State of New York Metro-25 System...
leaf
hmmmfd.
I havent heard anything on the system in 2 days. Anyone else? I pulled it off of RR database via FreeScan into my 396xt. Are the TG's up in the Database the only ones there are? I monitored for about 7 hours today in Times Square, and about 9 hours yesterday from Astoria.
-leaf
minasha
NYC
Hi,
I programmed my pro-96 to the metro-25 system but it doesn't track the system at all,
It's totally silent. When i receive something on my 396xt the pro-96 stays silent.
I programmed the frequencies into win 96 like every other system but no good.
Can anyone help me with this ?
Thank You
W2SJW
Senior Member
Northwest NJ
The Pro-96 needs channel assignment tables to monitor ANY P25 systems (it cannot read them from the control channel). They are NOT in the same format that the 396 will show them as, but if you post what your 396 has, someone can help you figure out how to configure the data in the way the Pro-96 will need it.
minasha
NYC
pro-96 metro-25
Hi,
I have the Jersey City P-25 system programmed into my pro-96 and it works great.
It is configured with "multi tables" from the Radio Ref site for Jersey City. I think these are the tables
you mean, but there are no tables listed in Radio Ref site for Metro-25.
Where can I get the correct tables for the metro-25 system?
minasha
NYC
Hello,
I see that Radio Reference database lists pro-96 tables for Woodbridge NJ and Jersey city
Does anyone have the tables for NYS Metro-25?
riveter
MD
Hey, scuse me for resurrecting this after six months, but I'm curious.
Can someone put up the bandplan used by this system? I wanted to see if Harris lays it out a little differently or if it's the same as what I'm used to.
Similarly, I'm curious whether they're using C4FM or CQPSK LSM for this- can anyone advise?
I'd grab this myself, but I haven't been back to NYC in months :(
Thank you.
minasha
NYC
Signal-0,
Did you get the metro-25 offset tables for pro-96 ?
Thank You
minasha
NYC
Yes TG 5001 is extremely active today for the Belmont Stakes horse race
AlexC
Code:
  ID=00 Phase 1 FDMA           BASE=851000000  STEP=12500  TX_OFFSET= -45000000
  ID=10 Phase 1 FDMA           BASE=762006250  STEP= 6250  TX_OFFSET= +30000000
talkpair
Clinton County, MO
That's what we needed.
Thanks Alex
For older Radio Shack and GRE radios that require tables:
Code:
  Low      High                 Base      Step /
 Chan      Chan     Offset    Frequency   Spacing
    0      1439         0     851.00000    12.50
For older Uniden radios that require band plans:
Code:
Lower Base    Upper Base                 Step /
Frequency     Frequency    POL    Offset Spacing
851.00000     868.98750     +         0    12.50
minasha
NYC
Hello,
How do I program this band plan into a bc296d scanner?
Either with butel arc296 or doing it manually on the scanner?
Thank You
minasha
NYC
talkpair,
Thank you
your table works perfectly in a Pro-96
riveter
MD
Alex, Talk, thank you- outstanding.
