Sticky Thread For MilAir VIII (2013)
BM82557
Berkeley Co WV
Tankers active
Kind of surprised to see these up considering the weather in the Mid-Atlantic -
AE0487 62-3556 K35R KC-135R > 18:15:17 25100' DECEE41
AE0160 57-1479 K35R KC-135R > 18:15:22 23900' DECEE42
screenersam
I hate motrbro
Somerset County, MD
are we starting a 2014 sticky?
Darkstar and Bullseye working 139.7 since about 0830 this am. I can hear them, didn't go outside for the visual. Brrr.
Tech792
Central NJ
yes we should...sticky for 2014
01/14/14- 1414 local- Had ROMA 21 (flt x 2) passing through ZNY 282.3 (After doing a quick search, ROMA might be associated with a Coronet flight)
nyair1
Saw this in another board -
It was Rama 21 flt of 2 B1's heading back to Texas
nyair1
Colt Flt 1/14
301.600 - Steel 71 AR with Colt 01 flt of 2 in the Duke MOA
293.200 - Colt flt a/a
353.850 ZOB - Colt 01 flt climbing to 15,500 to seperate from tanke. Would like to delay at out Tac Range and then VFR to M-T-N
338.300 ZNY - Colt 01 flt of 2 Alpha 10's VFR at 15,500
nyair1
Colt Flt 1/15
301.600 - Sluff 62 AR with Colt 01 flt of 2 in Duke MOA. 3K fuel for each
271.400 - Colt 01 flt a/a
353.850 ZOB - Colt 01 flt at 15,500 for exit out of Duke MOA
338.300 ZNY - Colt 01 with you at 200
269.100 ZNY - Colt 01 flt level 200 non-standard
SOSull66
Monmouth County NJ
McGuire is busy tonight. Activity on 139.875. And on the AR777 freq. 315.9
a large tanker has been making loops over the house. He's very low tonight and he's making much higher than normal angle banks. It looks pretty cool since the clouds are low and he's just on the bottom edge of the clouds.
jkahn
Very good looking Member
Silver Spring MD
Just curious. What are you guys monitoring on, radio only or radio with something like ACARS attached on a computer? I am in flight path for inbound Andrews JB and would like to monitor occasionally.
I could use the HP-1 with record on, or an older (very older!) 100 ch scanner just programmed with air freqs.
Any suggestions for a old scanner who is very newbie to listening to air bands.
JK :)
screenersam
I hate motrbro
Somerset County, MD
JK :)
I don't have one myself but I unnerstand there's a separate acars decoder.
these guys ACARS - Free ACARS decoder for Linux & Windows - acarsd
giving away a computer program that apparently decodes.
we started a 2014 sticky so you might want to ask there. good luck
info on pc ops http://wiki.radioreference.com/index.php/ACARS I suggest read this one first
pro106import
Milford, Ct. perched high above Long Island Sound
hearing Wild aircraft (F-16's from Andrews AFB DC) on 143.600 - at least 3 aircraft
maybe en-route to NJ?
Bob
--- I don't usually cross post, but I also posted this info on the NJ forum under the super bowl thread. Most reading that thread would not normally know much about the milair thread here.
edit- just a dogfight- not superbowl related
on 339.725 now
