Sticky Thread for MilAir II
TinEar
Glen Burnie, Maryland
trainman111 said:
I'm very impressed. The CAP is coming in very clear here on 260.9. Usually it's more staticy than it is today.
They're working down in the southwest corner of the CAP area because of the weather Nick. So they're much closer to you than usual.
1348: Just heard that 302.075 freq again (scanning 300-303 for the CAP fighters interflight freq which is how I found it earlier and again this time). Didn't hear a callsign but it was an aircraft at very low altitude..."leaving 1700 for 4000" (feet). I guess it could be a "mixer" winding up on that freq but will park a scanner on it to see what turns up.
1435: RAMROD 11/12 coming into the CAP area to replace 65/66...260.9
1521: TANKER 21 confirms the tail number I posted earlier....62-3506...260.9
1524: TANKER 21 cleared to RTB by HUNTRESS...260.9
1524: RAMROD 11 tells 12 to change to "Point 4 in the main" and come up on...300.425
1539: TANKER 22 (KC-135R, 465th ARS AFRC, Tinker AFB OK) contacts HUNTRESS to say he's got a problem...he's only going to be able to offload 20,000 pounds from one of his tanks once he gets to the CAP (still out a way). Says he can do that offload and then will need to RTB. He wants HUNTRESS to notify TACC so they can start planning accordingly...as it is, he'll be 5-10 minutes late due to weather...260.9
1547: RAMROD 11 tells HUNTRESS that if there's only 20K of gas available, only one aircraft will be able to maintain the VOL...says they'll be about an hour short...260.9
1554: TANKER 22 tells RAMROD 11 he's entering from the northwest. Says he now can give 30K and wants to know if they want 15K apiece. 11 tells him they're still working that out...260.9
1555: TANKER 22 reports established on track at FL 240...260.9
1557: TANKER 22 now says they've done some work and tells RAMROD 11 he can now give 40,000 pounds...11 says with 20K each they can make it to the end of their VOL...260.9 (It keeps getting better with every utterance.)
1559: TANKER 22 asks RAMROD 11 if they're ready to refuel...11 says they'll wait about 15 minutes...22 reports they're slowing to save fuel...260.9
1617: RAMROD 11 sends 12 to the tanker...TANKER 22 says he's going to be working a real thin track in the northwest portion of the CAP area...260.9
1628: TANKER 22 tells HUNTRESS the weather is starting to squeeze them into a small space....and one of the fighters pops in with, "Yeah, it's nasty."...260.9
1628: TANKER 22 says it would help if they could extend the track out about 20 miles to the east...260.9
1629: RAMROD 11 now heading for the tanker...22 picking up speed to match the fighter...260.9
1629: Royal Air Force C-130/C5 (C-130J), tail ZH885, Lyneham Transport Wing, RAF Lyneham...landing ADW...118.4 (ASCOT but missed his numbers...sounded like ASCOT 47M)
1635: RAMROD 11 finishes his AR...they took 10K each for now and, apparently, will take another 10K each in a bit...260.9
1636: CAP participants really getting worried about the weather moving into their area - especially the tanker...260.9
1650: TANKER 22 tells HUNTRESS they absolutely cannot stay in this area due to wx...we're going to have to RTB now...says they already made Guard Dog mad...can't get the track they want...260.9
1651: RAMROD 11 says they'll go take the rest of the fuel now...22 says he can stay on this track for a bit....tanker and F-15s are going to slow to a speed of 290 knots...260.9
1652: TANKER 22 says he can give out the 20K he has if they hurry...260.9
1652: U/I aircraft an Andrews trying to get in to the field in spite of a ramp freeze in effect....118.4
RAMP FREEZE 29 JUL 20:45 2007 UNTIL 29 JUL 21:15 2007
1654: TANKER 22 says he's got to slow to 250 knots in the turns because of the wx...of course, the fighters can't go that slow during refueling...260.9
1655: Another Royal Air Force ASCOT C-130/C5 (C-130J), tail ZH888 from Lyneham Training Wing, RAF Lyneham heading into Andrews...119.3
1702: RAMROD 12 finishes AR after taking 10K for a total of 31,400 pounds...11 is heading for the tanker...22 says he's got to maintain the track in the western portion of the Guard Dog area...tanker in a hard right turn...says he can only work the area with right turns...260.9
I set my Weatherbug display for zip code 21788 at Camp David to see the weather they're talking about. Looks nasty except for the northwest corner of the area as they've mentioned.
1711: RAMROD 11 off the boom and heading back to the CAP at FL 220...260.9
1711: TANKER 22 says he understands he should be working his clearance out of here...HUNTRESS gives him the okay to RTB...260.9...over to Potomac for his clearance and says he understands he has to stay in the CAP untill he gets the clearance...135.525
1717: TANKER 22 cleared and handed off to ZDC-Hagerstown 134.15 where he checks in at FL 240 direct Hagesrstown
RAMROD 11 asked TANKER 22 for his tail number while 22 was talking to Potomac. 22 told him to standby. They never did pass it so this is the only tanker tail number during the CAP that I don't have. Sometimes, that's the way it goes. Can't be lucky all the time.
1749: Weather is still key in the CAP...RAMROD 11 reports they have to stay in the very north of the area due to a cell moving through...says if the cell moves to the north they're going to run out of airspace...260.9
1800: If you're hearing REACH 6002 on ZDC VHF, don't try to ID it from those numbers...it's C-17A, 01-0196, 437th AW Charleston.
1810: RAMROD 11 tells HUNTRESS they're now having to stay within 7 miles of the northern border of the airspace...estimates in about 20 minutes they won't be able to maintain the airspace at all....wants to know weather at Seymour Johnson...260.9
1813: RAMROD 11 working with Potomac to try to find some alternate space to fly in...apparently there might be an area in the southern part of the CAP they can move to...11 wants them to keep him apprised of the airspace down there...350.25
1816: RAMROD 11 says they might move down to the south...says they'll have to go west out of the airspace to get to the south though...350.25
1817: RAMROD 11 to HUNTRESS to relay the message about being clear in the south FL 190 and above...says they might have to move down there if they get boxed in up here in the north...260.9
1825: RAMROD 11 clears 12 to head down south and to report the weather once he gets there...260.9 (He also reports that to Potomac on 350.25)
1834: RAMROD 12 gets to the south, says the weather is better than in the north...260.9
1835: RAMROD 11 advises HUNTRESS they've got one hour of playtime (based on fuel remaining)...260.9
1841: RAMROD 11 moves to the south too and they're in the block 210-250...260.9
1910: RAMROD 11 lets HUNTRESS know their bingo point is 10,000 pounds...wingman only has 1000 pounds above that or 5-6 minutes left before he has to head for home...260.9
1915: RAMROD 11 tells HUNTRESS his wingman is 2 minutes from bingo and they're awaiting words...wants to know if they should leave together or work it as a single ship...11/12 are going to close into formation so it looks like both have been cleared out...260.9
1916: RAMROD 11 to Potomac (who he keeps calling "Center") to get clearance back to Seymour Johnson for both of them...350.25 (guess this means the CAP is being disbanded...haven't heard anything about replacements arriving or even another tanker coming in)
1918: RAMROD 11 tells Potomac they'd like to alter course a bit...want to go through Langley (LFI) for their first point and then back on normal course...350.25
Guess HARRIER and crew will be taking care of anything that might happen just as they do overnight once the CAP is disbanded.
1923: RAMROD 11/12 cleared to GSB at FL 260...first checkpoint is direct Langley...350.25
1925: RAMROD 11/12 handed off to ZDC-Brooke and check in there at FL 260...327.0
1927: RAMROD 11 reports exiting the airspace to the south....will remain this freq to let HUNTRESS know when they're switching (switching to what/where?)...260.9
1931: RAMROD 11/12 handed to ZDC-Calvert and check in at FL 260...cleared to FL 220 and say they've got to move left to get around a thunderstorm...281.4
1936: RAMROD 11/12 handed to Norfolk Approach 353.7...no joy and come back to 281.4... sent to ZDC-Franklin where they check in at FL 220...290.425
1944: RAMROD 11/12 handed to ZDC-Cofield and check in there...323.0
And that's the end of them and the end of the CAP for this evening. Guess they'll be back at it at 0600 tomorrow.
CitationJet
Northern Virginia
07.29.2007
No time for blogging/logging at the moment, but have had BUCK 87 (pres. E-4B), REACH 9489 (IDed by ATC as a KC-135), and MARINE 374 up on TRACON freqs within the past hour or so.
Also heard TANKR 20 receiving RTB clearance to Meridian on 135.525 at 1559Z-1603Z.
RAMROD 65 req. a p/p to KGSB on 378.100 @ 1640Z. I assume the answer from CP was no p/p capability.
CAP comms on 260.900 are fair to strong at times here with ground controller coming in fairly well as usual.
7of9
Geez,
You guys are way over my head with respect to radio in general, military radio in specific. Honestly I just got interested in all the frequencies, how to get set up etc. Kudos to you all. think I need to search for a beginner thread!
trainman111
Richmond, VA
It takes time...don't worry you'll get it. When I started out, I just asked questions. Most everyone is more than happy to answer any questions you may have. After all, that is how you learn.After awhile, you start to learn the "lingo" that the different branches of the military use. Once you get it, you'll be hooked. Welcome to the hobby! If you have any questions, just ask!
trainman111
Richmond, VA
Definately use that wiki!!! That was what gave me a good nudge along with the great info everyone has to share. Like ka3jjz said, where are you located? Once we know that, we can start compiling freq lists and also point you in the right direction.
REACH 608 C-5 #85-0001 arrive Dover with CP 349.400
RODEO 29 C-5 436th AMW back from humiliating defeat to Travis 60th AMW at AF Rodeo,McChord AFB.
Travis squashed everyone and clearly are the Rodeo Champs.2234z.
Best KC-10 Team: 60th AMW, Travis AFB.
Best C-17 Team: 60th AMW, Travis AFB.
Best C-5 Team: 60th AMW, Travis AFB
Course in the real scheme of things those contests mean nothing as some Units take more serious than others but congrats to Travis guys for show well done!
Dover crews and McGuire and Andrews still do a great job but am sure they are pissed off for various reasons.
Sounded like the West Coast fix was in...LOL
Maybe Travis 60th AMW crews need some more Trans-Atlantic action!
http://www.af.mil/news/story.asp?id=123062556
OPEC 78 arriving McGuire 0010z KC-10 85-0031 from Europe on CP 319.400.
16 pax and alpha 2 for 1 writeup.
WIZARD-ALPHA AWACS E-3 calling Northern Lights many times 364.200."Looking for tracks from your station" at 1946 local
TinEar
2122: So, just when I thought the CAP was over for tonight...here comes RAMROD 13 and 14 up the road...currently with Potomac...350.25
2124: Potomac clears RAMROD 13/14 for the block 210-250...350.25
I take it they went over to HUNTRESS on 260.9...had the volume turned down on that radio and didn't realize it.
2130: Yup...RAMROD 13/14 with HUNTRESS...260.9
Tanker is on the way in...guess it will be TANKER 23.
2141: TANKER 23 with Potomac cleared into the Guard Dog area at FL 240 (when he gets here)...135.525
2141: TANKER 23 also checks in with HUNTRESS...HUNTRESS reports he has him at 115 degrees, 32 miles...260.9
2145: TANKER 23 coming into the Guard Dog area...he's a KC-135R from the 171st ARW PA-ANG Pittsburgh...260.9
2150: TANKER 23 asks RAMROD 13 for his tail and unit...reply from 13 is 90499 (which is 89-0499) from the 324th Fighter Squadron, (4th Fighter Wing, Seymour Johnson AFB NC)...13 just wants 6,000 pounds this time...260.9
2155: RAMROD 14 to the tanker for 15K...RAMROD 14 gives his tail as 70205 (87-0205)...260.9
2314: TANKER 23 to Potomac to start the clearance working...RTB in five minutes...135.525
2320: TANKER 23 released from the CAP...260.9...23 to Potomac to pick up clearance through Indianhead to Pittsburgh at FL 240...135.525
2324: TANKER 23 handed off to ZDC-Hagerstown and checks in at FL 240 - several times and, apparently, not being heard...134.15
2324: RAMROD 13 to Potomac to say they'll be RTBing in about 10 minutes...350.25
2329: RAMROD 13 requesting direct Seymour...350.25
2330: RAMROD 13/14 released from the CAP...260.9
2331: RAMROD 13/14 cleared direct Nottingham, Tar River...report ready to depart at this time...350.25
2333: RAMROD 13/14 handed off to ZDC-Calvert and check in there at FL 230...281.4
2334: RAMROD 13 tells HUNTRESS they're leaving the ATCAA at this time...tells 14 to push common aux...260.9
2334: RAMROD 13/14 check in on common aux...300.425
And the CAP is suspended overnight --- again.
Mark, I didn't hear an E-3 in the area during that time but there sure was an E-4B from the 1st ACCS, tail 73-1676. He flew out of the area and then came back through an hour later.
Rgr above post TIN I didn't hear E-3 so assumed id so probably is your E-4..thanks.
Yes happened to hear them on 327.000 coming in just while ago...
2137 REACH 7029 C-5 arriving Dover CP 349.400 ,thought this was RODEO bird but must not be.
2137 ETHYL 50 on unid CP 134.100,prob McGuire.
2155 RAMROD 13 and 14 F-15-E models checking in with Tanker 260.900 tails 89-0499 and 87-0205
2200 REACH 135 C-5? arriving Dover,132.425 appch and CP 349.400
TinEar
First shift in the CAP this morning is RAMROD 15 and 16, F-15s from Seymour Johnson. The tanker is TANKER 24 (KC-135R, 63-8002, 22nd ARW McConnell AFB KS).
The second pair of fighters is coming into the Guard Dog area shortly before 1000. They are RAMROD 21 and 22.
0955: TANKER 24 only has 15,000 pounds of fuel to give to the incoming fighter pair. Once he does that, he will be bingo for Andrews, not for home. No sign of a TANKER 25 yet. After the first day, someone wised up and began scheduling the tankers for every three hours instead of four. That solved the problem of tankers running out of fuel before their shift ended. This tanker, however, has been on station for a full four hours - and beyond - which is why he's out of fuel and having to divert to Andrews.
0958: TANKER 24 tells HUNTRESS they are unable to RTB McConnell at this time...260.9
0959: RAMROD 21 tells BLUE CRAB (unknown ground station) he has him broken but readable...260.9
1000: RAMROD 21 says he'll take 7K and 22 will take 8K...TANKER 24 tells HUNTRESS that once he does this offload he'll be bingo for Andrews or McGuire - wherever HUNTRESS is sending them...260.9
1006: RAMROD 21 off the boom after taking 7000 pounds of fuel...260.9
1012: RAMROD 22 off the boom after taking 8000 pounds of fuel...260.9
1012: RAMROD 15/16 to Potomac to get clearance back to Seymour Johnson...cleared Nottingham, Tar River, Eagle...heading out at FL 220...350.25
1014: RAMROD 15/16 to common aux...300.125
1014: RAMROD 15/16 check onto freq 228.9 per instructions from HUNTRESS before they left to get their clearance.
1015: RAMROD 15/16 handed off to ZDC-Calvert and check in there at FL 220...281.4 (Dropping coverage of this pair)
1017: TANKER 24 given instructions to head for Andrews...told to standby for altitude, flight route, etc...24 asks for PPR for Andrews...260.9
1019: TANKER 24 tells HUNTRESS that since he's sending them into Andrews that he should get the PPR for Andrews so they're legal to land there...24 says they'll be performing some check lists for now but will not leave until they get a PPR number...260.9 (Sounding a bit testy here.)
1020: TANKER 24 to Potomac to say he's doing check lists...wants routing to Andrews and PPR...told to expect runway 1R when they get to ADW...135.525
1022: RAMROD 21 tells HUNTRESS that he and his wingman have approximately two hours worth of fuel...260.9
1027: TANKER 24 asking Potomac if they have a PPR yet...they do...135.525....24 then to HUNTRESS to say everything is in order and they're leaving his freq...260.9
1028: TANKER 24 beginning his descent...down to FL 210 from 240 to start...then to 16,000 feet...135.525
1031: TANKER 24 cleared to 12,000 feet...to 9000 at 1032 ...getting vectored around the area to get him to Andrews...135.525
1034: TANKER 24 cleared from 9000 down to 2500 feet...135.525
1035: TANKER 24 cleared to 2000 feet ILS runway 1R...135.525
1036: SKATER 07 (KC-135E, 57-1464, 108th ARW McGuire) to HUNTRESS to say he should be in the area in 15 minutes...260.9 (SKATER 07 is a standby tanker at McGuire that seems to be a fill-in when needed on short notice. He was still in his climb out of McGuire at the time of this transmission.)
1037: Potomac hands TANKER 24 off to Andrews Tower freq 118.4....135.525 (I'm not hearing TANKER 24 on 118.4 but presume he landed without incident. He was at very low altitude coming into Andrews from the south to land on runway 1R which often puts aircraft out of my listening range. If they land runway 19, coming in from the north, they're about 20 miles closer to me at that low altitude and no problem hearing them.)
1044: SKATER 07 to Potomac reports at FL 210 approaching Guard Dog...will enter area at FL 210 and has the block 210-250...135.525
End of log. Have appointment (of all days!) and must get out of here.
CitationJet
Northern Virginia
07.30.2007 am
1152Z 119.300 Potomac APP - BRS2404 (KC-137 FAB2404 2°/2°GT BrAF) - deps ADW to 11000' stayed on this freq on dep.
1154Z 126.300 Davison AAF TWR - NAVY 7C 505 (UC-12B NAS Oceana NFD DAA-PHF shuttle) - deps rwy 32 QSY 118.950 @ 1500' for 2000' cleared to 5000' then 7000' dir GRUBY QSY 126.400.
1200Z 118.950 Potomac DEP - JOSA 538 (C-21A JOSAC) - QSY ZDC-Montebello 121.675.
1208Z 260.900 PT HUNTRESS - RAMROD 16 - A/R in progress with TANKR 24 (KC-135R 22nd ARW) in the Guard Dog MOA.
Vschlitz
Pick up Time
13:39 A flight of 4 helo's enroute to Wash DC over head Frederick.
BM82557
Berkeley Co WV
Activity 07302007
1400 - HUNTRESS released SKATER 07 to RTB - 260.9
1401 - SKATER 07 cleared by Potomac to McGuire -135.525
gcgrotz
Savannah, GA
Hi Everybody:
Venus22 is doing practice approaches to CHO as I type. They did an RNAV and now ILS ry3 approach with Potomac on 132.85. Will be staying with tower for a few approaches after this.
Now here's the curious part: I tuned up what I have as Venus control on 142.75 and there is a big carrier with an FM high pitch tone (maybe 2khz or better). It is running S6 now on my IC746pro with discone on the roof. I can also hear it on the AOR8200 on the same antenna. Are they using this for telemetry now or something? I'm pretty sure I've heard them talking on it before on AM, that's what's in the truck scanner. Maybe I'm just picking up something local..
Venus22 just left, checked in with Potomac 17:04
TinEar
gcgrotz said:
Hi Everybody:
Probably something local to you George. I have a full time scanner running through all the Andrews associated freqs, including 142.75, and nothing was heard from here today on it (other than the continuing very high noise level across all the VHF freqs.)
The TANKER 24 (KC-135R, 63-8002, 22 ARW) that was forced to land at Andrews in the 1000 hour this morning due to bingo fuel load for ADW or WRI, apparently refueled and left about three hours later heading home to McConnell AFB KS.
Yesterday, I logged two Royal Air Force C-130J types (tails ZH885 and ZH888) coming into the area. This morning about 0930, ZH888 and another RAF C-130 (C3), tail XV197 that I didn't realize was here, left together. About 1730 this afternoon, the ZH885 tail left (so did the rest of the plane and crew, not just the tail.)
BM82557
Berkeley Co WV
Helo from Emmitsburg
Happened upon http://frederickpedalers.org/pages/photogallery_2006_0701_biglerville.htm
which has a couple of pictures taken during a Camp David cap last year. The one that caught my attention is the one of what appears to be a Blackhawk helo described as being from the FEMA facility (National Fire Academy in Emmitsburg). Maybe this is HARRIER.
Brian
Edit to add -- the url has the date as 2006_0701. That was before I started following milair but I did find these 2 posts from that day:
http://www.radioreference.com/forums/showpost.php?p=310406&postcount=2454
http://www.radioreference.com/forums/showpost.php?p=310416&postcount=2455
Maybe incident in the RR posts in the 1428 - 1437 timeframe is what is in the pictures?
gcgrotz
Savannah, GA
Thanks, still hearing that noise this morning. Damn this city living! Probably cable leakage or something, I'll keep an ear on it in my travels the next few days.
Here's an interesting post from VA forum someone observed in Newport News. Scroll down to the end of the stuff about STARS, the last 3 posts.
http://www.radioreference.com/forums/showthread.php?t=76951
Stay cool guys, the heat wave is coming!
TinEar
0920: Just turned the radios on and have a few transports moving around the area but not much else.
0921: Spoke too soon...BOBCAT flight of Langley F-22s w/Norfolk at FL 230...370.925
0922: BOBCAT flight to Giant Killer to work in W-386 for the next 30 minutes...249.8
0923: DAGGER 61 flight (Langley F-22A) also into W-386 w/Giant Killer and switch to 40 Prime...249.8
0923: REACH 6437 (C-130J, 06-1437, 143rd AS RI-ANG Quonset) reports takeoff from Andrews at 1319Z...378.1 (This is the new C-130J that was at the ADW airshow)
0924: BOBCAT flight working interflight...233.525
0938: U/I aircraft - suffix 22 - on Metro freq asking for weather for KSVN (Hunter Army Airfield) at 1500Z...239.8
0940: 22 gets the KSVN wx and asks also for Charleston wx...239.8
Turns out to be REACH 222.
0943: BRAVE 61 (2 ship flight w/62...F-16s DC-ANG Andrews) calling HUNTRESS...139.7
0943: BRAVE 61 w/TRACON climbing out of Andrews...348.725
0944: BRAVE 61 handed to ZDC-Calvert and check in heading for Patuxent ...281.4
0945: BRAVE 61 tells HUNTRESS he got the text message...62 did not receive it but does on the second try...139.7
0946: BRAVE 61/62 handed off to Patuxent Check-In...and do...305.2
0949: BRAVE 61/62 handed to BayWatch where they report in the airspace and will work from 3500-35000 for the next 30 minutes...when done, it will be a tunnel recovery back to Andrews at 4000 feet...354.8
0950: BRAVE flight back to HUNTRESS freq to perform their assigned work...139.7
0955: Langley F-22 activity on Giant Killer's tac freq...391.2
0956: BRAVE 62 having some equipment problem...trying to figure out how to correct it...139.7
0957: Flight Check 81 (BE-30, registration N81, FAA) flight in the area....not sure what he's talking about but wants to check some runway equipment somewhere but they won't give it to him for another two hours...he tells the TRACON controller that if they want to just put him in a penalty box somewhere, that would be okay...before that transmission, he said, "Well, that just leaves us dead in the water."...125.65
0959: U/I aircraft (big 'un) to Norfolk CP with arrival msg...he's got 25 pallets and 52 pax and various loose cargo and mail...needs Customs and Ag...349.5 (I believe this is a C-5A, tail 70-0455 from the 105th AW NY-ANG operating as REACH 0455 who I know was in Europe a couple of days ago. I've got a C-5B, 85-0006, and a C-17A, 06-6158 also in the area but neither appears to be coming from overseas.
1000 BRAVE 61/62 seem to be okay and doing their work at Pax on 139.7....more F-22s entering/exiting W-386 w/Giant Killer on 249.8...a few LBEs moving around the area.
The problem BRAVE 62 was having was with his weapon selections...he could only select Mark-82 and Mark-84 type weapons...then learned he could select GBU-12...but wouldn't allow him to select any other weapons systems. He has enough going for him so they can continue their work.
Got to run for a bit.....back later.
BM82557
Berkeley Co WV
Activity 07312007
0942 - HUNTRESS with BRAVE 61, weapons safe etc. - 139.7
0943 - BRAVE 61 out of 13 for 15, ZDC-CALVERT - 281.4
0944 - BRAVE 61 reports receiving test message alpha - 139.7
freqhopping
Not milair but interesting, the Goodyear blimp N2A is over the Sterling, VA area currently. With Dulles tower 120.1 right now.
1611- N2A now heading south towards Rt50. They're taking pictures of their stores in the area. The ATC controller mentioned he thought they may have been in the area for the Redskins training camp. They pretty much flew right over it. There is a Cowboys fan onboard, he may not have liked that. ATC said we (the Redskins) are going all the way this year.
1625- Heading back north to Frederick.
1626- Some blimp comms on 132.0
