State of Delaware - P25 Phase 1 System (2024)
maus92
The OP
Going back to your list, the Phase 1 voice grants were on a company channel and a fire police channel; both historically tend to have heavy private radio traffic The Bayhealth grant - not sure about that but sometimes hospital owned equipment tend to lag wrt technology upgrades.
chrishoerner
KC3KSJ
Frederica, Delaware
Maybe the hospitals are some kind of patch at the hospital over IP that's not as simple as just swapping out a radio? I find it hard to imagine someone standing by a mobile at the hospital waiting for a call nailed to a desk.
maus92
The OP
They don’t. Somebody in he ER is listening though during their normal duties, and it’s common for an EOC to pre-alert a hospital that a call might be forthcoming. In Maryland, EMRC will connect a field provider with a hospital, so someone at the ER knows to expect / answer a call.
fireboat61
DelMarVa
@915hrs activity on talkgroup 277 Sussex Fire Dispatch. Hope the system comes online soon. Ready to use my G5.
  • Like
Reactions: hey
fireboat61
DelMarVa
It seems that a system tech is turning on and off talkgroups as something is happening. Milton 85 was alerted for a house fire. The 277 Disp talkgroup sounded the call then went silent but Sussex Fire 3 went active for the incident. Now neither the Disp nor Fire 3 is active. But Kent Fire 1 ( 211) is.
Hbright
Can you confirm the same RIDs on P25 transmissions and Motorola transmissions?
From what I noticed it looked like the same transmission was transmitted across two freqs, one for Motorola and one for P25. Same RIDs, so didn’t look like a patch.
fireboat61
DelMarVa
So far all of the tkgps have been accurate to the predicted p25 tkgps. Yes the voice was transmitting over both systems and did not sound like a patch from the legacy system to the new p25. I preprogrammed my harris unity radio with the new p25 tkgps and it sounds like p25 full volume voice audio. I was using the portable to monitor the new system while using the HP2 to monitor the legacy system. Both transmissions came through at the same time.
tvboy08721
Millsboro, De
I noticed on my SDS100, the Sussex Fire talkgroups are comming across as FDMA phase 1, while the Kent Fire talkgroups are TDMA phase 2.
maus92
The OP
If a unit with a Phase 1 radio registers on a tg, that tg will run in FDMA mode until all FDMA subs de-register (leaves the tg). I'm not sure if this is what is going on, but seems likely considing all the private radios out in the wild. I'd be curious if the VFCs have been given an EOL for their FDMA / XTL/XTS radios.
station09
Question , is Delaware state new phase 2 radio system in service. I look on radio ref, did not see new talk groups or freqs listed. Looks like they are still testing. Thank you
Whiskey3JMC
Airwave surfer...Cowabunga!
Philly burbs 🇺🇸
Huh? Not sure where you looked but...
Each county has their simulcast cells. Numerous public works talkgroups ID'ed thusfar FWIW...
