TinEar
Second half of the 2000 hour finds the CAP still in place. HARASS 45/46 have the duty and are being assisted by TANKER 07. At 2038, HUNTRESS told HARASS 45 their replacements, HARASS 47/48, were airborne and flying to the area. Primary freq for the CAP is still «228.9» and it's also the primary boom freq for refueling. At 2050 HARASS 47/48 arrive in the CAP and do a boom check as the first order of business. They checked in along the way from Langley to the CAP with ZDC-Calvert on «281.4». HARASS 45 and 46 are given the okay to RTB. 45 reports Code 3 for a left engine afterburner problem and 46 is Code 2. (Broken down old F-15s). HARASS 45/46 use tac «276.675» for chat on their way home. At 2059, HUNTRESS asks HARASS 47 for a PIREP and is told there is a solid cloud deck over D.C. but the rest of the CAP is okay.
2105: HARASS 45 flight with ZDC-Calvert on «281.4» on their way home. Report leaving 21,000 for 10,000 and says the flight is 10 miles north of HARKUM (or is it HARCUM? I've seen it spelled both ways on supposedly official documents recently.)
By the way, HUNTRESS is extremely loud and clear today - more so than I've ever heard them.
2110: HARASS 45 with Calvert says they'll be direct Langley after passing HARKUM. «281.4»
2111: Have Langley tac «228.175» active. Not sure which pair of HARASS fighters this is. 45/46 were getting weak on the last freq when they got down to 10,000 feet and this guy is as loud as 47/48. Of course, he gave his ID before I got on the freq.
Is it Christmas yet?
2209: HUNTRESS tells HARASS 47 that RENEGADE is coming over to the freq in a few minutes to get a "time check." «228.9» (RENEGADE is one of the controllers we hear on the Customs freqs when they do a scramble for an ADIZ violator.)
2234: And still no RENEGADE has appeared on the CAP freqs.
2236: HUNTRESS calls HARASS 47 and does a "time check" which doesn't sound like a time check - just a bunch of numbers. He then tells him he can get back in the net with ?NCR? «228.9»
[[After thinking about this, I don't think RENEGADE was expected to do any kind of voice check. I believe all of that meant he was going to sign onto the DATALINK net and synch his time with everyone else.]]
2243: HARASS 47 reports back in the net but is getting no tracks from HUNTRESS. «228.9» HUNTRESS says the only tracks he's pushing right now are the players - the two F-15s and the tanker. 47 says he has nothing...just the same as before he did all the resets. HUNTRESS says he doesn't think he's going to get it fixed tonight and 47 says that's okay because he can see his wingman and the tanker so they're good to go. He adds that maybe Santa will bring HUNTRESS a new terminal. HUNTRESS has nothing to say to that. «228.9»
2303: TANKER 07 calls HUNTRESS to ask if he has any word on his replacement. HUNTRESS, of course, says to stand by. (And goes back to his sandwich.) «228.9» HUNTRESS actually comes back a minute later to say he doesn't see him on his scope but tells 07 he's due to be off station by 0457Z (1157 local) And TANKER 07 seems satisfied to be told he's due to go home when he's due to go home.
2331: HARASS 47 calls TANKER 07 to ask how much gas he has. 07 responds that he has all they need. 47 tells 48 to switch to B.S. (First time I've ever heard them refer to the chat channel for what it is...B.S. channel.)
2331: HARASS 47 and 48 on their tac/chat/B.S. freq «228.175» to talk about refueling and deciding who'll go first to the tanker.
2335: HARASS 48 asks for clearance to the tanker. HUNTRESS tells him to go for it. «228.9» 48 reports his weapons are on "safe."
2336: TANKER 07 clears HARASS 48 to contact the boom. «228.9» 48 tells the tanker he wants about 6,000 (pounds of fuel).
2338: 48 has contact with the boom. «228.9»
Seems all the recent CAPs have used the primary freq as a boom freq. It sure makes it easier than switching back and forth to a secondary freq for refueling.
2341: TANKER 07 tells 48 he has given him 6,000 and asks if he wants more. 48 tells him to give him another 1,000. «228.9» About 20 seconds later the additional 1,000 pounds has been transferred. 48 breaks contact with the boom and tells HUNTRESS he's back on station. HUNTRESS nods and says okay.
2342: HARASS 47 heading for the boom and says he wants 5,000. «228.9» 07 clears him to contact the boom.
[[The F-15s use about 6,000 pounds of fuel per hour of flying. The KC-135 tanker uses 10,000 per hour.]]
2344: 47 tells 07 he sees fuel spilling out of the boom. 07 asks if it's from the nozzle and 47 concurs. 07 tells him to try reconnecting to the boom. He adds that he can't see it real well from his position - he just sees a spray. So 47 reconnects and then says it looks like the gas is going in fine. At 2345, 07 says he has given 5,000 and ask if he wants more. Nope, is the answer and so 47 breaks off the boom and tells HUNTRESS he's back on station. «228.9»
2355: TANKER 07 asks about the status of his replacement. HUNTRESS tells him that TANKER 08 is airborne and is about 200 miles out. «228.9»
[[I wonder what the HARASS numbers will be that replace 47/48. It shouldn't be 49/50. Will it be 51/52 or will they start over at 31/32? I won't know because I should be long gone by the time they show up...I think.]]
0008: TANKER 08 shows up in the CAP and makes contact with HUNTRESS. He's told to hold angels 25 (25,000 feet). TANKER 07 told he can RTB and to go to GUARD DOG to clear out. He says he'll go to VHF and do that and wishes everyone a Merry Christmas. «228.9»
0008: TANKER 07 contacts GUARD DOG on «135.525» and says he'll take the Indian Head heading to clear out of the CAP.
0009: HUNTRESS gives the Mode 3 of HARASS 47 as 5342 and 48 as 3612 to TANKER 08 «228.9»
0012: TANKER 07 repeats he's changing to ZDC frequency 134.15 and wishes this controller a Merry Christmas too. «135.525» [Goodbye 07. I'm not chasing you through the VHF Center freqs.]
0014: TANKER 08 with GUARD DOG on «135.525» is given altitude block 22 to 25,000.
0015: TANKER 08 tells HUNTRESS that if 07 is cleared out of the area, he'd like to descend from FL250 to 240. HUNTRESS tells him 07 is cleared out to the north and he's free to descend. «228.9»
0018: HUNTRESS asks HARASS 47 if he'll do a quick boom check with TANKER 08. 47 says of course he will. HUNTRESS gives him the BRA to the tanker. «228.9»
0024: HARASS 47 reaches TANKER 08 and closes in on the boom. The boom operator says with some alarm, "WATCH YOUR CLOSURE, WATCH YOUR CLOSURE." Not sure what 47 did that caused that. Anyway, 47 connects with the boom and takes on 1,000 pounds. He gives his tail number to the tanker as 83-0024. Then he reports off the boom and tells HUNTRESS he's back in the CAP. «228.9»
0027: HARASS 47 and 48 go to the B.S. channel on «228.175» and 47 tells 48, "What a moron that boom operator is." Then 48 makes fun of his "Watch your closure" holler. So they have their fun and that's it for now.
0032: HUNTRESS calls HARASS 47 to tell him their replacements are airborne and that he'll check the weather for home plate (Langley). «228.9» He also tells them to maintain a position in the north part of the CAP.
[Guess I will find out which numbers the replacements will use.]
0034: HUNTRESS asks 47 what altitude he'd like his relief to come in at. 47 says to have them come in at 21,000. «228.9»
0035: HUNTRESS gives the Langley wx and reports the temp is 43 degrees. Nothing out of the ordinary. HARASS 47 and 48 both report being Code 1 maintenance status. «228.9»
0036: HARASS 51/52 with ZDC-Woodstown on «363.0» checking in at FL230 and are given altitude block 21-25,000 in the CAP. (No idea why they used this freq. Maybe ZDC-Calvert closes the 281.4 freq at midnight and combines on 363.0.)
0037: HARASS 47/48 with GUARD DOG on «288.35» to say they'll be leaving in about 5 minutes. They'll go to Nottingham and then direct Langley.
0038: HARASS 51 and 52 check into the CAP with HUNTRESS on «228.9»
0041: HARASS 51 does an Alpha check on the bullseye and his data matches what HUNTRESS sees on his scope. «228.9»
0042: HUNTRESS gives HARASS 51 the BRA to TANKER 08. «228.9»
0043: HARASS 51 and HARASS 47 go to «228.175» and 51 says 47's radar is f***ed...he's right on his nose and doesn't know why he doesn't see him. 47 shows him 5 miles off but 51 again says that's f***ed up, he's right on his nose...look out the window and you'll see me. 47 ends that conversation in a hurry.
0045: HARASS 51 gives the Mode 3 and tail numbers for himself and his wingman to TANKER 08. I was across the room without a pen and didn't write them down so no report on them. Anyway, they're on the way to the tanker for a boom check. «228.9»
Over the next several minutes 51 and 52 hit the boom for fuel. Meanwhile, HARASS 47 and 48 also use ZDC-Woodstown on «363.0» on their flight home to Langley. That brings us to 0055.
0104: HARASS 47/48 call IRON Ops on «357.1» to report both are Code 1 and ar 50 miles out.
Okay...I've had enough. Wanted to stay to see the replacement numbers and have. So that'll be the end of this log for tonight. HARASS 51 and his foul mouth could get interesting though if there's any screwups or pressure during his flight. Till later....
I forgot to mention that earlier today when HARASS 42 was held on station in the CAP because 44 couldn't find a working aircraft to replace him when due, 42 had a big worry. He was out of "piddle packs." (Yeah, you can figure it out without me explaining it.) I had already turned off the PC so couldn't log that little exchange. Everyone listening to the conversation had a good laugh about it, including me. Even 42 laughed on the air but it's the little things like that you don't think about when listening to those guys fly circles for hours and hours. I've never figured out what female fighter pilots use or how they use it. Guess I'll have to ask one of them..........or maybe not.
