TinEar
Mike, both those tail numbers come up as 79th Fighter Squadron on Scramble. But so did a pair in the last CAP when we knew they were from the 77th because that's where they said they were from. I didn't hear their first refueling when they came into the CAP so didn't hear if they gave their squadron association. I guess it's possible that all the interflight freqs got scrambled but that's not at the top of my list for an explanation.
1723: Guess they refueled with TANKER 05 while I was away from radios...PITMAN 33 reporting 8,000 pounds of fuel remaining and tanks feeding...34 has 8,700 pounds and feeding...260.9
This pair isn't talking to each other on interflight. Anything they say, the're saying it on HUNTRESS' freq.
1749: PITMAN 33 heading for the tanker...260.9...33 says he's having a problem with his radar and asks HUNTRESS for a BRA to the tanker.
1754: PITMAN 33 makes contact with the tanker's boom...tanker asks his unit affilitation...33 tells him they're from the 77th Fighter Squadron...TANKER 05 says he's from the 77th Air Refueling Squadron and chuckles about it....228.9 (This makes TANKER 05 from Seymour Johnson AFB NC...the 77th is "The Totin' Tigers" - a winged tiger on their unit patch. The 77th Fighter Squadron at Shaw are "The Gamblers" and have 4 sevens separated by an ace on their patch - 77A77.)
1757: PITMAN 33 off the boom...228.9
1758: PITMAN 34 heading for the tanker...260.9
1759: PITMAN 34 changes to boom freq, reports he's 5 miles off the tanker's left wing...tanker clears him to rejoin...228.9
1804: PITMAN 34 finally at the tanker and is cleared in to the boom...228.9
1804: PITMAN 33 asks HUNTRESS for a weather update for Shaw...260.9 (Gets it at 1806)
1808: PITMAN 34 off the boom after taking 5700 pounds...they wish each other a good flight and a Merry Christmas...228.9
1809: PITMAN 34 established back in the CAP at FL 220...260.9
1811: TANKER 05, while on 135.525, is sent to 126.55 for radio checks and gets them all (apparently from different transmitter sites)...goes back to 135.525 and reports that info.
1816: Fuel reports...33 has 11,000 pounds, 34 has 11,700 pounds...both report wing tanks feeding...260.9
Depending on when this pair is relieved, they should need one more small fuel stop, a couple of thousand pounds each before heading home...assuming their replacements come in by 1900.
1831: PITMAN 35/36 on their way...with ZDC-Blackstone 235.625 and then to ZDC-Brooke 327.0
1831: PITMAN 35/36 using 139.925 for interflight...another new one for us...at least one they haven't used in the past while in the CAP...no preset number used for it yet. (Edit: I'm wrong...it has been used inthe past..it's their V-12 preset...just found it in my reference book)
1836: PITMAN 36 reports timber sweet [female]...PITMAN 35 reports timber coarse...(talking about their Link 16)...139.925
1838: PITMAN 35, while on 327.0, asks ZDC-Brooke for a VHF freq and get 126.875 and change there and check in with ZDC.
1839: PITMAN 35 checking in with HUNTRESS as fragged...260.9...ask for a squawk on the tanker...get 5346...TANKER 05 asks for squawks for new players from HUNTRESS and gets them.
1841: TANKER 06 checking in with HUNTRESS...260.9
1841: PITMAN 35/36 check in with Guard Dog at FL 250...135.525
1844: PITMAN 35/36 heading for the tanker...still 30 miles away....they are talking on 260.9 and TANKER 05 is answering them on 228.9...finally they get together on 228.9...now 19 miles to the south of the tanker
1847: PITMAN 35 cleared to the boom, 36 cleared to hang out off the left wing of TANKER 05...228.9
1848: PITMAN 33/34 have 9000 and 9700 pounds of fuel remaining...might not have to refuel if they get out of the CAP in the next 10-15 minutes.
1849: PITMAN 35 gives his tail as 94-4044 and 36 is 94-4040 and says simply they're from the 20th FW...228.9
1849: TANKER 06 checks in with HUNTRESS again...260.9
1850: PITMAN 35 disconnects from the boom after taking 1900 pounds...is sending 36 in to topoff and then 35 will go back for more...228.9
1851: PITMAN 33 to Guard Dog to say they're 5 minutes from RTB. Wants them to work up his clearance back to Shaw...135.525
1851: HUNTRESS had PITMAN 33 go to 139.15 for a radio check...nada there...260.9
1854: PITMAN 36 off the boom after taking 5200 pounds...228.9
1854: PITMAN 33/34 sent down to 14,000 feet...they're heading south...260.9
1855: PITMAN 37 [female] established in the CAP with HUNTRESS...260.9 (35 taking on more fuel)
1856: PITMAN 33/34 sent to freq 125.65 (Potomac TRACON) for comms while on 135.525
This is differnt...PITMAN using VHF to exit the area
1858: PITMAN 35 finishes his topoff, goes back to the CAP and establishes in the south...260.9
1900: TANKER 05 reports at FL 240 and RTB to Guard Dog...135.525...cleared direct Tar River.
1901: PITMAN 33/34 switch to "FMT, Net 1" but I don't find them on any of the FMT 300 mHz freqs I have programmed...different FMT net apparently.
1903: PITMAN 33/34 say to go to V-10 and go to 140.375 as expected to chat on their way home
1903: PITMAN 33/34 with ZDC-Brooke 327.0
1905: TANKER 05 handed off from Guard Dog to a VHF ZDC freq...135.525 (Not following him)
1907: PITMAN 33/34 handed off to ZDC-Blackstone 235.625 where they check in at FL 240.
And so...by 1905 the PITMAN 33/34 flight is heading home on ZDC freqs and 140.375 (V-10) for chat. PITMAN 35/36 are established in the CAP with HUNTRESS and are using 139.925 (V-12) for chat. TANKER 06 is flying the track as the refueler and we're all settled down until the end of the CAP at 2300.
2025: PITMAN 36 heading to the tanker...260.9...PITMAN 35 says he'll go about 10 minutes later after she's done....36 reports radar contact with the tanker.
2030: PITMAN 36 to the boom freq with TANKER 06 who is at FL 250 awaiting her arrival...228.9
2034: PITMAN 36 confirms she's from the 77th FS at Shaw and again gives her tail number 94-4040...she's cleared to contact the boom...228.9 ...TANKER 06 tells PITMAN 36 that the boom interphone is inop...says when he turns it on he only gets a loud hum. (This confirms for the umpteenth time there is such as thing as a boom intercom/interphone which we cannot hear when they use it. I've been assured by several people there is no such thing as a boom interphone. I continue to differ with them.)
Bold is specifically for those people telling me it doesn't exist. Everyone else pay no attention.
2038: PITMAN 36 completes refueling...took 7,000 pounds....228.9
2038: PITMAN 36 back to HUNTRESS...260.9
2038: PITMAN 35 requests the boom...says 36 has the CAP...260.9
2040: PITMAN 35 says he's pushing to boom freq...260.9...and contacts TANKER 06 on boom, reports nose cold and is on 2992 (standard at 18,000 feet and above) barometric pressure setting.....228.9
2043: PITMAN 35 confirms tail as 94-4044...cleared to contact the boom...228.9
2044: TANKER 06 says he's from Bangor, Maine...also says he can hear PITMAN 35 on the boom intercom but no doubt 35 can't hear him....35 confirms that...228.9 (And another confirmation of a boom interphone!!)
2046: PITMAN 35 tells TANKER 06 they'll need one more topoff - about 2000 pounds each after this refueling...228.9
TANKER 04 -- PA-ANG Pittsburgh
TANKER 05 -- Seymour Johnson AFB
TANKER 06 -- ME-ANG Bangor
2036: PITMAN 35 disconnects from the boom...says he has a full load and will see the tanker in about an hour...228.9....reports back in the CAP to HUNTRESS...260.9
2200: PITMAN 35 heading to the tanker...says this will be the last refueling...has radar and then visual contact with the tanker...changing to the boom freq, nose is cold...260.9
2201: PITMAN 35 to TANKER 06 on boom freq...says he'll take a topoff and this will be last time...3 miles at TANKER 06's six o'clock position...228.9
2204: PITMAN 35 cleared to the boom...wants a topoff...says it should take about 4500 pounds...228.9
2207: PITMAN 35 disconnects after taking 4500 pounds, wishes the boomer a Merry Christmas...228.9
2207: PITMAN 35 back in the CAP established below FL 220 in the north...36 climbing to FL 230...260.9
2209: PITMAN 36 going to the tanker...260.9
2210: PITMAN 36 10 miles from the tanker at his three o'clock position after switching to boom freq...228.9
2214: PITMAN 36 established 2000 feet in trail with the tanker...6 clears her in to the boom...228.9
2216: PITMAN 36 connects to the boom...228.9
2218: PITMAN 36 disconnects from the boom after taking 5200 pounds...228.9....goes back to HUNTRESS...260.9
2239: PITMAN asks HUNTRESS to relay to their maintenance that 35 is Code 2 for Link 16 and 36 is Code 1...260.9
2241: TANKER 06 calls Guard Dog...request RTB in 10 minutes...135.525
2244: TANKER 06 tells HUNTRESS he's all set to go...PITMAN 35 says they're good with gas...260.9
2245: TANKER 06 asks for clearance back to Bangor (BGR) from Guard Dog...says their first fix will be DIMBY...ready to go in 5 minutes...135.525
DIMBY = 41-11-54.540N / 074-37-25.270W (New Jersey)
2247: TANKER 06 cleared out of the CAP by HUNTRESS...260.9...goes to Guard Dog for his clearance...cleared direct Bangor...and he's gone to handoff freq 134.325...comes back and says no one home on that freq and is sent right back there (134.325 = ZNY-Westminster Sector 9)...135.525
2250: PITMAN 35 asks HUNTRESS if they'll be cleared off as fragged...requests to start working his clearance...260.9
2250: PITMAN 35 calls Potomac...says he'll be ready to RTB in 10 minutes...135.525
2251: PITMAN 35 says they'll join up in 5 minutes, RTB in 8...135.525
2255: PITMAN 35/36 get in one mile trail preparing to leave...260.9
2257: Preparing to leave the CAP, PITMAN 35 reports 8800 pounds of fuel remaining, 36 has 9700 pounds...HUNTRESS clears them to RTB and they wish HUNTRESS a Merry Christmas...260.9
2258: PITMAN 35 to Guard Dog to pick up clearance back to Shaw...climbing to FL 240...cleared to Nottingham and then Raleigh-Durham...135.525
2259: PITMAN 35 requesting 2 miles front to back, non-standard formation...135.525
And the CAP is done for tonight...should resume at 0600 tomorrow morning.
2301: PITMAN 35/36 handed off to ZDC-Brooke 327.0 where they check in at FL 240
2301: PITMAN 35 tells 36 to go to V-12 and they check in on 139.925
2302: PITMAN 35 reports pushing it up to .95 mach...139.925...35 says he should get home with 3.0 (meaning 3000 pounds of fuel remaining)...36 says she'll make it with 4.6...36 says she's got the duty again tomorrow night....35 says he has it Christmas night
2304: PITMAN 35 tells ZDC-Brooke they'd like to stay 2 mile, non-standard if possible...they're cleared direct Raleigh...327.0
2309: PITMAN 35/36 handed off to ZDC-Blackstone 235.625 where they check in at FL 240
2312: Fuel checks...35 has 6900 pounds...36 has 7900 pounds and still feeding...139.925
2317: PITMAN 35 requesting direct Shaw when able...235.625
2321: PITMAN 35/36 get cleared direct Shaw...235.625
And that will be the last heard from them as they fly home.
THE END
Ref Mike below: Yes, 139.925 is their V-12...I just found it in my book.
THE END
