Sticky Thread for MilAir II
1900 local REACH 1197 C-17 out of KCHS on AR primary 305.500 with tanker BULL 40 self id as KC-135 171st ARW Pittsburgh tail #58-0112 headed for Nantucket AR.
BULL is new callsign for me and the 171st ARW.
Had a STORK 41 call Dover CP about same time,nothing else heard.
jethunder
Fairfax, VA
311.0 used at Pax River?
311.0 at 2312 local....."Pax river, This is BULLET 85". calling several times, doesn't sound like a response.
I know 311.0 is used for the command post at Langley and Seymour Johnson AFB, but use for Pax River is new to me.
Yes he must have been accidently on wrong freq.
BULLET 85 was doing touch and go's at Dover earlier during the evening.
Not sure what type it was..
TinEar
Glen Burnie, Maryland
0922: DC-ANG F-16 flights are up working at Patuxent. WILD 1 and 2 are among them but coming home to Andrews because WILD 2 is in an emergency situation due to an electrical problem. They are on 143.6 interflight, 270.275 TRACON and with SOF on 139.9. WILD 2 is being cleared for straight in approach with WILD 1 flying chase.
0926: WILD 1 and 2 handed off to Andrews Tower...check in 15 miles to the east and repeats that WILD 2 is in emergency with an electrical problem...349.0
0927: A SCARY flight of F-16s has been holding with TRACON on 335.5 due to a ramp freeze at Andrews for Air Force 2 (C-32A, 99-0004, 1st AS)
0928: WILD 2 cleared to land in emergency, WILD 1 for low approach...349.0
0929: Lots of chat with SOF and the WILD flight on 139.9 as they approach the field.
0930: SCARY flight to ADW Tower 8 miles out...349.0
0930: ANGRY flight also on the way home to Andrews and giving mission reports to SOF...139.9
0933: WILD flight is on the runway (WILD 2 landed, WILD 1 went around again and then landed), SCARY cleared to land - all on 349.0 - and ANGRY now with TRACON 335.5
0936: ANGRY flight to ADW Tower for landing...349.0
0940: ANGRY flight "base, gear, stop, right"...and they're down...349.0
All three Andrews DC-ANG two-ship F-16 flights are now on the ground and done....except for the debriefing.
Meanwhile, several Langley F-22A flights are heading out to W-386 under Giant Killer's control. They are using 249.8 primary but also 238.1 due to poor comms with GK on the primary. Flights are also noted with Norfolk TRACON on 370.925 after takeoff from Langley as they climb out and head offshore. Around 0930, the two most recent flights to enter W-386 have been STUD 41 and CYCLONE 51.
0918: AR freq 252.8 active
0941: AR freq 235.1 active
0940: NAVY SALTY DOG 323 (F/A-18B, 161947, VX-23 Pax) with ZDC-Calvert as a flight of two at 16,000 feet...281.4
0942: SD 323 handed off to ZDC-Irons and check in at 16K...360.85
0948: SD 323 cleared direct Gordonsville...360.85
0948: Langley interflight freq active...315.85
0951: SD 323 flight handed to ZDC-Azalea...263.1
1006: FLIGHT CHECK 81 (BE-30, N81, FAA) to Andrews Tower...says he's going to be checking the glideslope first and asks tower to be sure it's radiating for runway 1 left...118.4
1009: CYCLONE 51 flight to Giant Killer to report 25 miles east of HEELS to RTB....249.8
1011: DC 51 (KC-135R, 57-1479, 756th AS Andrews) with Andrews arrival message....378.1
1016: DEVIL 11 (F-16, NJ-ANG Atlantic City), flight of four on interflight...138.425
1016: DEVIL 11 with ZDC-Kenton reporting passing through 13,000 feet...354.15
1017: DEVIL 11 handed to ZDC-DuPont and check in at 16,000 feet....ID as a flight of four F-16s....307.25 (Not sure what ground controller called them but flight leader told him they take offense at that.)
1021: DEVIL 11 flight handed to ZNY-Modena and check in at FL 220, ID as a flight of four...says they'd like to go to the Harrisburg 220/18 radial which is the start point for low level route VR-705 which they'll be working...335.6
1022: DEVIL 11 flight cleared down to 12,000 feet...335.6
1025: DEVIL 11 flight asks to cancel IFR at this time...ask if this is the freq they should come back on after completing the low level flight. They are told to use 239.05 coming out...flight leader says he'll see them in 25 minutes...335.6 (Flight leader taking his flight down on interflight 138.425)
1025: CRAB 51 (C-130J, 97-1351, 135th AS MD-ANG) airborne from MTN...w/CRAB Ops...384.1 (Not flying locals for a change...eventually climbed to FL 260 and out of range)
1028: JEDI 11 (EA-6B, VAQ-209 Andrews) flight climbing out from Andrews and cleared to 17,000 feet w/TRACON....348.725
1029: SALTY DOG 323, flight of two, back in the area...with ZDC-Irons 360.85 and then to ZDC-Calvert 281.4 at 17,000 feet.
1032: SD 323 asks to be handed off to Pax and get 354.8 as the freq to go to....281.4
1032: JEDI 11 flight handed to ZDC-Calvert and check in at 17,000 feet...133.9
1035: JENA 13 aircraft (Cessna 206, N831EM, FBI) flying at 3600 feet somewhere in the area (Missed freq but fixed callsign...first typed ROSS out of habit instead of the new callsign even though I clearly heard JENA)
1038: FLIGHT CHECK 81 still working Andrews area...switching between Tower 118.4 and Approach (TRACON) 119.3
1041: JENA 13 in the landing approach at BWI w/Tower...119.4
1046: JENA 13 lands on runway 33R (short runway), is handed to Ground Control who directs him to go park his stuff...121.9 (Flew directly overhead my house at about 500 feet)
1054: DEVIL 11 flight comes out of VR-705 and checks in with ZNY-Lancaster...239.05
1055: DEVIL 11 handed off to ZNY-Middletown...says they're at the Harrisburg 230/20 radial at 13,500 feet and want to get to Smyrna (then have to explain that's ENO)...want to go low level along the coast to Atlantic City...322.4
1056: Pair of McGuire KC-10As on primary interplane freq performing AR training with each other....suffixes 51 and 52...139.875 [Should be TEAM 51 (79-1710) and TEAM 52 (79-1712). At about 1110, they are also working ZDC-Sea Isle 133.125)
1058: DEVIL 11 flight handed off to ZNY-Hyper and check in at 13,500 feet...322.5
1100: DEVIL 11 handed off to ZNY-Modena and check in as a flight of four...335.6
Got to leave. Back later.
Note for the future: JSTARS aircraft today noted in the Atlanta area using low band freq 46.65 FM. MilAir monitor reported the JSTARS aircraft was working with a FIREBIRD 37, a suspected helo. (Courtesy MilRadioComms) Although I've never heard them working low band in the past, I imagine a JSTARS aircraft can go just about anywhere.
JohnFB
Western Mass
I heard them as well, Mark ...... but I think you heard the tanker swallowing ETHYL ... I heard him a number of time with ZBW ATC. And the C-17 I believe was 01-0197 .... ETHYL had long chat regarding his being with the unit when they were transitioning to C-17s.
freqhopping
Looked out the window just before 0800 to look for the snow that weather.com said was happening. No snow but I did spot a CH-47 at a much higher altitude than I usually see helos around here. Found him on 125.05 just before switching to 126.65. It's GUARD-10253 heading to Stafford. Handed off to 124.65 and still looking to get a WX report for Stafford.
Later in the morning RAM-41 ZDC-Irons to Norfolk approach 353.7 then immediately to 370.925
Yes the C-17 01-0197 was also a gabby guy.. "This is a 2001 model etc".
REACH 1197 was heard this morning over Europe btw.
TinEar
Yup...REACH 1197 was first heard in the UK around 0700Z yesterday morning. Since then, monitors in the UK, Belgium and the Netherlands have logged him all day yesterday and today. He's busy.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
OK the Delmarva quick list is ready to be distributed. Anyone who would like a .csv based copy of the file can email me at ka3jjz@NOSPAM.netscape.com (remove the nospam to use) and the list is yours. Many of the better scanner packages have the ability to import .csv files - however please note that the PRO-96 or 2096 won't work very well for this application.
Let's hear from some of the lurkers out there. Anyone who gets a request for lists of freqs please pass them along. Remember, this is not a complete list by any means - it's a list to get a newcomer's feet wet.
73s Mike
BM82557
Berkeley Co WV
TinEar said:
Wow! Assuming they run the normal schedule from 0600-2300 on the middle days, they'll wind up flying 87 hours of mission time. If it's with F-15s and a KC-135, they'll use 30,000 pounds of fuel per hour (running conservatively) or 2,610,000 pounds over the course of the mission. That's not counting flight time to and from the Guard Dog area. Just imagine if it's Eglin that gets the call again!
I believe that F-15E's have been cleared to fly but that the C's are still grounded. Has anyone heard anything different?
TinEar
Yeah, I guess we read the same article. All 224 of the E-models have been cleared for flight after undergoing a 13-hour series of tests on each aircraft and the Seymour Johnson F-15s were flying again as of Thursday. Langley has nothing but C-models so they're all still grounded and not flying.
JohnFB
Western Mass
Evac 9108
Sun
18-11-07
@1810Z
EVAC 9108 clg "HANSCOM Ops" [KBED] a number of times on 397.100.
Sounded like a C-130 ..... anyone else catch? Never caught him on ATC.
JohnFB
Western Mass
Hobby 07
Sun
18-11-07
2025Z : 11175.0 USB HOBBY 07 in p/p [DSN 597-4121] w/possible Keesler ops. Were told by "ATC" to divert to Kelly, TX and wanted to know who authorized it. They were already 'half-way across the country' and they would have to stop for gas and it would take them 3 hours.
I could only make out Ops saying "General" a number of times and that seemed to convince HOBBY.
I know HOBBY had been @ KCEF Westover, MA earlier .... must have been a long day for them.
TinEar
JohnFB said:
Sun
18-11-07
@1810Z
This was a C-130H from the 757th Airlift Squadron AFRC in Youngstown OH. Tail was 90-9108. He came in from Europe yesterday and into this area in the 1500 hour. At the time you logged him, he would have still been off the coast.
Can't help you John on the HOBBY 07. Since you caught him on HF, there's no telling where he might have been....well, at least by me.
BM82557
Berkeley Co WV
Guard Dog time change
NOTAM Number : FDC 7/4793
Issue Date : November 19, 2007 at 1820 UTC
Location : Hagerstown/Thurmont, Maryland near MARTINSBURG VORTAC (MRB)
Beginning Date and Time : November 20, 2007 at 1600 UTC
Ending Date and Time : November 24, 2007 at 1900 UTC
Reason for NOTAM : Temporary flight restrictions for VIP (Very Important Person) Movement
Type : VIP
Replaced NOTAM(s) : 7/4450: Due to change in Departure Date and Time.
Departure time changed from 11/25 1800 UTC.
freqhopping
BLUETAIL-02 flying in circles or something. Been with ZDC-Dominion 377.1 for a while now. Advises he's still VFR, done with north to south track, requesting to head towards Elizabeth City. Final destination is NGU Norfolk NAS.
1635- ???-91 departed Langley I believe. 370.925>ZDC-Cape Charles 256.8 then 257.7.
1639- ???-91 with ZDC-Coyle 254.3 Still to garbled to get the c/s, it's two syllables.
1641- This time it sounds like MAKO or MACON.
1642- ZDC-Sea Isle 281.45
TinEar
Unusual Travis. At first, I assumed that was the backend callsign for a GRAYHAWK E-2C and was going to ask if you got the front end callsign. But the traffic looks like it's the front end doing the talking since the guys in back wouldn't normally work the ATC freqs.
1720: A couple of KC-135R tankers from the 756th ARS at Andrews took to the air at this time. DC 11 (61-0307) and DC 12 (57-1487) were the two.
[They still use that funny looking DECEE spelling on their flight plans but I've never been able to convince myself to use it when I type logs.]
NOTE: A person with knowledge of what he speaks...ahem...gave me the confirmed freqs for refueling track AR-777...228.0 Primary and 315.9 Secondary. That track is not included in the FAA supplements so it's not on the official list that floats around. A McGuire tanker going from WRI to AR-777 will follow this freq progression...118.65 Twr> 124.15 (119.05) Dep> 128.3 ZNY-Manta> 132.15 ZNY-Atlantic. If the tanker is going from McGuire to AR-20, they follow the same freq pattern except after ZNY-Manta, they'll go to ZBW-Hampton freq 124.525.
Additionally, that funny track with no known number that runs from around the Patuxent area up to the W-107 area is also not included. Primary for that one is 288.0 and I don't have a clue for the secondary.
Foreign Flags Today:
1003: German Air Force...C-160D, tail 50+34. Looks like he went notheast up the coast and probably home. He's been around since the 15th of the month.
1805: German Air Force...C-160D, tail 50+85. He came in from the west. He arrived from Europe on the 8th, departed on the 9th heading west and wasn't heard from again until today.
1354: NATO, Luxembourg flagged...CT-49A (or a B-707-307), tail LX-N20000, operating as NATO 25. He came from overseas and was heard over Cape Cod at 1323 before moving into this area.
This morning at 0959, an Israeli Defense Forces B-707, tail 275, came off the ocean and was heard over Cape Cod. At 1036 he was heard in the McGuire area and may have landed there.
Airspace fix ASHEY in Virginia cancelled by the FAA today. It can be removed from lists.
1917: CRAB 53 (C-130J, 97-1353, 135th AS MD-ANG MTN) to CRAB SHACK (Crab Ops) at MTN says he's 15 minutes out, A-1 and 25K on the fuel...also tells ground that if the "other guys are ready, we'll leave our engines running."....384.1 (This is their new Ops freq replacing 385.9)
1922: MARINE 101 (C-37B, 166378) to Andrews Tower reports breaking out of the clouds at 4500-5000 feet. Says he'll see them at Andrews in about a week...118.4
JohnFB
Western Mass
1615Z : I caught him on 11232.0 USB working Trenton Mil ...... p/p to ?385-126-6325? and also I thought he was talking about a selcal KMIA, but maybe he wanted to go to Miami.
1520Z : This wouldn't be the IAF 053 I caught on 129.400 would it? Asking for WX @ Dover and somewhere else. The Israelis say "Israeli" usually, right? This guy said 'India Alpha Foxtrot' and sounded Indian.
CitationJet
Northern Virginia
Re: IAF
Hi John,
IAF=Israeli Air Force.
Best regards,
Tony
