BM82557 said:
Yep, new notam FDC 6/8958 replaces 6/8739. Have they ever pulled one and re-issued before?
Yes, often. Even a minor time change of a few minutes results in a new NOTAM being published. When they publish the initial NOTAM early in the week before a VIP movement, it might change several times before the actual event.
1414: NIGHTHAWK 2 arriving Andrews for landing runway 19R...with Tower...118.4
This might have been MARINE 1 going north.
1440: AXEMAN flight back with Dover Approach...257.875...and on interflight for chat...142.3
1445: AXEMAN flight reporting to Raven Ops they're 10 minutes out and both Code 1...143.8
I didn't hear a reply from ground so don't know if they were heard.
1447: REACH 4126 to Dover CP with arrival message...20 minutes out, A-1, 1 pax to offload, need fuel, crew bus and parking spot...349.4
1449: AXEMAN 1 with Potomac TRACON 317.425...AXEMAN 2 with Dover Approach 257.875
AXEMAN 1 asking for the localizer to runway 15, circle to 33...not RNAV equipped....ceiling 1700 feet.
1450: AXEMAN 2 trying to call Raven Ops again...no joy...143.8
AXEMAN 1 and 2 had separated prior to the checkin with TRACON...they are now coming back together.
1452: TRACON hands off the AXEMAN flight to channel 4 (282.275 but no reply...back to 317.425 and ground tells them the controller is now listening...go back to channel 4 and they do to make contact)
Interesting that the TRACON controller is familiar with the Martin A-10's radio presets.
1452: AXEMAN 1 and 2 discuss viz at 2.5 miles and ask why they don't just use runway 15...good idea they decide and will...142.3
1456: TRACON has AXEMAN flight descend from 4000 to 2500 feet...then changes it to 3000...282.275
[U-4 for 282.275 and U-5 for 317.425 previously confirmed.]
1458: Both AXEMAN pilots report they're not getting DME info...142.3
1459: TRACON clears AXEMAN to the localizer and to 2500 feet....AXEMAN repeats that channel 44 is not working for the DME readings and wants TRACON to make a call to ALLDE to report it....ground confirms he'll do that...282.275
1502: TRACON tells AXEMAN they're over ALLDE now...282.275
ALLDE = 39-23-46.930N / 076-30-39.670W
1503: TRACON asks AXEMAN if they have DME now...nope, is the reply...282.275
1503: AXEMAN 1 says, "1700 feet my ass" with respect to the the low ceiling...thinks it's much lower...142.3
1508: AXEMAN pair very low feeling around for the runway...142.3...they land and no doubt head for Ops to ***** about the ceiling being reported at 1700 feet (but that was the latest ATIS report and could have changed considerably in the meantime.)
1509: JOSA 253 with arrival message to Andrews...A-1, has a code S-4 plus 2 Duty Pax with courier cargo to offload, needs 3000 pounds of fuel...will leave 1 hour after arrival and can free 5 seats on the outbound flight...141.55
1525: ?FOXY? 44 with arrival message to SAM Command at Andrews..."inbound your station"...IDs as a C-37, tail 01-0076, 3 crew members, no pax or cargo, needs parking, 5000 pounds of fuel, will RON at Andrews...141.55
1529: JOSA 253 in the pattern at Andrews preparing for landing with Approach...then cleared for approach to runway 19R...119.3
1531: Someone telling ADW Approach the base is at 500, maybe 550 (feet)...119.3
1532: JOSA 253 tells ADW Tower he's 7 miles out for runway 19R, gear down, full stop...cleared to land...118.4
1543: FOXY 44 (callsign much clearer on this freq...adding to callsign list) to Andrews to repeat aircraft type as C-37, tail 01-0076 asks if he'll park on 10 row and says he won't take his fuel tonight...will wait for tomorrow. Over the next few minutes he repeats most of his arrival message a couple of times...says they will do nothing tonight, will do it all tomorrow...just want to go get their rental car...378.1
1548: U/I aircraft, suffix 28, arrival message...349.7 (This is Shark Ops freq of the CT-ANG Bradley - only user I know of)
1610: REACH 5039 with arrival message to Andrews...(sounds like a C-130 with that distinctive turboprop engine whine in the background)...20 minutes out, is A-1, needs 20,000 pounds of fuel, parking and crew transportation...will need nothing tonight, will do it tomorrow...gets parking instructions for 11-Row...378.1
1621: REACH 5140 calling SAM Command at Andrews...no joy...makes it on second call...ETA 2140Z, A-1, offload 6 Space A pax, no cargo, requests parking spot, wants to know if billeting is on or off base...told to park in Row-13...378.1
1637: REACH 5140 in the pattern with ADW Approach...119.3
1649: EVAC 33118 (Prob a C-17 from Jackson MS) to SAM Command at Andrews with arrival message...30 minutes out, A-1, needs 30,000 pounds of fuel...has 17 litter patients, 27 ambulatory patients, 10 dependents...wants a quick refueling so he can head out to Jackson MS....378.1
1656: EVAC 33118 trying to call Andrews Metro...344.6 (No reply so he goes back to Griffin Command on 378.1 to ask them to have Metro come up on 344.6 so they can get a handle on this weather. He goes back to 344.6 at 1658 but apparently still gets no reply. NOTAM said they should be on duty until 2000 local time.)
1701: Apparently, CP controller on 378.1 tells EVAC 33118 to go try it now...EVAC 33118 again tries calling Andrews Metro a couple of times with the same lack of results...344.6
1703: EVAC 33118 goes back to 378.1 to say he still can't get anyone on the Metro freq...he wants them to go ask the Metro people about the ceiling at Andrews and if it's expected to get any worse.
1706: EVAC 33118 again asks ground to contact Metro about the ceiling...says it's at minimums now and wants to know if it's expected to get any worse...378.1
1708: EVAC 33118 gets the info he wants (doesn't repeat it so don't know what he was told)...378.1
NOTAMs for Patuxent NAS:
AERODROME CLOSED. 23 DEC 04:00 UNTIL 27 DEC 12:00
AERODROME HOURS OF SERVICE ARE 1200-2200 ZULU DAILY (0700-1700 LOCAL). 27 DEC 12:00 UNTIL 29 DEC 22:00
For Willow Grove:
AERODROME CLOSED FOR CHRISTMAS HOLIDAY DECEMBER 23-26.
AERODROME HOURS OF OPERATION FROM 27 DECEMBER 2006 TO 29 DECEMBER 2006 ARE 1300Z-2200Z.
KNXX IS NOT ACCEPTING PPR'S FOR THE 29 OF DECEMBER 2006 TO 02 JANUARY 2007.
For Oceana NAS:
AERODROME CLOSED FOR HOLIDAYS. 23 DEC 01:00 UNTIL 27 DEC 13:00
And at Andrews:
THERE WILL BE NO WEATHER PERSONNEL ON DUTY FROM 0100-0900Z, 22 DEC - 1 JAN. WEATHER PERSONNEL WILL BE ON DUTY FROM 0900-0100Z OVER THAT SAME TIME PERIOD. TRANSIENT AIR FORCE AND ARMY CREWS REQUIRING BRIEFING SERVICES ARE ASKED TO CONTACT THE 15TH OPERATIONAL WEATHER SQUADRON AT DSN 576-9755/9702. NAVY AND MARINE CREWS MAY CONTACT THE NORFOLK BRIEFING CELL AT DSN 565-2500 TO OBTAIN BRIEFING SUPPORT. 22 DEC 01:00 UNTIL 01 JAN 09:00 2007
(That includes the 344.6 Andrews Metro freq)
And all that tells us that next week will be a big, fat, zero for MilAir listening. Maybe some activity from Langley since the regular Air Force doesn't close - but does have very liberal leave policies over the Christmas/New Year holiday period. Expecting nada. We used to try to get all the married people off duty over Christmas and the single guys off at New Year. It was a plan that worked.
