t4win & pro-2051
steve2004
update below
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
T4Win is probably not the best choice since it hasn't been developed in a while - UniTrunker is a better bet.
Did you put a discriminator tap in the 2051? Because of the reshaping done in the audio amp stages, you cannot just feed speaker or headphone audio to trunking utilities like UniTrunker. A discriminator tap is required. 73s Mike
steve2004
if you know how Please share it with us.... nobody knows where it is.
even UniTrunker requires disciminator tap ?
what about a data slicer will that do?
Thanks.
You will definitely need a discriminator tapped radio. Unitrunker can support a data slicer but it is (a) very experimental and (b) only works on 2K and XP. I can't remember if T4Win was given that capability or not. Most folks use a direct sound input.
steve2004
I will go dig my old Pro-2039 this week end... it has one I think. I seen where it should go anyway.
too bad the Pro-2051 is still unknown (it is keept in such secret by R-S )
Someone just needs to shine flashlight on the main circuitboard and locate the FM IF chip.
-rick
steve2004
I'm not sure if I found the right spot..
check the pics
and Also did a quick test with universal trunker and I also attached a pictures of the result.
Does it look like I found the Discriminator tap of the Pro-2051 ?
Likely so. Are you able to get 100% decode on any area signals?
Also, with the tap in use - does the speaker audio drop out or loose volume? Does the squelch still work. Sometimes adding a tap will affect these.
-rick
steve2004
-rick
yes 100%
Does the squelch still work: no. it has no effect on the tap just on the scanner speaker)
and so is the volume.
(thank you for pointing it out. I thought something was not right about the squelch.)
ab3ai
For the 2051 I used the LND7 point for my tap. It's labeled data skip. works 100% decode with unitrunker and works fine with a data slicer too.
Chris
