1000 hour: 28 degrees and partly cloudy at BWI airport
Will only have limited time today to monitor MilAir activity.
1047: Langley fighters (x2) on tac freq «228.45»
1047: NJ-ANG F-16s (x2) with SOF on «138.125» giving mission report
1049: NJ F-16s chat as they approach runway 31 at Atlantic City for landing
1057: JOSA 871 reports takeoff time from Andrews as 1553Z to SAM Command on «378.1»
1102: Have «138.3» tac freq active -- probably A-10s from the PA-ANG at Willow Grove. They mention coming up on KIPT which is Williamsport Regional Airport in PA. They sound more like F-16s than A-10s now.
1105: Yes...the aircraft on «138.3» are F-16s from the NJ-ANG at Atlantic City.
1105: They 138.3 pair say to switch to V-15 and come up on «138.425» which should confirm NJ-ANG. Callsign is DEVIL.
1106: DC-ANG at Andrews has F-16s airborne on tac «127.275»
1107: DC-ANG is an ANGRY flight...they are just coming home to Andrews and switch to Andrews GCA on «335.5» and are descending.
1107: ANGRY 1 reports at 4,000 feet «335.5»
1107: Northrup-Grumman flight up on «123.225» and say they are heading for home (to BWI).
1111: ANGRY flight with Andrews Tower on «349.0» Landing on 1R and have runway in sight.
1112: BASH 61 flight (F-16s VA-ANG Richmond) with ZNY-Millville on «323.3» and reported direct Nottingham. It looks like a flight of three aircraft.
1115: Navy 375 landing at Andrews on «118.4»
1116: BASH 61 from FL260 to 230 and switching to ZDC-Swann on «360.7» where they check in and are told to descend to FL210
1120: BASH 61 flight to ZDC-Calvert on «281.4» down to FL210 and going to 200.
As this flight comes through the area, the callsign sounds like it may be FAST rather than BASH. If so, they're F-16s from the NY-ANG at Syracuse.
1124: FAST/BASH 61 flight expediting down to 15,000 and looking for traffic.
1125: Have a FAST/BASH 63 flight behind the first group and now going from the ZDC-Millville «323.3» freq to ZDC-Swann on «360.7»
1126: FAST/BASH 61 leaving FL150 for 10,000 «281.4»
1127: DEVIL 11 flight of two F-16s sound like they're in the BayWatch area. Still working tac freq «138.425»
1129: FAST/BASH 63 while on «360.7» is sent to ZDC-Calvert on «281.4» where he checks in at FL230. Leaving 230 for 190.
1133: FAST/BASH 63 reports 10 miles north of HARKUM. «281.4»
I've had a radio searching through the 138-144 range looking for a tac freq for the FAST/BASH flight but have found nothing. Either they aren't chatting or they have a tac freq outside that range as many units do - like DC with their 127.275 tac freq. In any case, that transmission at 1133 was the last I heard from the flight. They were sent down to 10,000 feet so they are probably out of listening range. Color them gone. That callsign could even have been BASS which would make them A-10s from the CT-ANG at Bradley.
1135: Have the RAVEN flight coming home and in contact with Raven Ops on «347.2» where they report being Code 1. (Thanks Dave for the heads-up)
1145: NJ-ANG F-16 DEVIL flight still working down this way attacking targets of interest they find in the area. Currently, they are searching for a car to attack. One is below 10,000 feet and the other is staying above 15,000. DEVIL low picks a white car getting off the highway onto a cloverleaf intersection. They have him in their pods and are ready to blow him all to hell (simulated of course). They messed something up in their targetting pods so the white car gets a pass and they're looking for another target opportunity. Still all on tac freq «138.425»
1148: RAVEN flight headed into Martin State with Tower on «297.2»
1151: Have another flight of NJ-ANG F-16s in the area using tac freq «138.875» and also in ground attack activity. Callsign BANGER
1208: DEVIL flight still on tac «138.425» and still having trouble attacking moving targets. The problem rests with the altitudes they're using for acquiring and tracking a small, fast-moving target.
1209: The DEVIL flight is getting low on fuel so are joining up for a flight back to Atlantic City.
1210: The other NJ pair on «138.875» is also calling it a day. Callsign BANGER
1211: DEVIL 11 flight with ZDC-Kenton on «277.4» 30 miles west of Waterloo at 11,500 requesting direct Atlantic City and mentions flight following.
1212: DEVIL 11/12 both Code 1...12 is cleared off freq for ATIS info and to report status to Devil Ops «138.425»
1212: BANGER flight reports both are Code 1 «138.875»
1215: Have a U/I flight....???? 1 reports losing #1 engine, declaring emergency and returning to Andrews «257.2» Reagan TRACON
1217: ???? 1 leaving 3,000 for 2,000...has field in sight «257.2» They report they have five hours of fuel on board and will stay on Uniform freq.
1218: ???? 1 will use runway 1R at Andrews «349.0»
1219: BANGER flight with Atlantic City Approach on «327.125» A couple of minutes earlier while I was listening to the emergency, the DEVIL flight reported in on the same freq heading for runway 31 at Atlantic City.
1220: ???? 1 reports gear down and locked for right side (right side meaning runway 1 Right) «349.0»
He only used his callsign one time while on 257.2 which is why I can't fill it in. All I caught was the suffix 1. It wasn't one of the normal JOSA/VENUS/PACER/REACH callsigns. He apparently made it in safely and I heard nothing further after the gear down and locked transmission.
1231: Now have a U/I aircraft with Dover Tower on «279.625» reporting a brake malfunction indication. He says procedures call for a runway sweep (runway 32) for this problem and he says it should be done. He was apparently asked if he's declaring an emergency and says, "No. We're pressing on." (Nothing further heard from him)
1239: SALTY DOG 423 with Norfolk TRACON on «370.925»
1254: Have had an aircraft on Pax River freq «350.9» for about the past hour doing flight testing maneuvers. He has not used a callsign in all that time - just a suffix 05 - which makes him look like a TESTER callsign.
1255: REACH 320 calling HUNTRESS on «364.2» reporting FL290.
1257: REACH 320 to HUNTRESS reporting again at FL290 and just east of New Jersey requesting a Mode 4 and parrot check. «364.2»
1259: ?TESTER? 05 reports his activity is done and he sees the field «350.9» And now as he finishes he confirms his callsign as TESTER 05.
1300: Break time...will be back later with more if MilAir is active.
