 (was a CC for site 2-1, now just a voice channel)
853.9000 (Alt. CC) (from site 2-36)
856.3125 (Alt. CC) (from site 2-36)
860.2625 (CC) (was listed as a voice channel under both site 2-1 and 2-28)
860.4625 (from site 2-36)
Unfortunately can't tell a whole lot else, it's barely strong enough for Unitrunker and DSD to acknowledge there's anything there. I'm a little surprised I can get it at all.
NAC is 143. Site neighbors are 2-1 (inactive), 2-2, 2-3, 2-6, 2-14, 2-17, 2-26, 2-27, 2-28 (inactive), 2-29, 2-30, 2-34, 2-36 (inactive), and 2-63.
@K9CRT If you can help identify this new site that would be great I'm nowhere near Decatur
kevino
Chicagoland
Over the past few days, I have seen silent key-ups and affiliations by IDOT District 1 and 2 units on what appear to be four "new" IDOT District 1 talkgroups - 33810, 33814, 33818 and 33819. I have not had previous loggings for these talkgroups going back two years.
Does anyone have any additional information for these talkgroups?
These talkgroups have been added to the Radio Reference STARCOM21 database page.
kbk777
Northbrook, IL
Which simulcast are you monitoring when you hear these TGs?
K9CRT
Decatur, IL
I am now suspecting that Decatur, Macon Co have switched to phase 2 can anyone confirm or deny this on Starcom 21
Doug K9CRT Decatur
JR16
Happy New Year everyone! It is "in the cards" that I'll be moving back into Dupage County from North Carolina this very month where I grew up, and literally used to do "scanner chasing" physically, took photos, and had them published in newspapers going back to the 1980's when I was a teenager, and most recently with my children through the early 2010's. I still monitor DuComm, and even have an 𝕏 account where I drop audio of various "newsworthy" calls. I hope to add pictures and videos as long as I'm able to monitor on Broadcastify!View attachment 175590
1000006301-jpg.175591
Maybe you can help me? I am trying to get DU-COMM Fire North on my SDS100. Specifically want to hear Glenside Fire. But I am not able to hear any traffic, even when in close proximity of Glendale Heights (+-5 miles) Does this look correct in Sentinel?
INDaviation
D1 Hater
The 317
You only have the McHenry County Simulcast site loaded in. Try adding the DuPage Simulcast site and see if that helps.
JR16
Ok I think I see what you’re saying. So I need to add the Ducomm simulcast frequency but not the talk group I have in the above image? When would I add the talk group over the simulcast site?
JR16
I was able to manually add them and can receive now traffic, however before every broadcast there is 1-2 seconds of loud static, then the broadcast comes in clear at normal volume. Is there any way to remove the static before the broadcast?
Kordaviation
Hey Everyone,
Quick question, I have an SDS100 and I monitor the Will/Grundy Site and I'm wondering if my signal is weak because of the stock antenna I'm using or because there's a cell tower nearby or because I'm not close to the tower which Is about 3 miles away. If it is the antenna is the Remtronix antenna a good one, if so which exact one should I get for Starcom21? I'm in the Plainfield area trying to reach sites 1 and 3 of callsigns WRAQ940 WRAQ941 Thanks.
Bri112233445
Plainfield & Wescom Police 2 dispatch channels are currently patched together started past 10:30 p.m tonight. Is this a new thing for overnights or are they permanently moving Plainfield to police 2?
