Sticky Thread For Mid-Atlantic MilAir 2021
mdmonitor
But he is showing 78-0640 or 80-0640 on mode s. Prob more accurate then the listed number.
They swap modes around a lot those A-10's.
Someone yakking A/A 228.100
Maryland A-10's yakking A/A on 271.400...Heading out I think. Said looking for Higher.
McGuire space A has flight to Griffiss Intl airport Weds around 10am local.Unknown type so far.
Heard SCAN 04,05 out in W-386 South enter on 249.800 then 312.400 talking with 3rd flight and
seems on mode s working with a P-8A out there doing racetracks. Asked him Scans are going higher to FL250 will
that interfere with you? P-8A 169333 is up at 37k so no problem.
228.1 is 104th FS A-10s discrete. Used mainly for air to ground attack training.
mdmonitor
1630- Marlins (3 X T-38s 71st FS) out in W386 (255.65).
1440- Scan 04 (CRJ-7 N804X NGTF) on Giantkiller discrete (312.2) advising Pioneer 91 the will be in east portion of the Atlantic Test Track for next 15 mins. Pioneer advises they will stay in the west area of the Test Track so there will be no conflicts in airspace use.
AirScan
314.4 is currently active. A2A comms. S3 here in Montreal.
I picked up a little at the start of their training but I haven't heard anything until now (1647). I
Got my SDR up with a crappy indoor antenna and was able to get them S1-S4 here in Ottawa. Constant chatter throughout the time they were in VIPER until they exited at 17:25. Reception varied from barely readable to 4/4, I guess they get pretty low at times.
GS I'm surprised you don't get them clearer as you should be the closest if you are near Griffiss ? What sort of radio/antenna are you using ?
1700- Spur 65 (KC-10 # 83-0079 AE0216) working Brickyard CP (134.1) w/write ups and inbound msg. Had gone down to the Gulf of Mexico, then the FL Panhandle before working way back to McGuire. also working ACY approach (124.6) on way in.
SPUR-65 inbound report complained aircraft rolled 5 degrees left to right a couple times with
Auto pilot disengaged and no pilot input..
Dover sent a C-5M to Panama today #84-0061 RCH426.
Airport icao is MPPA and has 8500 foot runway.
Bet the C-5M turns some heads landing there :)
MC426 (RCH426) Air Mobility Command Flight Tracking and History 02-Apr-2021 (KDOV-BLB / MPPA) - FlightAware
From this past Friday's post seems RCH-426 C-5M #84-0061 done shuttling between Guatemala and Cecil Jacksonville Fla.
Scheduled home Dover later tonight,, Wonder what that is all about.. Humanitarian mission? Repatriate?
MC426 (RCH426) Air Mobility Command Flight Tracking and History 06-Apr-2021 (GUA / MGGT-KDOV) - FlightAware
AirScan
I live approximately 10 miles south of Griffiss and I have the Uniden BC125AT w/ Diamond RH77CA antenna.
I've tried the RH77CA on airband. I compared it with 4 different antennas (on the same handheld) and it was by far the worst, pretty well useless. I never bothered to return it but figure it must have had a manufacturing defect, or was just really bad for airband ? Is there anything blocking your reception in that direction, terrain, buildings ?
GriffissSpotter
Central NY/Western NY
I've tried the RH77CA on airband. I compared it with 4 different antennas (on the same handheld) and it was by far the worst, pretty well useless. I never bothered to return it but figure it might have been faulty ? Is there anything blocking your reception in that direction, terrain, buildings ?
There are lots of hills and mountains in between me and in the VIPER complex so that's the main source of blockage. In some directions, I can get 100+ miles (ex. AR-631 comms on the western half of AR-631).
Also I heard NINJA31 flight on ZBW headed up there, didn't catch the other callsigns though.
