1000 hour:
The first fighter activity of the day appears when a flight of A-10s from Martin State take off. Callsign RAVEN. They are currently using squadron freq 142.30.
There are a couple of aircraft working in the Pax River (BayWatch) area but are U/I for now.
WARDOG (OA-10 Martin State) off the deck at 1037 with Raven Ops on 347.20.
Trooper 1 (as Lifeguard Trooper 1) clears into the Aberdeen area for medevac landing with Phillips AAF on 126.15 at 1047.
Guard helo 22322 with Weide AAF on 126.20 and 229.40 for landing.
JOSA 964 (C-12) off the deck at Andrews at 1050.
Army 01052 (home based Andrews) 10 minutes out from landing at Andrews at 1052. Ops on 141.55.
WARDOG is at the Kiowa Range on 237.20 and will be working there against MANPADS and SA-3s. He'll take out the radar first. He's working with controller VENOM but complains to BALKY (Range Controller at Kiowa) that he can't hear VENOM. VENOM has been heard before as a controller at Kiowa in conjunction with A-10s from the PA-ANG.
1100 hour:
The other A-10s from Martin State (RAVENs) are now arriving at Kiowa at 1103 and WARDOG is giving them their missions. This WARDOG pilot is a hard charger. He's good. Activity still on 237.20.
At 1105 Lifeguard Trooper 1 clears out of Phillips AAF territory on 126.15 and requests freq change.
The two RAVENs are done at Kiowa at 1117. WARDOG tells them to scoot on home and make the flight reports. They contact Raven Ops on 347.20. WARDOG stays at the range.
1120-1135 sees fighters in the BayWatch area on 270.80 and 354.80. Believe we've got SALTY DOG there.
At 1138 WARDOG finishes ar Kiowa. Sounds like he wants to stay but is "Winchester." Damn...he's a good pilot. He switches to a Harrisburg squawk for clearance to go home. He checks in with Raven Ops 347.20 at 1143.
1200 hour:
GOPHER 1195 (C-130H 109th Airlift Squadron MN-ANG Minneapolis-St. Paul) arriving at Andrews. He's going to upload 14 pallets, 1 vehicle and some loose items and wants 80,000 pounds of fuel. Freq 378.10. Pilot seems concerned about the weight of all that cargo.
COLT 45 (A-10 MD-ANG Martin State) coming home on 347.20 (Raven Ops) and 297.20 (Martin State tower).
At 1220, PAT 636 (C-12 US Army Priority Air Transport Andrews AFB) will be landing at Phillips AAF. Freq 126.15. He wants to make sure the runway is swept of deer. This must be a problem at Phillips. I've heard this request many times. He's on a final approach at 1232.
1230: Something-524-Charlie clears through Phillips AAF airspace on 126.15. Difficult to understand with a heavy Arabic (or Farsi or Urdu) accent.
1250-55: REACH 5033 (Contract passenger acft to Air Mobility Command) tries and tries to communicate with McGuire Command Post on 319.40. Finally makes contact when 15 minutes from landing. Dropping off 9 pax, no cargo.
SALTY DOG 122 (Prob F-18 Strike Aircraft Test Squadron at Pax River) contacts BayWatch on 354.80 to enter area.
1300 hour:
VENUS 44 (99th Airlift Squadron Andrews) arriving home. Only request is for a crew bus for three crew members and to advise the 99th SOF of his arrival. On 141.55. Ground station loud and clear.
Aircraft EVAC 126 follows on 141.55 announcing takeoff from Andrews.
323 (possibly another SALTY DOG) in BayWatch area on 354.80 and 264.55 at 1310.
REACH 1298 calls Andrews on 378.10 for three minutes before getting a response - then just announces his takeoff from Andrews as at 1718Z.
I'm submitting a bid to Andrews Comm Directorate to solve thier comm problem on 378.10. My bid is for a meager $13,876. If accepted, I'll hand them a box with a wide band discone inside it.
REACH 4128 tries contacting McGuire CP on 319.40 several times without success 1330-1336. Contact at 1337...1 pax, no cargo, needs parking space, A-2 maintenance status.
Raven Ops (347.20) talking to WARDOG on the ground at Martin State at 1336. Possible flight of A-10s upcoming.
PAT 636 mentioned earlier arriving Phillips AAF, leaving there at 1351.
1400 hour:
Guard helicopter 22978 with Weide AAF inbound on 126.20.
JOSA 297 off the deck at Andrews 1804Z (378.10).
At 1419 a u/i aircraft leaving BayWatch 270.80 to land at Webster NOLF (Naval Outer Landing Field). Two minutes later he has Webster in sight. Webster tower on 126.20 and 358.00.
At 1440 TESTER 13 (USN Test Flight School) checks in with BayWatch on 270.80.
Overall, a very quiet hour - much more so than normal for a sunny day over the entire listening area.
1500 hour:
TESTER 13 still whipping around the Pax River area. Announces at 1505 he'll be doing vertical maneuvers for the next several minutes. At 1509 he decides he's had enough and announces RTB.
At 1512, FLYER (A-10 PA-ANG Willow Grove) arrives at Kiowa Range on 237.20 and announces he's in a flight of three aircraft.
JOSA 964 coming home to Andrews, tail number 84-0125, home based at Andrews, no pax, no cargo, no fuel needed, 15 minutes out at 1518. Took off earlier at 1050 per mention above.
1525: JOSA 272, C-21, tail number 40073, home based at Andrews, 20 minutes out, no pax, A-3 maintenance status for a broken radar. Wants maintenance guys notified of problem.
EVAC 636 off from Andrews on 141.55 at 1525.
At 1534 three A-10s from Martin State coming home on freq 347.20 with Raven Ops, callsign COLT 1/2/3. Two have Code-2 maintenance problems, and one is Code-1. The problems are a Weapons Safe indicator on one and a PAVE PENNY problem on another. The PAVE PENNY system is a laser tracking pod. It doesn't produce a laser, just tracks one. On the pictures of an A-10, it's the pod hanging off the right side below the pilot's canopy. They switch to Martin Tower on 297.20 for full stop landings at approximately 1546 for the first of the three landings. One of them is still 10 minutes out.
F-16s from VA-ANG up at 1545 on 139.625. Clearing into the GIANT KILLER area on 249.80 at 1548, then onto 292.30...missed callsign.
1554 a flight of three TORCH (F-15s Langley AFB) enter GK's area on 249.80, then 373.10 and 391.20.
1557 flight of three CAVE (F-15s Langley) enter GK's area on 249.80....can't hear GK, switching to 391.20 to try it again. One of the CAVEs has a problem and will RTB. The CAVE flight will not be ready to start the exercise at 10 after the hour as planned. TORCH flight is ready.
1559 flight of ROCKY (F-15s Langley) enter GK's area on 249.80.
Looks like the skies off the VA and NC coasts will be busy for the next hour or so.
1600 END OF REPORT
