System 2088 NXDN
DaveH
Ottawa, Ont.
164.985 Ran 3 Enc. Does this help anyone?
One of the few frequencies in my area that I haven't been able to get any info on until now (NXDN upgrade)
Sent from my SM-G390W using Tapatalk
It's a Site 3 (RAN=3) voice channel. Back a bit in this thread the channels are listed (mostly). Would help if you can report on the signal strength of the various CC's as nobody seems to know their locations (even generally) for Site 3,4, and 7.
The DB is not up to date.
And unfortunately, 100% ENC.
162.570
151.910
152.750
Dave
mciupa
Canadian DB Admin
Moderator
I'm here a lot
The DB is not up to date. And unfortunately, 100% ENC.
Dave
I looked at the submission history for this system. No one has ever made a submission for it.
Nothing better to do on a rainy day. If I have time, I'll review the five pages and see what I can add.
(A few minutes later) :p
Look over the system: https://www.radioreference.com/apps/db/?sid=9247 and see if it is up to date. :)
IdleMonitor
Does this help anyone? I had to take a drive and find me a hill to park on outside of Renfrew to get the following. Also what does the S Q and A stand for again? I forget.
Sys ID though doesn't say 2088 though it's different. Does that matter?
Uniden 436HP/VHF/UHF NMO Ground Plane Base Antenna
Anytone 6666/Sirio Tornado 27 Antenna
President Grant II/K40 Magnet Antenna
TRC-465 - Spare
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Watching a multi-channel site versus this one, not seeing any difference on DSD+ datastream.
What would I be looking for?
Dave
You might have to run more verbose logging to see it, and you would see it in the DOS screen.
Sync:+NXDN96 TB CCDATA SRV_INFO Category=Local System=181 Site=9 MultiSite LocnReg GrpReg CompCC Voice Data ShortData Status&RemCtl
Sync:+NXDN96 TB CCDATA SITE_INFO Category=Local System=181 Site=9 MultiSite LocnReg GrpReg CompCC Voice Data ShortData Status&RemCtl Version=1 Neighbors=8 CC=3
Notice the "CompCC" -- for Composite Control Channel. If you see CompCC, you know that the control channel can serve voice too, and if you see voice on a CC you'll likely see DSDPlus display IDAS during the voice call.
UPDATE: Actually, CompCC will reveal that the CC is set up to handle voice if needed, but that doesn't guarantee a single channel site. In my area, starting out the regional NXDN system of one provider had only a single channel active per site. Now those same sites have multiple channels, yet the control channel still reports CompCC. So I'm not sure that CompCC present in the advertisements by the system is indicative of a single-channel site, but rather just indicates that the CC will perform double duty as a voice channel if the need arises. Somebody who knows more than I will have to verify that.
DaveH
Ottawa, Ont.
Found a new Site 8 with CC on 165.045 (Channel =18). Could not get a Neighbour list from it (weak signal). May be another single-channel site like 7.
Dave
mmisk
Ottawa Canada
Left DSD running on that frequency for a while and eventually came up with this:
Sync:+NXDN48 TB CCDATA SRV_INFO
Sync:+NXDN48 TB CCDATA ERR1 SRV_INFO
Sync:+NXDN48 TB CCDATA ERR4 SITE_INFO Category=Local System=2088 Site=8
MultiSite LocnReg GrpReg Auth CompCC Voice Data ShortData Status&RemCtl Version=
1 Neighbors=3 CC=18
Sync:+NXDN48 TB CCDATA ERR2 SRV_INFO
Sync:+NXDN48 TB CCDATA ERR29
Sync:+NXDN48 TB CCDATA ERR3 SRV_INFO
lucll24
ProScan
Good moring
I'm new to NXDN. I bough the liscance for my 436 and loaded using ProScan on my scanner but I'm not getting anything from any of the sites. I'm in Gatineau and would image that MRC des collines would come in strong.
Have you had that problem with ProScan?
thanks
Luc
DaveH
Ottawa, Ont.
I think Site 7 is a single-channel site, still weak here but managed to catch some enc. voice
on 152.750, but have not seen any other channels active.
Dave
152.750 CC converts to VC frequently. A couple of times I've seen Ch. 7 (153.515 on Site 2) show
up but can't confirm it's not a bit of interference, or weird decode error. Someone else might confirm,
hold off DB update.
Not knowing where Site 7 or 2 is, but if far enough apart, some frequency re-use is possible.
Dave
BTW Site 1 channel 3 is a typo, should be 165.735. Also, CC on Site 4 is 151.9100.
DaveH
Ottawa, Ont.
Good moring
thanks
Luc
Sorry Luc, I cannot help with your 436 and ProScan issues, but the system appears to be 100% encrypted
so you will not be able to hear anything interesting. The best we can do is track frequencies, sites,
and TG activity.
Dave
