15:34 - Another quick TIS-B hit on one of the NOBELs.
All the TIS-B hits are way too low, under FL 4K, unless the FL is wrong (not to mention position of AC with TIS-B) those are not them.
Must be UFOs then
I was talking about this one only - click link.
Hex: ~278E8B
Speed: 366 kt
Altitude: 22,400 ft
Vert. Rate: 0 ft/min
Source: TIS-B
Ah you made me go track it down. ~DEEC30 is N22591 (click link for picture). Yep, not an F-16.
TIS-B IDs are not fixed to a specific aircraft like a mode-S hex. A mode-S hex is programmed into the transponder. A TIS-B ID is somewhat randomly* created by ATC for every broadcast.
Travis Would guess that it was a bad readback. Maybe one of these: My money would be on ZDC Brooke. Make sense since it's in the flt path from CAP to Savannah Don't think Sampson NC makes sense.
Sampson, NC - RCAG
Travis
No, 285.55 is legit. They were talking to someone right away. I was listening to 285.45 at the same time and can hear that controller, he wasn't talking to them. It's a valid Memphis Center freq. Maybe ZME/ZDC/ZTL are combining to have one controller deal with UHF during low activity periods due to reduced staffing because of the virus. |
So what is this 285.55 ZDC freq they're given to depart the CAP?
Picked up a couple of VP-45`s so far, would guess the main push will be off within the next 48hrs.Morning All,
Bit of a thing I have for the P-8s
The P-8 Patrol Squadrons out of Whidbey should be swapping soon, kick off date is normally 1st April give or take. VP-4 Skinny Dragons & VP-40 Marlins have confirmed to be coming east to LICZ as well as MSLP/OBBS so they will be split up to some degree.
Normal routes taken would be either KNUW>BIKF or KNUW>KBGR>LICZ, Pease has also been used in the past but rarely & mainly by the KNIP squadrons.
If anyone picks these guys up Id most appreciate anything on them.
Some tails to look out for,
Call signs,
Dragon/VVYD/MARLIN/VVQE
168439
168755
168757
168851
169001
169008
169009
169325
169348
169426
169542
169557
169561
