Some of the proposed categorization comments in this thread do not square with the actual operations and structure of the entities under discussion, or with the practices and thought processes of scanner listeners. Some are linguistically ambiguous.
For example:
Also, something I noticed, and don't have time to play with right now, is that maybe there should be another category added called "Aircraft Monitoring Frequencies", as a child under "Aircraft Monitoring" and "Wiki Frequencies"
Monitoring is not a function of many of the agencies we scan. That is what we hobbyists do.
Aircraft Monitoring Frequencies = Frequencies used by people who monitor aircraft. This would be a set with zero members.
On the other hand, Railroad Monitoring Frequencies would include the frequencies used by railfans who have ham or GMRS licenses and/or use two-way radio in support of their railfanning. (If there are such frequencies for aviation buffs, then I withdraw my comment above.)
I understand the grammar-technicality you highlight above regarding the suggested "Aircraft Monitoring Frequencies" category, and in that context, I agree with you completely, because I also found/find the "...Monitoring Frequencies" description to be problematic (whereas the other subcategories, like "Air Traffic Control Frequencies" are grammatically precise and accurate).
As you probably guessed, the "Aircraft Monitoring Frequencies" suggestion was an unpolished-attempt to suggest a "...Frequencies" category that would:
- Be a child of "Aircraft Monitoring" since not all "Aircraft Monitoring" articles contain frequencies, and
- Follow the "...Frequencies" naming-convention as closely as possible and
- Allow "Aircraft Monitoring" articles that contain frequencies to be appropriately categorized with a "...Frequencies" category.
Maybe another approach would be two-fold:
- First, Eliminate/Avoid the "Aircraft Monitoring Frequencies" category or any such "...Frequencies" category that is so poorly-named, and then:
- Second, Create additional specific "...Frequencies" categories for the frequencies found in general "Aircraft Monitoring" articles. For example:
- Airport Frequencies (proposed)
- Air Show Frequencies (already exists)
- Air Traffic Control Frequencies (already exists)
- Airline Frequencies (proposed / see last comment below)
- Blimp Frequencies (proposed)
- General Aviation Frequencies (proposed)
- Helicopter Frequencies (proposed)
- ...etc.
- This way, any article listed in the "Aircraft Monitoring" category would also get a specific "...Frequencies" category as well, instead of the confusingly-named "Aircraft Monitoring Frequencies" category.
Thanks for pointing out the problem with "Aircraft Monitoring Frequencies".
Another example:
"Milcom" is a made-up word, known to hobbyists. It has no real-world connection to defense, military, or "support" operations of any kind. Why not just drop it and use language that means something in the real world?
As hinted in an earlier post, I am in-favor of losing the "MilCom"
category all-together, and following the categories that correspond to real entities, like having "US Defense" (or whatever its updated name will be after the current revision-cycle) as a child of "US Federal Government", and under "US Defense" have all subcategories related to both the civilian-components of the US DoD, as well as those relating to the US military branches (currently listed under MilCom).
I think this would much more closely match reality, and make navigation-by-category more sensible for those who are listening/scanning and trying to match agency-articles with what they are hearing.
Since Wiki articles' contents and links can be customized as the author wishes, there could still be a "MilCom"-type
article that summarizes Military Communications/Monitoring, and links to related articles. But, I think, the categories-tree should be structured to match reality, and where possible, match existing agency/organizational structure.
If something in the Wiki (or in the DB for that matter) has been defined in the world external to RadioReference, then why establish and argue over made-up definitions and categories?
Agreed. It seems like it would be better for both groups -- those visiting/searching RR, and those maintaining RR over time.
It might also be worthwhile to think about the questions being asked by scanner listeners, who are the Wiki's target audience. If someone wants to listen to communications relating to aviation, say, they often inquire about airline company frequencies, airline ramp communication systems, ATC frequencies, and airport operations frequencies. All of those things are part of monitoring "aircraft" to many hobbyists. At least the "super-" and "sub-categories" should be designed around such considerations.
As seen in the above list, something like "Airline Frequencies" could easily be a child under "Aircraft Monitoring". Others could be added, too.
Thanks again for the helpful ideas and comments.
Thoughts?
And, thanks to ka3jjz for all the continuing hard work. Non-RR projects are keeping me busy right now, but I will jump in to help when I can.
