TinEar
2335: BRAVE 61 and 62 (F-16s DC-ANG Andrews AFB MD) up in a scramble - probably as part of an exercise. «139.7»
2337: OMAHA 3 (Customs) up with HUNTRESS on «260.9»
2337: BRAVE flight talking with CAPITOL on «139.7» CAPITOL is back at their HQ. They've been given a target by HUNTRESS.
2340: HUNTRESS gives a "skip it" command and gives a BRAA for a new TOI to the BRAVE flight. «139.7»
2342: BRAVE changes to callsign ALERT 1 and is sent to TRACON «269.5» where he explains he's got a "real world target but it's an exercise."
2344: OMAHA 03 repeats he was given a "bug out" command. «260.9»
2344: BRAVE describes the target as a Citation business jet. «139.7» He then changes back to ALERT 1 (putting on his magic cape) and reports he has no luck in head butting the TOI away.
2347: ALERT 1 tells Reagan TRACON he's sticking with the target for a few more miles. «269.5» He had to go out of the CAP area to chase this target is why he has to check in with TRACON.
The BRAVE pair is flying the GUARD DOG CAP track for this exercise.
2348: HUNTRESS gives the "bug out" command to ALERT 1/BRAVE 61 to the south. «139.7»
2348: ALERT 1 tells TRACON he's going back to the CAP in one minute. «269.5»
2351: OMAHA 3 with HUNTRESS on «260.9» He doesn't seem to be doing much.
2352: BRAVE 61/ALERT 1 to GUARD DOG on «288.35» to report going back into the CAP.
2355: HUNTRESS tells the BRAVE flight to come up on the JADOC Gateway and BRAVE reports going to GAT KEY 5, channel 54....and other stuff I don't have a clue about. «139.7» BRAVE 61 tells 62 to come up on the 72X air to air ???.
2357: BRAVE 61 and 62 both report timber sour...recycling the DATALINK. «139.7» They then do a new alpha check on the system and get the bullseye (bearing/range.)
2359: HUNTRESS tells BRAVE flight to expect OMAHA 3 to come up with them. «139.7» All these GAT KEYS and channel numbers are apparently on the DATALINK.
0000: OMAHA 3 comes up with HUNTRESS on «139.7» after being told on «260.9» to switch to VHF.
0000: BRAVE flight is going to try GAT KEY 6 on their DATALINK since they are again "sour" «139.7» The new key worked and they are again "sweet" on the system.
0005: HUNTRESS asks OMAHA 3 his flight time remaining and 3 tells him he has about 3 hours of gas left. «139.7» (I'm not staying up until 3 a.m. Are you? I've got a DirecTV guy due here at 8 a.m. to install my HD equipment.)
0009: Not much happening at the moment...HUNTRESS/BRAVE just BSing.
0010: OMAHA 3 wants to know when the next scenario will start. HUNTRESS says NOW! «139.7» Sure enough, BRAVE reports they have a target on the DATALINK. OMAHA 3 is given the BRAA to the TOI.
0015: BRAVE 61 turns into ALERT 1 again and gets cleared to chase the target on GUARD DOG freq «288.35»
0016: OMAHA 3 reports sighting the target «139.7»
0017: OMAHA 3 gets cleared by Reagan TRACON «269.5» to chase the target and ALERT 1 does the same with BWI TRACON. OMAHA reports on the wing of the target «139.7» ALERT 1 reports TOI is a low winged, 2 engine jet....HUNTRESS tells him to head butt him north. «139.7» OMHA 3 is on a different target...he IDs as a Cessna 172 or 180 hi wing single engine.....ALERT 1 requests use of flares on his target due to non response. OMAHA 3 told to bug out north. ALERT 1 eventually given the bug out command too.
Both the BRAVE F-16s and the OMAHA 3 are back and forth to TRACON freqs each time they chase a target.
0022: OMAHA 3 wants to RTB because he doesn't have a decent aircraft...wants to know if there's another scenario....HUNTRESS sends him away and OMAHA 3 thanks him. He changes to Reagan TRACON on «269.5» to report going back to his nest at Reagan National (DCA).
0038: After a long silence, HUNTRESS asks BRAVE61 if he has any targets showing. 61 has one of his own. «139.7» Almost immediately, BRAVE 61 reports the track is gone.
0044: BRAVE 61 sees a new target on his datalink...HUNTRESS agrees «139.7» and he has a second suspect aircraft...HUNTRESS shows the same on that one too.
0048: HUNTRESS tells BRAVEs to "skip it" on this latest target. 62 reports he sees 2 suspects. HUNTRES gives the authentication for his "skip it" command. New mission coming up....wants a head butt to the west.
0052: ALERT 2 requests use of flares «139.7» After a couple of requests he's told by HUNTRESS to bug out. He does at 0056.
0057: BRAVEs/ALERTs aircraft sent back to the CAP for a new mission by HUNTRESS «139.7»
0101: BRAVEs report 15 and 30 minutes respectively of playtime left (running low on gas) «139.7»
0108: BRAVE 62 headed home...61 is going to stay up another 20 minutes. 61 asks CAPITOL back at Andrews if they're going to get new jets or stay with what they've got for the next mission. They should be up again in about 3 hours...but I'm not staying with them. I've had enough for tonight. «139.7»
0112: BRAVE 62 with TRACOn on «269.5» and then with Andrews Tower on «349.0» and has gear down for landing.
Goodnight everyone.
(Reply to below): Russ, that's the BWI TRACON.
And, yeah, he was unhappy with that helo...didn't like it at all. Bet when he gets back to National he's going to ***** to everyone in sight.
Good catch Russ on that Civil Air Patrol flight. That's probably the target that OMAHA 3 was describing as the Cessna 172 or 180 "or something like that." I haven't heard the VENUS (or whomever) flight that the BRAVEs went after.
Goodnight everyone.
