Subaru Impreza Radios
dropkick
Here is a picture during a test-fit while installing a BC-996T scanner in my WRX. Ignore the unfinished edges for now!
The brackets behind the panel are ISO sized, but the opening plate is not. Had to remove 5mm of materal from each side. I'll post more pics later. Will note how the Uniden actually bleeds over into the space for the unit below too. Fortunately the cd player has a small face and allowed the Uniden to hook over the front edge of it (the cd face comes off).
Electronics were super easy to hook up. Power. GPS. Splitter on AM/FM antenna. No problems. I was replacing a Uniden 780, so really the power connector just changed. I only pulled RX from the GPS bus in the car. There is a Kenwood D700 which has full access to it, tho I don't really use it.
STiMULi
Tucson, Arizona
Good looking install.
Did you use the sleeve? How do you have the Kenwood mounted?
Antennae please :)
(I have a 2005 STi with the same equipment but I moved my (AM/FM) radio to the stock dash pod location.)
BoxAlarm187
Level 6 RR Member (Since 1998)
Old Dominion
That is a great looking, clean install. Very well done. I espcially like how the aftermarket AM/FM head unit compliments the dash and the 996T.
dropkick
The 996 is mounted in "ISO" configuration. You don't use the included sleeve, and you remove the outer chassis cover. Two screws (M4 size) on the sides. I did have to make some additional holes in the car mounting plates cause I didn't like the depth it was at and I had to put it slightly "out of spec" to get it to fit on top of the cd player. I used to have the subaru guage pack above the cd player (both standard ISO sized). Its now back up on top of the dash. That upper upper location had the BC 780 in it without any modications. Lots of room above the vents. That might be an alternate location for a 996 if u dont want to cut the audio trim piece, but I didn't try it.
Yeah, I use the AM/FM antenna for the scanner, thru a $20 spliiter from Grove, iirc. Works fine for what I listen too (almost all 800mhz from strong sources). The only other outside antenna is a valor glass mount 2m/440. Yes, glass mount, I know, but it works in my area just fine :)
The D700 is right in front of the cigarette lighter/ashtray, its base is mounted to that little pocket forward of the gear shift. It blocks the outlet, but added one under the seat if i need it.
This pic is what it used to look like.... Wow my car was clean 4 years ago!
Like the 780 install ... my personal preference is to have the radio up high like where the 780 was, just think it is better. Too bad it is difficult in some cars to do that .. mine included. Nice install of the new radio .. good job.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Does your car have an outer AM/FM antenna? Mine is the mesh on the windscreen, behind the mirror, I think. I have an '06 and am thinking of an eventual setup like what you've done, once I save up some $ for a carputer and 996.
I have to figure out how to run an external antenna for my GPS, if not a magmount for the scanner as well (if I don't use your idea). The antenna I have only has a 6 foot cord and I am really loath to just slam it in the door jamb. I thought I was going to be really clever and put it on the trunklid, running the cable thru the pass-through, but as I say, the cable only reaches to the center armrest/console if done that way - and I want to mount it on the right side of the dash, by the climate controls.
STiMULi
Tucson, Arizona
It is in the rear glass above the defroster. You will see a T at the top.
(05 STi)
policeMonitor
Michigan
that is a awsome set up!!!!
dropkick
Antenna: Mine's an '02, so it's got a real whip antenna above the driver's side A piller... Not sure what year they disappeared on. I also have the wagon, but it should be the same.
GPS: Garmin GPS-35 is on the rear hatch, on the inside, where the glass meets the body of the door. Wire runs next to the washer fluid/electric port by the hinges. Isn't outside and isn't exactly pointed straight up, but it works just fine. Like the other stuff, its also low-profile :>
deckgun
NJ
that looks hot.... i have a wrx n i was lookin for a place to mount a scanner.... i have my icom 208H mounted by my driver side "A" post (remote mount).... and switches for lights where u have ur scanner.... might have to do a lil change.... where did u mount your speaker?
rhutch
Ontario
If it's a Garmin get an extension for the cable, won't really notice any difference with the GPS. (don't know what's available for other makes)
Jay911
Thanks, didn't know if there was such an extension cable. I'll look it up on the website right now. (GPS is a 60CS, antenna is ... I forget the name, but it's the accompanying magmount aerodynamic (plastic, non-whip) type.
STiMULi
Tucson, Arizona
Real good look!
Is there enough room for the DIN sleeve to go in (modified I am sure). I want to be able to pull out the radio on the fly.
Are the gauges up top now?
What is your username on NABISCO? (PM me if you want)
dropkick
STiMULi said:
Real good look!
I think the DIN sleeve is too wide by about 5mm to fit inbetween the ISO backets. This is what I remember from the original cd player install. I remember not being able to use it. And holding the DIN sleeve up to the 780 here on the desk, it's about 5mm wider. The 780 fit between the upper pod brackets perfectly.
Yup, the guages are back up in their "factory" location :)
For OLD pics, see: http://www.krap-fm.com/wrx/radioinstall.html
The updates will go there, when I get a chance...
Here is the final result, minus the D700 which was absent that day... But you can see where it goes...
