TinEar
Here's the update for the CAP's TANKER 05...he's a KC-135R, tail 61-0276, from the 173rd Air Refueling Squadron NE-ANG based at the Lincoln Municipal Airport in Lincoln, Nebraska.
1757: PITMAN 33 and 34 getting ready to go home...33 reports he took 11,000 pounds from TANKER 04 and 6,000 pounds fromTANKER 05...34 took 12,000 and 9,000 from the two tankers. PITMAN 33 is Code 2 for multiple writeups and 34 is Code 1....260.9
1759: PITMAN 35 and 36 are refueling and are ready to take the CAP...260.9
1801: PITMAN 33/34 picking up clearance back to Shaw from Guard Dog (Potomac)...135.525
1805: PITMAN 33/34 handed off to ZDC-Irons...132.95
1810: PITMAN 33/34 get cleared direct Shaw...132.95
1811: PITMAN 33/34 handed off to ZDC-Blackstone and check in direct Shaw...235.625
1811: PITMAN flight leader tells #2 to switch to interflight Victor-8...and come up on 139.825
1831: PITMAN 35 going to TANKER 05 for fuel...260.9 (They are using primary 260.9 for a boom freq again)
1837: PITMAN 35 off the boom...35 now has 12,000 pounds in his tanks and 36 has 10,000...PITMAN 36 tells the tanker he'll wait 15-20 minutes before his AR...260.9
1931: PITMAN 35 and 36 have taken on gas from TANKER 05...they tell HUNTRESS they won't need gas for another 45 minutes or so if he wants to let TANKER 05 go home...260.9
1933: TANKER 06 calling HUNTRESS...260.9
1934: Looks like we've got a pair of A-10s from Martin State in the air on interflight...142.3
1035: It's a RAVEN flight that reports to Raven Ops they were off at 33 past the hour and the ceiling is at 1800 feet right now...347.2
1936: TANKER 06 calling HUNTRESS a few times, no reply...139.7 (Someone is answering him and giving him the correct freq to use)
1938: I'm hearing that open mic thing again on 136.725 (I thought this was the usual mistake the first time I heard it but this is three days in a row now someone has been doing this on this freq.)
1943: TANKER 06 makes contact with PITMAN 35 to swap squawks...260.9
1944: TANKER 05 leaving FL 240 for 250 so TANKER 06 can come in at FL 240...260.9
1945: TANKER 05 requestint FL 360 for the trip home from Potomac...135.525
1948: TANKER 05 tells Potomac he'd like to start working his clearance...he should be out of the CAP in about 10 minutes...135.525
1949: TANKER 05 gets his flight route back to Lincoln NE at FL 240...says he'll be expecting FL 360 later...135.525
1952: TANKER 06 just entering the Guard Dog area...there he is...it's a KC-135E, tail 57-1496, from the 132nd ARS ME-ANG based at Bangor International Airport in Bangor, Maine....260.9
1958: TANKER 05 handed off to ZDC and begins his trip home...135.525
2000: TANKER 05 reports leaving the airspace...260.9
2003: TANKER 06 reports dropping from FL 250 to 240 as he sets up for his track in Guard Dog...135.525
2005: AXEMAN flight of A-10s reports off the deck at 02 to Raven Ops...347.2
I'm starting to suspect the A-10s from MTN have changed their low band FM freqs. I used to hear them very often as they climbed out of MTN when they used those freqs - at least for a short time although they quickly disappeared from listening range on the low band. Over the past couple of months I haven't heard them at all and I know sometimes they've got to be using low band such as the AXEMAN flight that didn't show up in the 138-144 band.
2024: Apparently, PITMAN 41 is on his way to the CAP but 42 is going to be late...260.9 (I would have thought PITMAN 35/36 would have pulled a 5 hour shift until the end of the cap at 2300 but apparently they're going to split it up.)
2030: PITMAN 35 advises Potomac his flight is approximately 30 minutes from RTB...request either direct Shaw or J75 to Columbia and then direct Shaw...135.525
2033: REACH 3812 to Andrews with arrival message...0050Z is the ETA, says he's a returning airevac flight...378.1
2035: PITMAN 41 with ZDC-Irons heading this way...360.85
2036: RAVEN flight back in range on interflight 142.3 and just reported to Raven Ops they're 10 minutes out and both Code 1...347.2
2037: PITMAN 35 requests TANKER 06 do a north spin so 35 can top off...HUNTRESS agrees, TANKER 06 agrees...260.9
2038: RAVEN flight chatting about not wanting to go down to Avon Park (Range in Florida)...142.3
2039: Apparently, PITMAN 42 is in the air and 130 miles to the south (or that's what it sounded like...HUNTRESS is getting very noisy from here)...260.9
2040: PITMAN 35 tells 36 to hang out in the north and that he'd join on him after tanking...260.9
2042: PITMAN 41 handed off to Potomac 135.525 by ZDC-Irons...360.85
2042: RAVEN 1 with MTN Tower for approach to runway...297.2
2043: PITMAN 41 to Potomac at FL 230...he's cleared into Guard Dog...135.525
2044: PITMAN 35 tells 41 to stay in the south part of the CAP at FL 230...35 and 36 will stay in the north until 42 arrives...260.9
2048: PITMAN 35 on the boom...gives his tail as 91-390 and tail for 36 is 91-384...as 35 comes off the boom he reports having 11,300 pounds...36 reports 11,400 pounds...35 requests to join up with 36...260.9
2048: PITMAN 42 now with ZDC-Irons...360.85
2050: PITMAN 41 is given the BRA to TANKER 06 by HUNTRESS...260.9
2053: PITMAN 41 tells TANKER 06 he's in a one mile trail...260.9
2056: PITMAN 42 handed off to Potomac 135.525 by ZDC-Irons...360.85
2056: PITMAN 42 checks in with Potomac at FL 230 and is cleared into Guard Dog...135.525
2057: PITMAN 35 asks Potomac the status of their clearance to Shaw...says they'll be leaving in 5-10 minutes...135.525
2058: HOIST 98 (KC-10A McGuire) with arrival msg to McGuire CP...25 minutes out, A-2, has 4 pax and 2 pallets...319.4
2058: PITMAN 42 wants BRA to the tanker...and gets it...260.9
2057: PITMAN 42 checks in with HUNTRESS...260.9
2059: PITMAN 42 reports timber sour, energy sweet (meaning: the sumbitch ain't showing me diddly squat but at least it's lit up)...260.9
2101: PITMAN 35 requests clearance in about 2 minutes to J75...wants 2 mile trail with a separate squawk for PITMAN 35...135.525
2103: PITMAN 35 tells HUNTRESS low man has 10,200 pounds and they're both Code 1...260.9
2103: PITMAN 35 tells Potomac they're ready to go...135.525
2104: PITMAN 42 in one mile trail with the tanker...260.9
2105: PITMAN 35/36 cleared to the J75/Columbia/direct Shaw route at FL 220...135.525
2105: PITMAN 35/36 handed to ZDC-Montebello and check in at FL 220, 2 miles non-standard...284.7
PITMAN 35 tells #2 to open Victor-8 for interflight which should again be 139.825...and is.
2109: Raven Ops repeats a message from AXEMAN that he's 10 minutes out and Code 1 (I hear the ground but not the aircraft on this one...strange)...347.2
2110: PITMAN 42 off the boom so both new F-16s are now refueled and ready to fly circles...260.9
2110: PITMAN 35 asks 36 if he's flown NVG recently..36 tells him awhile ago but not since (not sure what that means)...139.825
2111: TANKER 06 tells Potomac he's an E type KC-135...135.525 (But we knew that because I posted it at 1952)
2113: PITMAN 41 and 42 both report timber sour...HUNTRESS gives them a time hack to make sure they're in synch...still nada so HUNTRESS tells them to re-synch...260.9
And everything is now settled down and it should stay quiet until the end of the CAP at 2300.
2131: TANKER 06 tells Potomac he'll be ready for clearance home about 0245Z...135.525
2136: Air Force 2 with Andrews Tower for landing on runway 1L...cleared to land...118.4
2151-58: REACH 273 calling McGuire CP...no joy...319.4
2202: REACH 278 makes contact with McGuire at last...arriving 20 past the hour, A-1, has two pax and no cargo...need parking...319.4
2230-ish: PITMAN 41 and 42 refuel for the last time with TANKER 06...260.0
2239: TANKER 06 contacts Potomac and says he'll RTB in about 10 minutes...135.525
2248: TANKER 06 tells Potomac he's ready to leave the area and requests FL 290...cleared to 250 for now and course 340 degrees...135.525
2250: TANKER 06 handed off to ZDC and we say goodnight and goodbye to him...135.525
2251: PITMAN 41 tells Potomac they'll be ready to RTB in about 10 minutes...135.525
2254: PITMAN 41 reports Code 1 and 7500 pounds of fuel remaining...42 is Code 1 with 9700 pounds...260.9
2259: PITMAN 41/42 released to RTB by HUNTRESS...260.9
2259: PITMAN 41 to Potomac for clearance and are handed off to Potomac on 350.25
2259: PITMAN 41 tells wingman to go to Victor-8 and come up on 139.825
2300: PITMAN 41/42 handed off to ZDC-Irons and check in there...360.85
2303: PITMAN 41/42 cleared direct Shaw...360.85
2303: PITMAN 41/42 chat happily away as they fly south toward Shaw...we'll say goodbye to them too...139.825
Early bird special...CAP starting again at 0600.
Ref below: Nice picture Paul. I posted that about 10,000 messages ago but someone has added the blue sky and clouds to it since then. Nice job. That interactive site is great for learning the layout of the F-16 cockpit.
Ref below below: Travis, we had AF 2 go out this afternoon in the 1500 hour so it might be him coming home causing the ramp freeze. (Edit: And it is...log item at 2136)
